Results 1 to 14 of 14
    Veteran Member Three Rings Lugi20's Avatar
    Sep 24 2007
    Chicago
    Rear sunshade stopped working?
    So I was about to brag about how sweet my rear sunshade is to my friend, and I hit the button and the damn thing isn't working (Murphy's law). I'm sure Audi will replace this, but has this happened to anyone else? Also, I can't even conceve of a reason why it stopped working... nobody has ever been in the back seat and I've never put anything in the trunk, it just crapped out.
    Veteran Member Four Rings PenguiN's Avatar
    Nov 12 2006
    RR Sport SC-B6S4-Gallardo
    DC
    Re: Rear sunshade stopped working?
    it could be just dust that got in the cracks and the condensation just moistened it. When it dried, it probably made it get stuck.. just my .02
    Jan 14 2008
    B8.5 S4 - 6MT Sepang/Panda
    Calgary
    How cold out was it? If the interior temperature is too low it won't deploy to keep it from cracking/ripping.
    Veteran Member Four Rings quattroanillos5's Avatar
    Feb 13 2004
    2004 S4 MT6
    Jersey
    Lack of use is the only thing I can think of.... that beign said, I love my rear sunshade! I just wish they made the side shades power, too. But i guess they didn't do that because you might have a passenger in the back with his/her arm out the window...
    sold:
    1999.5 B5 A4 1.8T quattro MT5
    current:
    Moro Blue 2004 B6 S4 MT6
    Sep 24 2007
    Chicago
    I've used it occassionally, almost exclusively just to show people I have one... It stopped working at a range of temps between -20F and 50F, when the car was cold and warm, so I don't think its weather/temperature related. The button seams functional, the shade simply doesn't come up.
    If the car wasn't under warranty I'd look into it myself, but as far as I'm concerned this is Audi's problem and they are going to have to look into it for me.
    Veteran Member Three Rings derleicaman's Avatar
    Aug 11 2005
    NW Suburban Chicago
    Check in your owner's manual. It states that the sunshade will not operate below about 20 degrees. You live in Wheaton, I live in Buffalo Grove. I had the same thing happen to me. It's cold, wait until the car warms up, it should work.
    Established Member Two Rings THM's Avatar
    Jun 06 2007
    Audi A6 4.2
    Chicago
    WTF mine just stopped working too, i can hear a click and then another click but thats it.
    2000 a6 4.2
    Sep 24 2007
    Chicago
    Quote Originally Posted by THM View Post
    My car is silver too... that probably has everything to do with the problem.
    Aug 11 2005
    NW Suburban Chicago
    OK guys, p.82 of the owner's manual:
    "If the sun blind is operated repeatedly within a short time, the built-in overload protection circuit may be tripped. If this occurs, you will have to wait briefly before you can operate the sun blind again."
    "Because of the decrease in the flexibility of the blind material at temperatures below freezing, the electrical circuit which operates the blind shuts off when the temperature in the vehicle fall below 23 F (-5 C). The blind cannot be operated until the passenger compartment warms up above this temperature."
    I experienced this last winter and thought WTF, I broke the sunshade! But once the car warmed up, the sunshade retracted just fine. I use mine a lot in the summer time. Black on black car you really need it when parked all day outside at work.
    I think the clicking you're hearing is the relay switch activating. It's located on the underside of the parcel shelf, along with the motor for the sunshade. I installed mine myself, so I'm familiar with the layout and operation.
    Veteran Member Four Rings PSYC0TIC ONE's Avatar
    Oct 19 2005
    2022 Mazda CX-5, 2013 HD FatBoy Lo
    Virginia
    Quote Originally Posted by derleicaman View Post
    your car didn't originally come with one? would I be able to get the parts required from the dealer and at what damage ($$$)?
    -Cliff
    Current:
    B9.5 //S4-Prstg-Turbo Blue on Gray-30% Tint
    B8 //S4-Prstg-6MT-Ibis on Blk-Sprt Diff-35% Tint-H&R OE Sprngs-AWE CatBack
    B6 //S4 Nogy on Nogy-19" OZ SLs-FI NonRes CatBack-Hardwired V1 w/ LIS4 Display & LaserMask-30% Tint-RS6 Pedals-BiXenon ECodes
    B5 //S4 Cactus on Black-Sport Pckg-18" Flik Justices-JHM Shrt Thrw-APR Stg1
    Aug 11 2005
    NW Suburban Chicago
    Quote Originally Posted by PSYC0TIC ONE View Post
    I bought the rear power sunshade from stevez1 over on navplus.us for $500, switch and wiring throw in another $50. Installed myself.
    Have no clue as to what the new price from dealer would be.
    Oct 19 2005
    Virginia
    sweet... Now this is only for the rear window right?
    I guess I should have asked this before... You do drive a sedan correct? where does it install....
    i'm about to look for pictures now...
    thanks again for the info
    -Cliff
    Current:
    Aug 11 2005
    NW Suburban Chicago
    Yup, just the rear shade. Yes, I do have a sedan. You install this in place of the stock parcel shelf. A bit of a PITA to get the old one out and the new one in. A Bentley manual is really helpful.
    I'd try looking on ebay for companies that do dismantling. Even though they don't list a particular part, if they have current B6 S4 parts, they may have it. This is how I got my S4 Recaros.
    Try [email protected]. I just bought some S4 parts from them.
    Oct 19 2005
    Virginia
    cool, thanks buddy
    -Cliff
    Current:
