Results 1 to 7 of 7
    Active Member Two Rings Magnus's Avatar
    Jun 29 2004
    Question Need to know tire pressure for 235-45-17 on Sedans
    Hello,
    I'm putting on my 17" winter tires today and can't find where I wrote down the recommended tire pressure. My pillar only has values for 18's. Anyone with stock 17's on a Quattro-equipped sedan know the recommended tire pressure?
    Thanks in advance for your replies!
    Registered Member Four Rings Noffy's Avatar
    Sep 06 2007
    Audi A4 2.0T, Forester 2.5xl
    Portland Oregon
    Re: Need to know tire pressure for 235-45-17 on Sedans
    Quote Originally Posted by Magnus View Post
    Hello,
    My P6 pirellis has a max psi of 44, they are stock all weather 235-45-17
    2005.5 A4 2.0Tq Quartz Grey
    Looking to purchase a euro car that I can learn to work on, and eventually take to the track for recreation days. What is a good car to start with?
    Veteran Member Three Rings barkerd427's Avatar
    Oct 04 2006
    2007 Audi A4 & a honda
    Princeton, NC
    There are different recommended pressures for each car and tire combination. The pressure on the tire is just the max pressure for the tire. You must take the car's recommended pressure as well to ensure proper wear, efficiency, and safety. However, since you probably wont be racing with the car you can usually just set around the 35psi standard or whatever you had it at before. It doesn't make as big of a difference in this situation. I am sure that others will disagree, but I doubt they have my fathers 60 years of automotive experience or the 10 years of experience which I possess. But to make it clear, proper inflation is very important, but 35 is fine for most sedans and there is a much greater leeway during the winter due to the fact that your speed will usually be less than during the summer.
    2007 A4 2.0T S-Line Quattro / Deep Sea Blue / Black Leather Interior / Nav / Heated front seats / Xenon head lamps / APR Snub Mount / RS4 Pedal Set / RS4 brushed aluminum grille / RS4 rear sway bar / RS4 parking brake handle / Xenon match interior lighting / SOON Custom fog light grilles with S6 LEDs and RS4 mesh and brushed aluminum trim, just need to find the trim
    Veteran Member Four Rings Phrost's Avatar
    Jan 24 2007
    1977 VW Type 2 Westfalia
    Wisconsin
    It should say in your manual or on your tire what the recommendations are. If you can't figure it out, a mid 30psi is always alright. I run about 32-33psi in the winter and damn near max (about 40psi) in the summer.
    I have dedicated tires for both seasons btw.
    Oct 18 2007
    Morris County, NJ
    I would say that those pressures above are both too low and too high. I have an 05.5 3.2 that came with the 235/45-17s. Recommended pressure is 35 psi. I normally run 36 front and 35 rear because of the added weight on the front axle. Note that it changes based on the passenger load.
    Jun 29 2004
    Quote Originally Posted by dmoney1282 View Post
    Thank you for finally answering my question!!!
    Registered Member Two Rings OceanBlueB7's Avatar
    Oct 15 2007
    Ocean Blue Pearl '06 A4 2.0TQT
    Boise, Idaho
    Quote Originally Posted by barkerd427 View Post
    What BarkerD said.
