Results 1 to 4 of 4
    Jan 17 2008
    CA
    3rd gear synchro?!?!
    Help me diagnose my grinding issue: So the clutch is fine and when I row through the gears for upshifts it goes into the gears fine. However, when I am downshifting into third from relatively high rpms ie. braking when getting off on a freeway offramp it grinds as if the clutch wasn't fully engaged or something. It feels like it would if I tried to shift it into gear with the clutch pedal not fully depressed. Driving style is ruled out because it doesn't happen in any of the other gears on this or my other manual car. I make absolutely sure the clutch is fully pressed as well. Does this sound like a synchro issue?! Has anybody else ever had a 3rd-4th gear synchro go bad (I know the 1-2 is infamous)? Could there be a clutch adjustment to cure this? Would a mis-aligned short shifter possibly cause this (keep in mind if I'm not coming down from higher speeds/RPM's it engages fine)? HELP!
    Veteran Member Four Rings Mattgfx's Avatar
    Sep 27 2006
    Re: 3rd gear synchro?!?!
    sounds like your slider/ synchro ... Rob had this problem but he couldn't even get into 3rd gear it completely locked up.. Sounds like a rebuild tranny soon or try some new tranny fluid! Im in kinda the same boat as you just with 2nd gear when the car is cold..
    AKA: Bigair
    Sold: 00 Audi S4
    Sold: 08 BMW 135i
    Sold: 11 BMW 328i xdrive
    Sold: 11 BMW M3
    Current: 15 Audi S3
    Jan 17 2008
    CA
    Anyone else have any input???
    Veteran Member Four Rings YZracer's Avatar
    Sep 20 2005
    Scottsdale, AZ
    Yea sounds like a syncro/slider issue. Like Bigair said, I had my tranny go. 1st, 2nd, and 3rd gear shifts were almost impossible. However, the problem with my tranny was the 1st and second gear syncro. The syncro was just so f**ed up for 1st/2nd, it made 3rd a pain in the ass to shift into even though my 3rd/4th gear syncro was perfect.
    It doesn't sound like you tranny is gone yet, but sounds like the syncro is getting close to it. If your 3rd-4th syncro goes then I'll be happy to sell you my busted tranny with a bad 1-2 syncro. You probably have a little while before your syncro goes assuming you don't push your car to the limit every second.
    CURRENT TOY
    2013 TT-RS Ibis White - Stock for now......
    Sold:
    2010 B8 S4 Phantom Black: Stasis Touring Suspension Kit, APR Pulley, APR 93 Octane Pulley Tune, APR Full Carbonio Intake
    Parted and Torn down:
    2000 Black 6spd S4
    SSP Tuned PJK04 Stage 3
    Burned:
    2000 S4 Tiptronic (B5)
