Results 1 to 11 of 11
    Veteran Member Four Rings alexza4's Avatar
    Apr 23 2007
    19-S5||22-GV70||14-RAM1500Hemi
    brand new turbo has small shaft play?
    folks, does the brand new turbocharger supposed to have small shaft play (i'd say within a mm)? I just got the (brand new) replacement K04 from Kinetic and it has a small shaft play, called them up, spoke with Sean (nice guy, sounded knowledgable), he say it is perfectly normal and it will pretty much go away once the turbocharger is compressed with oil.
    not that i don't beleive the guy, i do, but i'm still worried, why is my k03 with 60+K on it has no shaft play at all?
    so put my mind at ease please!
    2019 S5 3.0T
    2016 A5 2.0T Cab
    2015 S5 3.0T - SOLD
    2003 A4 QM Uni EFR 6758 on meth - SOLD :((
    2003 A4 GIAC KO4 - SOLD
    Nov 14 2006
    600hp glorified Beetle, e-tron, 1G DSM
    Gig Harbor, WA
    Re: brand new turbo has small shaft play?
    All my girlfriend ever gets is small shaft play.
    -Darrick
    Feb 19 2007
    2001 BMW 540i M-sport
    Charleston, SC
    Yea, hes right.....there is no oil in the "galleries" so it is perectly normal for their to be MINIMAL shaft play
    -Sami-
    Nov 16 2007
    Texas
    You will have some side-to-side play no matter what, more if there isnt any oil in the journals. The play you dont want is axial (front-to-back play)
    Nov 13 2007
    02 A4 3.0QM, 84 Rabbit GTI
    Gaithersburg, MD
    Quote Originally Posted by PerformnceTurbo View Post
    Yup!
    Registered Member Three Rings Allwheel Driver's Avatar
    Sep 18 2006
    '02 A4 3.0 6sp, '02 A6 Avant
    Wanaque, NJ
    Quote Originally Posted by Capt. Obvious View Post
    HA!
    '02 A4 3.0Q 6speed, Sport Package, GIAC, Neuspeed SS
    S4 rear swaybar, USP Front Lip (DIY), S4 door blades
    '02 A6 3.0Q Avant Tip, H-sport swaybars, 18" S4 BBS CH wheels
    Jun 29 2007
    Raleigh, NC
    aww darrick has a little KP31 hahahaha
    really though... i actually laughed at that
    12.5 best ET -- 113 best trap
    The Awesome™
    BetaAlphaTau Member #42
    Apr 23 2007
    i actualy talked to Borg Warner support and they confirmed that there would be shaft play not to exceed .6 mm.
    2019 S5 3.0T
    2016 A5 2.0T Cab
    2015 S5 3.0T - SOLD
    Feb 19 2007
    Charleston, SC
    Are you sure about that??
    I have read elsewhere that is is actually vise-versa from what you stated....
    -Sami-
    Nov 13 2007
    Gaithersburg, MD
    It's normal for floating bearing type turbos, it may be different for ball bearing turbos. All floating bearing type turbos have some measurable side-side play in them which is more noticeable when there's no oil pressure in them. The pressurized oil on either side of the bearing is what takes up the play and keeps the bearing from failing. That's why even brief loss of oil pressure will kill a turbo.
    Apr 23 2007
    Yes. See my post above. Like i said Borg Worner confirmed.
    2019 S5 3.0T
    2016 A5 2.0T Cab
    2015 S5 3.0T - SOLD
