Results 1 to 33 of 33
    Mar 07 2007
    04 S4, blown 91 Mustang GT
    Indianapolis, IN
    2004 S4 automatic 1/4 mile times
    The Mustang had been down for the count since June (motor upgrades) and I was suffering from drag racing withdrawal. So I took the S4 to Indianapolis Raceway Park for the last test and tune session of the season. Mind you this was back on October 29th. Conditions were good, temp was around 50, humidity even lower.
    The car is bone stock, but I did remove the spare and tools from the trunk (about 50 pounds). I weigh 190 so you're looking at a race weight of about 4050 pounds. The car had about 1/2 tank of gas and has about 45K miles on it. My best time came after about 50 minutes of cool down with the hood open went as follows
    60 foot - 2.186
    330 foot - 6.072
    660 foot - 9.261
    660 mph - 77.39
    1000 foot - 11.955
    1320 foot - 14.225
    1320 mph - 98.03
    I guess I thought the car would do a little better. I'm sure new plugs and less gas in the tank might get me another tenth. Traction control came on with every launch which indicates pretty poor track conditions, considering the car never spins on the street from a stop. Regardless I thought the car would do better off the line. If I could get another tenth off the 60 foot time I would think it would run a 13.99. However, the car seems to push through the brakes eliminating the ability to footbrake the car.
    Either way nothing special, just wanted to share. I know this car was never intended for drag racing. I'm just curious if there is a trick to getting the car off the line a bit harder.
    Take care all!!
    Senior Member Two Rings MTLA4's Avatar
    Nov 09 2006
    Next Audi A3 TDI , Too many daily drivers, 135I(sold),Jetta(sold),A4(RIP)
    Montreal
    Re: 2004 S4 automatic 1/4 mile times
    next time take traction control off i can't drive with that crap
    I've been Audiless for a while but one of my DD will get replaced by an A3.
    Jul 21 2004
    South Florida
    Quote Originally Posted by BrianSteuerwald View Post
    60 foot - 2.186
    330 foot - 6.072
    660 foot - 9.261
    660 mph - 77.39
    1000 foot - 11.955
    1320 foot - 14.225
    1320 mph - 98.03
    Take care all!!
    Can you send a photo of your timeslip to: [email protected]
    along with the year of your car and the octane fuel used as well as any mods to the car. I'll add you to the database. Thanks.
    cheers! Mike
    2018 Audi S5
    Gone-
    Mar 07 2007
    Indianapolis, IN
    MTLA4,
    Traction control was off. But when I launched the car I noticed the traction control icon blinking on the dash which I believe indicates when the system is active. The icon was only blinking upon the first second or so of the pass, then it was off the rest of the way down the track.
    Veteran Member Three Rings Lugi20's Avatar
    Sep 24 2007
    Chicago
    Does the light indicate the system is on or simply that you are losing traction? There is a difference between a warning system and an active system.
    Aug 09 2007
    2004 A4 1.8T Quattro Tip USP
    Portland, OR
    click ESP button and you'll see a solid esp logo on the dash, that means the system is off.
    when it is flashing the system is actively doing something
    when the light is off the system is "on" but not currently doing anything.
    correct me if im wrong obviously.
    USP CLUB MEMBER #75
    Registered Member Three Rings turbo4s's Avatar
    Mar 27 2006
    AUDI B7 S4 / MKV GLI
    My 60ft- 2.031
    My 1/4- 13.789 @ 103.27mph
    My Car is a 2006 S4 Tip.
    I dont have a scanner but I do at my Office so mybe I could remeber to scan it there.
    I ran three times down the track and they were all consitant.
    I dont know what happen with your time. My A4 2.0T was running 14.3's
    Veteran Member Four Rings toaster's Avatar
    Sep 16 2005
    Gone:A4 USP+ / A4 S-Line+
    long island, ny
    Quote Originally Posted by eddier View Post
    check, check, and check.
    esp comes on only when it needs to - something must activate it...it's always watching though. even when it is turned off, it can still override if it needs to, it just kicks in later.
    Veteran Member Four Rings Dodge2Dub's Avatar
    Feb 18 2007
    E90 M3; Ducati S2R 1000
    San Diego, CA
    Quote Originally Posted by turbo4s View Post
    My 60ft- 2.031
    Your car is stock, right? That's a pretty quick time for a Tip. Based upon what folks have said about the Tip vs. the MT, I would have expected a 13.9 since the MT runs a 13.7.
    Cool stuff with a little growl!
    Feb 18 2007
    San Diego, CA
    60 foot - 2.186
    330 foot - 6.072
    660 foot - 9.261
    660 mph - 77.39
    1000 foot - 11.955
    1320 foot - 14.225
    1320 mph - 98.03
    Take care all!!
    Mine surges off of the line with Traction Control off, torque braking to 2K, and the transmission in Sport mode.
    I'm not sure what you mean by the statement that the car pushes through the brakes....the problem that I have found when torque braking is that I can't rev the car past 2K because it bogs down.
    Jan 01 2008
    Long Island NY
    I am hopping to get in the 13's with my tip chipped A4 2.0T Quattro. I suspect my car now runs a 14.30 with exhaust, test pipe and CAI. Numbers could be alot better.
    Veteran Member Three Rings Four Play's Avatar
    Mar 15 2007
    is full of shit!
    Texas
    My car will push through the brakes too unless I get a little extra help.
    When you are at the line and are pushing the brakes down as far as you can, put the car in neutral and rev it a few times, and you'll feel the pedal drop down a bit more. Put it back in S and you should be good to go. In my car, I can hold it at 3k rpm's with no problem, makes for really good launches.
    V8 Touareg - 1G TSI AWD - WRB WRX
    Feb 18 2007
    San Diego, CA
    ^^^seriously? My S bogs down above 2K. I wish I had the problem of the car trying to break through!
    Oct 03 2007
    B7 S4, Kia Cadenza, Kia Optima
    Orange County, CA
    Quote Originally Posted by Four Play View Post
    I noticed on the bottom it says A4.... do you have an S4 as well? That could mean a world of difference here
    Mar 15 2007
    is full of shit!
    Texas
    Quote Originally Posted by wkornfeld View Post
    No, just an A4, forgot to mention that
    Is anyone else unable to rev past 2K rpms at the line in an S4, even with the way I launch mine? I understand there are some differences between the trans, but 2K sounds a little low, is the ECU stepping in possibly?
    Veteran Member Three Rings Audi05s4's Avatar
    Oct 17 2006
    Hockessin, DE
    if you turne the traction control off the light should stay on the entire time it shouldnt blink
    daworldisyours.com/forum<----check it out!!!!
    Senior Member Three Rings dr.evil's Avatar
    Nov 27 2005
    Sparks, NV
    try pressing on the brake, putting the car in neutral, throwing a couple quick revs and see if the brake goes down further and holds the car better. This trick really helped in my Typhoon, was able to build 15PSI boost without pushing through, and it had drum rears! Talk about a neck snapping launch.
    2014 SQ5 Prestige - Glacier White
    1970 Mustang BOSS 529
    Veteran Member Four Rings AB18's Avatar
    Dec 17 2004
    US
    I would think you would be able to bring that down some. Just for reference, i ran 13.9 in my nonchipped B5 S4, with 90hp less. If you could get some of that weight out of the car, you could get that 60 down in the 1.9 range.
    2001 S4 6sp...has a few goodies...and JHM shifted
    Tons of parts for sale..
    GIAC A box ECU for sale-350shipped.
    http://www.audizine.com/forum/showthread.php?t=170072
    Veteran Member Four Rings EuroB6's Avatar
    Nov 24 2005
    2024 Audi Q7 2017 911 GTS
    New Jersey
    My 60ft- 2.031
    with a trap like that, you should be running LOW 13s, easy! your launch is what slows your time down, other than that, you have a strong running car
    2020 Audi SQ7 PremPlus | Navarra Blue|Black|Black Optic Package| 22” Forged Black RS Performance Wheels
    2024 Audi Q7 PremPlus|White|Beige|Black Optic Package
    2017 Porsche 911 GTS Black | GTS Interior Package | Numeric shifter | GT3 RS Skirts | Kline SS Headers, Kline 200 Cell Cats, Kline SS Exhaust | Full Car PPF | 20” BC Forged MLE81 | Michelin PS4S |TechArt Springs | Vektor Performance Oil Separator | BMC Air Filter
    Mar 07 2007
    Indianapolis, IN
    That car must be one of the mythical factory freaks. 5.24 extra mph at the traps would quickly pull away from my 98 mph. Perhaps density altitude could be playing a factor in the mph discrepancy. But alas, the other car is for going fast in a straight line.
    Senior Member Three Rings killintime's Avatar
    May 02 2007
    VA
    So is my car, B6 S4, unusual? Because it runs 12.5's stock!
    May 02 2007
    VA
    Thought someone would have called me out on that already...
    Obviously 12.5 is BS.
    However I am hoping for a 13.6...it's a stock B6 S4 with a 6spd.
    Mar 27 2006
    Quote Originally Posted by EuroB6 View Post
    I must or it just like the Motor Trend mag I have, 06 S4 runs 13.6 1/4
    Mar 15 2007
    is full of shit!
    Texas
    Quote Originally Posted by dr.evil View Post
    Already got it covered
    Veteran Member Four Rings quattrosaint's Avatar
    Sep 24 2007
    Dallas
    My 60ft- 2.031
    damn these s4 times suck off the line! no offense. everyone of you has me up top but why cant you get off the line?
    2007 A4 Quattro 2.0T Tip
    Go Fast:Custom GIAC Tune & APR HPFP & AWE FMIC & AWE Exhaust & Labree DP & K&N Filter & Forge DV & Eurojet PCV
    Stop: ECS Stg 4 Porsche BBK
    Twisties: H&R Springs & RS4 Sway & Ti Rims
    Stunt: S4 Grill & S4 Rear & Cupra R Spoiler & TTS Wheel & 8MM Spacers & CF Trunk
    Now................Mostly parted out. Thanks everyone who participated
    Mar 07 2007
    Indianapolis, IN
    Thats what I'm trying to figure out. You don't have much control over launching an auto car. Just stab it and steer.
    Registered Member Two Rings
    Jul 18 2007
    West Coast
    60 foot - 2.186
    330 foot - 6.072
    660 foot - 9.261
    660 mph - 77.39
    1000 foot - 11.955
    1320 foot - 14.225
    1320 mph - 98.03
    Take care all!!
    60 foot of 2.1 with an AWD?
    That sucks.
    Feb 18 2007
    San Diego, CA
    ^^^troll!
    Jul 18 2007
    West Coast
    Quote Originally Posted by Dodge2Dub View Post
    ^^^troll!
    I'm just saying...I had a 60 foot of 2.0 and still ran a 13.0 @ 107 mph.
    Maybe the quattro was defective?
    Feb 18 2007
    San Diego, CA
    Okay I'll bite and assume that you are not trying to start crap again.
    Are you referring to your 335 or your previous S?
    Sep 09 2007
    AWD
    Turner
    hhhhmmm.
    Feb 18 2007
    San Diego, CA
    Point being that it's not apples to apples
    Mar 27 2006
    I think a 13.7 is a respectable time. I know I could have done better. There always room to improve. I dont know how much improvement with my tip but you never know.
