Results 1 to 7 of 7
    Veteran Member Three Rings BONFIRE074's Avatar
    Aug 13 2007
    Hood/Headlight/Bumper Gap
    So i was noticing i have a gap on the drivers side of my car between the hood and the headlight and also a little bit between the bumper. Just wondering what is causing this, because the lines on the hood line up with the fender lines perfect. Here are some pics. You can see how the drivers side is off, and the passenger side is really close..
    ..dont mind the highway rock chips either
    2004 Subaru Impreza WRX
    Aspen White
    Veteran Member Four Rings AudiSport12's Avatar
    Feb 17 2006
    Coastal Georgia
    Re: Hood/Headlight/Bumper Gap
    could be a few things.
    has your car been in an accident before?
    maybe the mount on the bottom of the headlight has popped out?
    open the hood and check around...
    2011 B8 S4
    2003 Z71 Tahoe
    2000 B5 S4 - Sold
    2001 B5 1.8TQM F21L - Sold
    2000 B5 1.8TQM - RIP
    2000 C5 4.2Q - Sold
    1997 B5 1.8TQ - Sold
    Aug 13 2007
    Quote Originally Posted by AudiSport12 View Post
    Yes both tabs on both headlights are broken on the bottom. When i had the front end off i did notice a crack in a radiator support right where it bolts up on the passenger side but nothing too bad...the gap just seems too big to be something like the bottom tab
    Aspen White
    Veteran Member Four Rings Rosati's Avatar
    Nov 17 2004
    B5 Brilliant Black A4 1.8TQM
    Northern New Jersey
    I was messin around w/ the turbo setup and broke my Ecode headlight tabs, the HID beam jumps on bumps ,, does anyone know a fix? / alternate support point?
    * Gone but not forgotten - BTA4 GT28RS w/ all mods 400chp
    https://www.facebook.com/media/set/?...1463643&type=3
    Current: 1994 Mazda RX7 Chaste White
    DIY B5 Head Replacement Guide: http://www.audizine.com/forum/showth...al-and-Install
    Feb 17 2006
    Coastal Georgia
    ^ there is a tab repair kit on either ecs or purems i cannot remember which one
    2011 B8 S4
    2003 Z71 Tahoe
    2000 B5 S4 - Sold
    2000 C5 4.2Q - Sold
    Veteran Member Four Rings Burntaudi's Avatar
    Sold:1997 Audi A4
    Maplewood, Minnesota
    ^^^You can get the tab repair kit at the dealer. It's a OEM part number.^^^
    Alex
    Sold 97 Audi A4 Turbo Quattro Manual
    KO4/GIAC PC-16/GHL Exhaust/EVO FMIC/ Southbend Clutch/JHM Short Shifter & Linkage/Shifter Bushing/Koni Coilovers/Neuspeed Sways/17" OZ Superellegras/Ecode Headlights/VVME Hids
    Current ride 03 Tahoe Z71
    Aug 13 2007
    Quote Originally Posted by Burntaudi View Post
    I dont want to get a tab repair kit because i will eventually be putting in 1 piece headlights, but wanted to know if once i put the 1 piece headlights in, if there will still be that gap
    Aspen White
