Originally Posted by
gerrygarcia11
I need help my situation got worse here. Idk if i should keep driving it like this or just let it be until i get it fixed
Sent from my SM-N910V using Tapatalk
gerrygarcia11
Should i try taking it out and then putting it back in and make the pinch bolt tighter.
That tie rod end is absolutely not seated correctly. I am not sure how you even got the pinch bolt in all the way. I would loosen the pinch bolt, pull the tie rod out, take the pinch bolt out, then install the tie rod end and make sure it is seated properly, you can see the slot in the tie rod end for the bolt to go through, make sure that slot is facing the direction of where the pinch bolt will go through. Once its seated in the spindle, and you are sure the bolt is actually going through the slot in the tie rod end, torque it to 36 ft-lbs, or at least just make it's "snug" if you don't have a torque wrench. After that you should be good to go and you should be safe to drive and the tie rod will not fall out.
