http://www.audizine.com/forum/showth...ght=relocation
Although I did mine much like this I wanted to still use the stock pipe that connects the IC to the Throttle Body and the stock TIP.
So I called Forge to get a 50mm T fitting and for the rest I went to Advanced Auto Parts and Lowes to get what I thought I might need.
I didnt use all of this I just got more so I didnt have to make another trip. I did not use the extra vac-hose, the 90degree fitting or the extra straight fitting.
So with everything together I took off the pipe from the IC to the Throttle Body and cut it in half, and installed the T-fitting.
You can leave it like this or cut a extra hole so it looks and fits alot better.
Next I took the radiator hoses I chose and cut them the way I wanted, to make everything fit right.
Everything went smoothly and was very easy. If your planing to do this all you really need is the T-fitting from Forge($40shipped), a few radiator hoses of your choice(about 20$), hose clamps, a pvc plug for the old DV spot, and a pvc connector fittings. I did not need any extra vac-hose cause the stock line was plenty long.....Hope this was helpful to anyone wanting to do this or still unclear about it.
Here is a questoin I have though. I want to disconncet my 007 from the return hose that goes to the TIP to see how it sounds. I guess Ill throw a code, but when I get done riding around for a min and plug it back in will the code go away or will I need to clear it myself.
