Page 5 of 5 FirstFirst ... 345
Results 161 to 172 of 172
  1. #161
    Established Member Two Rings kirkendall's Avatar
    Jan 20 2015
    06 zx6r , 2008 a4 B7
    Lehighton, PA
    I'm trying this. I just hope that when the switch is turned onto low beams if it drops power for a split second and might make an HID ballast turn off.
    2008 A4 6 speed mt.
    JHM STAGE 1 - 93 oct.
    Test pipe
    rs6 grille mod
  2. #162
    Veteran Member Four Rings Mistro's Avatar
    Jun 19 2011
    Quote Originally Posted by mcanedo92588 View Post
    This may sound like a dumb question, but does anyone have an exact name or gauge for the copper wire you are using, or even better, a link/picture of it? I am going to be doing this tomorrow and was at lowes tonight and figured I would look for the wire there. They only had really thick copper wire, and some thinner stuff, but still definitely not what I need. Is it just like speaker wire?
    I used a staple. It's been fine for 4 years now.
  3. #163
    Established Member Two Rings Irufushi's Avatar
    Jul 29 2013
    A4 B7 2.0T quattro S-Line
    Moscow
    How to make working daytime running lights with Gog Light?
  4. #164
    Veteran Member Four Rings Luxus Panzer's Avatar
    Apr 15 2014
    B6 A4 Avant, B4 90 Sprot Q, B4 90 FWD, 2014 VW Tiguan
    Ottawa/Gatineau Canada
    I did this today in my 2004 Avant and the function for ROTW did not change at all.
    I tried setting my car back to Canada, then to ROTW again and still nothing.
    Any ideas?
    This is the end state I am looking for...
    Light switch off = No lights (like USA setting)
    Light switch Auto = Auto
    Light switch to parking/city lights = city/parking lights on (like USA setting)
    Light switch to parking/city lights & pulled out = Fogs on with parking/city lights
    Light switch to on = low beams on.
    Light switch to on and pulled out = low beams and fogs on.
    2004 A4 Avant Quattro. (H&R springs, S100 Nav unit, Neuspeed Cat back, Torque solutions Snub mount, Thor Skid Plate, APR Stage 1, 18" S4 Rims, 2X Podi / Oil Press / Oil Temp / Boost/VAC, Full LED interior, Backup Camera/Screen, Upgraded 2.0 Coil Packs, Vag-Com, B7 Center console/B7 Hand Brake, B7 Aero wiper arms B7 rear headreasts,APR Carbonio intake, Fan washer sprayers,
    2014 VW Tiguan. (bone stock)
  5. #165
    Veteran Member Four Rings ballinb5's Avatar
    Jan 16 2011
    CA
    Quote Originally Posted by Luxus Panzer View Post
    Any ideas?
    Have something similar. I believe i am ROW as a buddy vagcommed me and I wired it up, fogs DO work with parking lights, but the outside ambers are ON... trying to only have the DRL bulb and the fogs on at the same time. Any ideas?
    2021 SQ5
    2008 A4 Avant 6 speed
  6. #166
    Jan 16 2011
    CA
    Quote Originally Posted by ballinb5 View Post
    Bump
    2021 SQ5
  7. #167
    Veteran Member Three Rings mgfranz's Avatar
    Apr 08 2016
    Mission Viejo, CA
    Pulling up an old thread.
    So I went out to play with VAGCOM today in an attempt to get JUST fogs to come on without ANY other lights. Basically what I would like to see happen is for just the fogs to come on with ignition, switch still in OFF position, no brake running lights at all. Do I just need to do the wire wrap mod? My B7 is already set for ROW, no Auto feature, halogen US car. What I would like to see is just fogs on with ignition, still on with city, still on with headlights and still on with high beams. Possible? Remember US car with halogens and NO Auto feature.
    2008 Audi B7
    2003 Ford F250 XLT
    2001 Porsche Boxster
    1999 BMW 740i M-Sport GONE
  8. #168
    Apr 02 2020
    United States
    I did this quick mod about a month ago and had great success. However recently I’ve been running in to issues with either the fogs not coming in when my switch is in the headlight position, or sometimes the fogs just not turning on at all upon request.
    When I first did this mod it worked without the VAG-COM so I figured I didn’t need it. Although with my recent glitches I’m wondering if it is my missing step. Could any direct me on where to snag a VAG-COM cable and five a quick explanation on what it can do?
    Thanks for the help all.
  9. #169
    Veteran Member Four Rings dubenvy's Avatar
    Oct 21 2006
    '14 A4 2.0tQ (wifey)
    Odenton
    Fun Fact: if you have a B7 headlight switch and you drive a B6, this is how you get fog lights working.
    USP CLUB MEMBER #41
    <<Insert Clever Signature Here>>
  10. #170
    Active Member Four Rings EuroxS4's Avatar
    Jan 24 2010
    Paramus,NJ USA
    I think it would be easier to just move the pin in the headlight connector. Also safer as well.
    VW/Audi Immobilizer removal and immobilizer adapting solutions for any and all VAG Vehicles, Odometer matching, SKC/Pin retrieval services/ Component Protection/Module Coding/Diagnosis Services and repairs.RB4/RB8 Specialist cloning and repairs. Located in Northern NJ. For inquries pm for details or contact me via Whatsapp
    Ziddy Autowerks
  11. #171
    May 18 2022
    Michigan
    What is RoTW?
  12. #172
    Feb 16 2019
    Li, NY
    Rest of The World.
