Results 1 to 12 of 12
    Registered Member Two Rings
    Jan 26 2006
    california
    When do we need to replace rotors?
    I was wondering if we really need to replace those rotors as recommended by the dealership. I understand that brake pads need to get replaced from time on but do rotors need to be replaced also? I had about 4mm left and my dealership wanted me to replace the rotors and pads. thx!
    2006 a4 3.2 quattro s-line.
    Veteran Member Three Rings Cronogr's Avatar
    Dec 14 2006
    Audi A4 B7 1.8TQM
    Greece
    Re: When do we need to replace rotors?
    replace the rotors ?? wtf ? the first time i hear that !!
    On my b5 i have 150.000khm and i never changed my rotors neither audi told me too (ok ok i change them with betterones but not because of the dealership :P)
    Audi A4 1.8 TQM B7 ~ Revo / Forge Dv / Sprint Booster / Apikol Snub Mount / Dtm Air Filter / Rs4 Sway Bar / Ebay SS / bbs s4 wheels
    Audi A4 1.6 FWD B5 ~ Koni sport / Eibach pro / Ebay ss mod to fit / Full Meyle CA kit / 034 motor,tranny mounts / 034 Strut mounts / Awe Dts Stabilizer / Apikol Snub mount / Neuspeed 28mm rear sway / Jhm shift knob / Momo e-brake / 17x7.5 oem b7 wheels
    Registered Member Four Rings
    Apr 24 2007
    Great Lakes of SoCal
    you change them when they are below factory specifications. however, you DO NOT turn or machine rotors on most german cars.
    Got Oetty?
    www.DiscountTires.com
    Just updated!!
    Veteran Member Four Rings 80sGuy's Avatar
    Oct 09 2007
    Miele S7
    The answer is: Yes, you do need to change them, but not as often as pads and usually on the front.
    Depending on your driving conditions, they can be warped due to extreme heat - say you live out in the California desert, or around the southwest like southern California, Nevada, Arizona or if you drive/brake like a mad manic all the time...then the answer is a definite yes, but you don't need to change them as often times as the pads. They should get at least 85,000-90,000 miles on them under normal wear, if not, more.
    If you want better heat dissipation, you should upgrade to some 'cross-drilled' type discs - like Brembo.
    Walnut Creek, Ca
    Quote Originally Posted by crack View Post
    Ask for the measurement of the rotor. Rotors are replaced when they are within .50mm of the wear limit.
    - JoJo
    Established Member Two Rings hmmd's Avatar
    Feb 07 2007
    2005.5 A4 2.0T quattro
    el centro, california
    the dealership replaced my front rotors at the 35k service
    ha haa! dangly parts
    Senior Member Three Rings FlyPenFly's Avatar
    Oct 29 2007
    Australian Shepherd
    San Diego, CA
    On heavy German cars, I've seen it usually around 40 to 60k miles that front rotors need to be replaced. Easy enough to do yourself and flush the brakes as well.
    Veteran Member Four Rings Sanjman's Avatar
    Nov 16 2006
    nothing else special
    Skokie, IL
    Quote Originally Posted by 80sGuy View Post
    Really? I thought it was the other way around where you live in cold areas with snow/rain that cause the warped rotors. I thought this because whenever you cool down really hot metals too quick causes the metal to warp.
    I could be wrong... I failed Thermodynamics class
    Oct 09 2007
    Miele S7
    Quote Originally Posted by Sanjman View Post
    No dude, your rotors can only 'warp' under extreme heat conditions. In cold areas, metal becomes 'brittle' when temps drop thus can break or crack when extreme heat comes to play or vice versa, but not warp.
    Twenty years ago - when I was young, dumb and full of cum, I literally crack broke the engine block from an old Chevy on very cold mornings by revving it full throttle during start ups. Somehow the heat from the combustion got to the colder layer of the block. This was when engines weren't made of aluminum like today.
    Also, I've already went through three sets of front rotors on a Japanese subcompact and the thing's only got 120,000 miles on it. It's a front drive, front disc/rear drum type of vehicle where all the 'load' comes to the front.
    In southern California, we get more heat than cold weather.
    Veteran Member Four Rings element256's Avatar
    Apr 15 2005
    Is about to change completely
    Destin Florida
    I got the hookup on rotors if you want to upgrade or even for the OEM ones.
    Registered Member Two Rings OceanBlueB7's Avatar
    Oct 15 2007
    Ocean Blue Pearl '06 A4 2.0TQT
    Boise, Idaho
    I picked up my car with 16k miles on it and the rotors were already severely worn. THe pads have yet to reach the wear sensors. Either the pads are too aggressive, or the rotor metallurgy on our cars sucks.
    Veteran Member Three Rings Bryan's Avatar
    Mar 20 2007
    Vancouver
    I just changed roter, pad from AUDI servise...
