Results 1 to 12 of 12
    Dec 27 2006
    Radiator fan Not working!
    I've notice that my radiator fan is not turning anymore....
    Even when i turn on the heat or a/c (cold) the radiator fan does not turn on at all.
    On a longggg stop and go traffic, it would overheat!
    what should i look for? fan relay/switch? location? or is it a coolant temp sensor by the radiator?
    Dec 28 2006
    '13 A5, '24 Tiguan SEL R-Line
    Western Maryland
    Re: Radiator fan Not working!
    There is a sensor mounted in the lower radiator hose. That one is tied in to the fan relay.
    Registered Member Two Rings Fier Ringe's Avatar
    Sep 06 2007
    '98 A4 1.8TQ '96 Jetta 2.slow
    Denver
    2nd old guy, also the cooling fan control module fails sometimes. It is the silver box on the top side of the drivers side fan. If the fans don't come on when you turn on the a/c then I would say that the Cooling fan CM is your problem
    Dec 27 2006
    Silver box on the top side of the drivers side fan...., I saw that box, its had fins on it. Guess i'll replace that this weekend.
    Where is the relay located?
    Aug 26 2005
    Quote Originally Posted by jatnguyen View Post
    Check the relay first, it's in the ECU box, left end of plenum under the windshield.
    Dec 27 2006
    i called the dealership today and they want $251 for the fan control module...ehhh
    i'll check the relay tonight, hopefully its clear on the top of the relay so i can see if its still good or not!
    Dec 27 2006
    How do i check to see if the Relay's in the ecu box are working?
    Veteran Member Three Rings dpatel's Avatar
    Oct 03 2005
    Atlanta, GA
    Mine failed too... luckily I was under warranty at that time. Seems to be happening alot lately... they should recall that sucker.
    - 3.0 Quattro
    - Milltek Exhaust with 4" Tips
    - Hyperflow Intake
    - Caracter Front bumper
    - Eibach Pro Kit + Bilstein Sport Shocks and S4 Rear Sway
    - Sportec 18" wheels
    - Stoptech Slotted Rotors with Ceramic Pads
    - Level 10 VB & APR Snub Mount
    - G3 SuPeRcHaRgEr
    VP of 3.0 CLuB
    Veteran Member Three Rings Hamotee's Avatar
    Oct 30 2005
    Other German Stuff
    Athens,Ga. Clemson,Sc
    Did you check fuse number 4? It is a 5 amp fuse.
    How to account for this massive success? Pure luck? Transcendental meditation? Machiavellian manipulation? Aerodynamics? High colonics? We haven't the slightest idea. -P.L. Newman
    Senior Member Three Rings 1EightTAvant's Avatar
    Nov 08 2007
    03 A4 1.8TQAvant
    CO
    Are you chipped? I had the same problem and it had something to do with the software on my APR chip. They reflashed it and everything started working normally again
    Dec 27 2006
    not chipped, and there is no fuse on number 4.
    Is there a website online where i can purchase the "coolant fan control module"?????????????
    I dont feel like paying the dealership haha
    Dec 27 2006
    Replace the Coolant Fan Control MOdule today ($250), now the fan works.....=)
    Next is to install my t-bolt clamps so the piping for the fmic stop popping off
