Results 1 to 22 of 22
    Nov 09 2007
    Australia
    Xenon vs Bi-Xenon
    Guys, Ive done a search but couldnt find anything(maybe im searching for the wrong thing), so I thought id start a new topic.
    Which one is better? and why?
    thanks
    Veteran Member Four Rings pyro's Avatar
    Mar 18 2007
    '05 A4
    Tampa, FL
    Re: Xenon vs Bi-Xenon
    the obvious - bixenons have xenon highbeams along with the halogen highs.
    some say that the cutoff on regular xenons is sharper, but its not much of a difference.
    bixenons pwn all.
    4 highbeams > 2
    Veteran Member Four Rings Tgr_Clw's Avatar
    Jul 20 2005
    2003 Audi A4 1.8TQM
    Toronto, Canada
    I ran ecode bi-xenons for about 2 years. I now run single-xenon ecodes. Low beam pattern is a lot better on the single-xenon version.
    Appearance: OEM+
    Interior: B6 S4 Recaro Seats
    Performance: MTM Stage 3 / Milltek Exhaust+Milltek HFC / JJ TIP / ASP FMIC / SB FE SS
    Suspension: Vogtland Coilovers / HSport S4 Sways
    Braking: Stoptech 332 BBK
    Wheels/Tires: BBS CH 18x8.5, ET35 / GY Eagle F1 GSD3 235/40/18
    Established Member Two Rings ultraxr's Avatar
    Jul 16 2007
    Virginia beach, VA
    I was wondering the same thing too.
    Veteran Member Three Rings JWERNER24's Avatar
    Nov 08 2005
    1983 Porsche 944 (Track Toy), 1997 Toyota 4Runner (Offroad Toy)
    Central Oregon
    What some people need to understand is that not all 4 of the high beam bulbs are xenon... just the 2 that are the low beams as well.
    Sold: 2002 Ming Blue A4 3.0 MT6Q
    Current: 2001 Brilliant Black allroad 2.7tQ
    FOR SALE: 1983 Porsche 944 - PM for details!
    Oct 15 2006
    From a few to one...
    Arlington, VA
    Quote Originally Posted by JWERNER24 View Post
    in bi-xenons, there's just a flap that reflects the low beams as high beams. like jwerner24 said, it's only the xenon low beams.
    '97 A4 1.8TQ, '02 A4 1.8TQ Avant, '03 A4 1.8TQMS, '04 A4 3.0Q Cabrio - Sold
    '18 S4 Prestige - APR Stage 1 ECU/TCU, APR Intake
    Jul 20 2005
    2003 Audi A4 1.8TQM
    Toronto, Canada
    Quote Originally Posted by NyteEscape View Post
    There is no reflector flap.
    Appearance: OEM+
    Buncha motorcycles
    Memphis, TN
    dont the bi-xenons require you to get a harness extension or cut up your own harness whereas the regular xenon dont?
    APR Stage 2/AWE Intake
    Veteran Member Four Rings Toecutter's Avatar
    Dec 31 2007
    Oregon
    Her friend goes both ways? I did not know that.
    Veteran Member Four Rings gdawg'05a4's Avatar
    May 03 2005
    '17 Q7, '95 Audi 90 AAN Swap
    Boston
    Quote Originally Posted by Tgr_Clw View Post
    Roman, are you sure? If I flip on my high beams on and off, I hear something mechanical going on and allows all the light to shine, like a flap or something along those lines. And of course, the two halogen high beams also go on but nothing to do with the bi-xenon.
    '17 Q7 3.0T | Graphite Gray | Rock Gray || Prestige | Cold Weather | Tow
    '14 A6 3.0T | Daytona Gray | Black || Prestige | Cold Weather | Driver Assist | Rear Sunshades | 19" Sport
    EPL S2 + TCU
    '95 90 Quattro Sport MT5 | Pearl | Black || 20vT AAN swap
    Previous Cars:
    '12 S4 | '13 Q5 2.0T | '11 A4 2.0TQ | '07 A4 2.0TQ | '06 S4 25quattro | '05 A4 1.8TQ MT6
    Senior Member Three Rings jetflyr's Avatar
    Nov 28 2006
    ‘03 A4 TQM Stage 1+, ‘07 FJ Cruiser, ‘18 Highlander
    Cincinnati, OH
    I thought there was a flap also. How else would it allow Xenon light to act as a high-beam?
    '03 A4 1.8T QMS
    -APR Stage 1+, TT 225 Injectors, ECS/Hitachi E Coils, Samco Boost Hoses, Forge 007, ECS Snub Mount, K&N Filter, ECS Steel Lines, B+M Short Shift, AWE Pedals, ECS Rotors and Hawk Pads
    Veteran Member Four Rings Condo's Avatar
    Jan 30 2007
    2001 S4 Avant
    Cincinnati, OH
    It's not a reflector flap. Just a metal flap that blocks light. When you turn the high beams on it lowers to allow the full xenon beam also.
    Jul 20 2005
    2003 Audi A4 1.8TQM
    Toronto, Canada
    Quote Originally Posted by gdawg'05a4 View Post
    Yes. There is a flap, but it doesn't reflect anything. It's the flap that blocks 1/2 of the projector beam giving you the low beam. When you flick on the high beams, that flap drops down (or lifts up, don't remember) thus giving you the full beam.
    Appearance: OEM+
    May 03 2005
    Boston
    I knew there was a flap that blocks the light, didn't think there was a reflector flap.
    EPL S2 + TCU
    Previous Cars:
    Nov 28 2006
    Cincinnati, OH
    Pretty sure the flap is on the bottom and flips up to block the light due to the reversal of the lighting through the lens.
    '03 A4 1.8T QMS
    Jan 30 2007
    2001 S4 Avant
    Cincinnati, OH
    Yeah, the flap is on the bottom and flips down when you turn the high beams on.
    Veteran Member Four Rings 02silverb6's Avatar
    Nov 20 2006
    ATL, GA
    Also alot of people have seemed to have trouble with moisture getting inside the bixenon housings, however there is a fix for it. Single xenon FTW! Im still waiting for a set to pop up.
    PM me if you need RNS-E installed in Atlanta area
    R.I.P 2002 Audi A4 3.0
    Oct 16 2006
    Naperville
    Bixenons require you to extend your harness. thats why i created my own extension. Both US spec and euro spec bixenons.
    Oct 15 2006
    Arlington, VA
    sry for the confusion, just screwed up a few words.
    Jul 20 2005
    2003 Audi A4 1.8TQM
    Toronto, Canada
    Quote Originally Posted by manguyen View Post
    Depends on the car. In my car no extension was necessary.
    Appearance: OEM+
    Nov 09 2007
    Australia
    So there isnt really that much of a difference in the low beam light patten then?
    I think i will be happier with either as Im currently running a HID kit in my halogens..
    Now, this having to extend your harness talk..how do I know if I will or wont have to?
    Oct 16 2006
    Naperville
    Take off your headlights and try to put the new one back on.... or compare the two headlights when they are off the car. I went from halogens to HIDs, and i needed it. Even after removing the clip inside the fender to give some more room. Also i have a carbonio intake, which might make a difference as the harness might have to make a longer route to get to the headlight.
