Results 1 to 13 of 13
    Registered Member Two Rings I Audi5K I's Avatar
    Jun 15 2007
    2002 A4 1.8T QM
    Atlanta
    Camshaft Seal Replacement DIY???
    Does anyone have a DIY for a chamshaft seal replacement....searched and just can't find one. Thanks!
    2002 A4TQM
    Forge 007 DV
    Coming Soon:
    | Revo Stage 1 | RNS-E | Racetec FMIC | Milltek Exhaust |
    Jun 15 2007
    2002 A4 1.8T QM
    Atlanta
    Re: Camshaft Seal Replacement DIY???
    anyone??
    2002 A4TQM
    Forge 007 DV
    Coming Soon:
    Feb 13 2006
    try searching for "camshaft" ...
    Jun 15 2007
    2002 A4 1.8T QM
    Atlanta
    Tried, Still no go...
    2002 A4TQM
    Forge 007 DV
    Coming Soon:
    Feb 13 2006
    are you trying to replace the front seals, or rear?
    Feb 17 2005
    Sarasota, FL
    The rear seals are a bitch, you have to partially take the cams out. Luckily the dealer covered mine under warranty! Good luck!
    Jun 15 2007
    2002 A4 1.8T QM
    Atlanta
    Just the front one.....5 dollar seal
    2002 A4TQM
    Forge 007 DV
    Coming Soon:
    Veteran Member Four Rings BOPOH's Avatar
    Oct 08 2007
    Columbus, OH
    sorry to bring it up, but i still cant find any good DIY for any camshaft seals, any info(price, websites, etc) would be greatly appreciated
    Feb 17 2005
    Sarasota, FL
    lol @ my retarded response years ago. Are you trying to change the cam tensioner gasket or the front cam seals?
    Oct 08 2007
    Columbus, OH
    i dont think that anything is leaking yet, but im getting new clutch and changing oil everywhere, so i want to do preventive maintenance on EVERYTHING that i can while i have access to lifts and tools.
    Oct 08 2007
    Columbus, OH
    i guess nobody never replaced it . . .
    any help at all?
    Veteran Member Four Rings A4 TSCHUSS's Avatar
    Apr 24 2005
    E55 AMG, CTS-V
    Jacksonville, Florida
    You will have to take the valve cover off then the cam cap that holds the seals in place (it spans across both cams). For the intake cam you will need to take the cam position sensor off which is easy to then slide the old seal off and put the new one on, but the exhaust cam involves a lot more work. You will have to take the timing belt off and then the cam gear so that means you will need to take the cam tensioner off. Basically you will need to do a timing belt job, so look for what you have to do to change the timing belt because you will need to remove all that crap in order to take the timing belt off to then take the cam gear off so you can once again slide the cam seal off then slide the new one on.
    ~David~
    Gone but not forgotten 437whp on 93 octane and washer fluid injection A4 12.2 best ET, 12.3@119 best overall
    480whp/500wtq E55 AMG 11.6@120
    CTS-V 9.6@148
    Oct 08 2007
    Columbus, OH
    thanks alot!!
