Page 69 of 70 FirstFirst ... 195967686970 LastLast
Results 2,721 to 2,760 of 2784
  1. #2721
    Sep 06 2017
    05 Subaru LGT (HTA71)
    MA
    Thank you for the leather info!
    Yeah my plan is to change pads once these wear down to needing replacement. Can't justify it until they're ready to go. I won't be cleaning the wheels so frequently to drive me crazy but I'll be doing it more than I currently have (almost never haha)
    > S4 Swapped B8 Avant <
    > 2015 Glacier White allroad P+ (RIP) <
  2. #2722
    Oct 10 2012
    Hamilton / Ontario
    Quote Originally Posted by DetailersDomain View Post
    we like to use the leather master kit to maintain these type of seats. the key is to use and apply product on applicators pads and towels first. massage the product into the pad so that it does not leave product on the stitching so much just enough where it doesnt get all over.
    - - - Updated - - -
    Update:
    Sonax Spray and Seal being used to maintain a ceramic coated vehicle.
    Using Sonax Spray and Seal for maintenance on a coated Lamborghini Huracan
    This Lamborghini Huracan was coated about 6 months ago with a ceramic coating, we wanted to test out the ability of the Sonax Spray and Seal and the effects of it over the coating. We are happy to report that it worked extremely well. Sonax Spray and Seal was compatible and showed no issues or side effects with the ceramic coating. We would recommend it as a maintenance product over your cars protected with ceramic coating.
    Hey Phil, great video!
    This Sonax spray and seal.....I noticed you never had to wipe it on than buff off. Is that true or was that just a fancy video edit?
    Would you recommend the Somax Spray and Seal as a quick detailer or just after a wash?
    What is a safe quick detailer that can be used over a ceramic coating that you’d recommend?
    Thanks in advance!
  3. #2723
    Stage 3 Forum Advertiser Four Rings DetailersDomain's Avatar
    Feb 23 2004
    Quote Originally Posted by NJA-TRTL View Post
    Thanks in advance!
    You would still need to dry the car completely. So yes when you check out the video there are drying towels to buff off the rest of the left over Spray and Seal
  4. #2724
    Sep 06 2017
    MA
    This one might be a better question for you versus the simple ones I can probably look up:
    A rubber shoe sole scuffed my paint. It looks like it transferred some black rubber to the paint or scuffed it like a black rubber sole would scuff a basketball court.
    Best recommendation for cleaning that up?
  5. #2725
    Feb 23 2004
    A good light polish or clay bar should work
  6. #2726
    Veteran Member Three Rings s4nicetry's Avatar
    Nov 29 2007
    Calgary / Vancouver
    I have a white car with visible fallout showing all over the body panels. On the lower doors / rocker panels, there is PPF that also has fallout on it. Can I use fallout remover on the PPF without damaging it? Or should I be using clay bar or something?
  7. #2727
    Feb 23 2004
    yes you can use the fall out remover on ppf just make sure it is removed completely.
  8. #2728
    Feb 02 2017
    Beaverton, OR
    Now that my summer wheels are off I want to see if I can get stains off the Rotors - I have similiar stains like these mentioned in this post - https://www.audizine.com/forum/showt...ains-on-wheels
    What Pads /wax might one recommend to use on my Griots Garage 6 Inch Random Orbital Polisher which I run this with 5" plate?
  9. #2729
    Feb 23 2004
    by rotors you mean your factory 5 spokes? if so then yes you might want to try to polish or if needed compound then polish them out....curious what wheel cleaner are you using it looks like they have already been damaged a bit from either a wheel cleaner or lack of care.
  10. #2730
    Feb 02 2017
    Beaverton, OR
    Yes - those are not mine but mine look similiar. Came like that when I bought my car. What pads/compound would you recommend to start with?
  11. #2731
    Feb 23 2004
    Quote Originally Posted by chip_ View Post
    before that what did you already try..
  12. #2732
    Feb 02 2017
    Beaverton, OR
    Mothers mag polish, Meguiars compound by hand with no luck.
  13. #2733
    Dec 21 2018
    WarnerJedXL
    Panama
    Ask Detailers Domain
    Question regarding wheel wax on polished lips with clear coat centers.
    I have a set of ccw wheels with polished lip and clear coat centers and want to protect them during the winter rainy/snowy months.. Is there a wax that can be used on polished lips? Also what about the center clear coat?
    Thanks
  14. #2734
    Feb 23 2004
    Quote Originally Posted by WarnerJed View Post
    Thanks
    it may need to be refinished.
  15. #2735
    Oct 10 2018
    DC Metro AreA
    Hello. My brake calipers were factory painted black, but now they are 'ashy' looking...almost gray. I'm not sure how the first owner maintained them, but it looks like they may have left some wheel cleaner on for too long. Is there a way I can restore the color and sheen of the calipers without having them repainted? Thanks!
  16. #2736
    Feb 23 2004
    Quote Originally Posted by mdjdc View Post
    got a photo
  17. #2737
    Veteran Member Four Rings JBAeroEngineer's Avatar
    Sep 19 2012
    Capitol Area
    Best way to remove that weird film/residue on the windshield leftover from wax, rainx, etc? I've read dish soap, isopropyl alcohol, water/vinegar mix, DA/m105, etc.
    2018 A4 | Mythos | Prestige | S
  18. #2738
  19. #2739
    Sep 19 2012
    Capitol Area
    got a photo?
    I'll try to grab one at night
  20. #2740
    Sep 19 2012
    Capitol Area
    got a photo?
    Here you go
  21. #2741
    Established Member Two Rings Blueiris's Avatar
    Aug 13 2018
    B8.5 S4, B8 Q5, Honda Snow Blower, Craftsman Lawnmower...
    Boston/MA
    I am planning to have a ceramic coating applied to my car by a detail shop. I have narrowed it down to 2 options: Opti-Coat pro Plus ($1,400) or Ceramic Pro 9H ($1,200). My car is a a white B8.5 S4 and the paint is in pretty good condition, some small swirl marks here and there. I am looking to have the car feel smooth and waxy for the longest period of time with a deep shine. Which option should i go with?
    2015 S4 Prem+ Black Optics
  22. #2742
    Veteran Member Four Rings Crucible35's Avatar
    Apr 22 2010
    13 Lawnmower Prem. Quattro
    Markham, Ontario. Canada
    Hey Phil,
    Quick question that I;m sure has been asked before but couldn't find any answers when I searched. I have a fair amount of polishes (1Z Polish Wax, Menzerna Super Finish etc.) and waxes (Collonite 845, Jescar PowerLock) that I haven't even opened and haven't had a chance to use. What's the shelf life on this stuff? Is 5 year old Polish wax and others still OK to use if it's unopened? If it's been opened I would assume it will dry out and be unusable. What's the rule of thumb?
    '15 A4 S Line Q Tip Monsoon
    '09 A4 Premium Q Tip Meteor (Gone)
  23. #2743
    Mar 05 2012
    Sidney, ME
    Quote Originally Posted by Blueiris View Post
    go with the 1 that will give you the longest protection for the price. The better you maintain it the longer and better it will perform.
  24. #2744
    Veteran Member Four Rings MugelloB7RS4's Avatar
    Feb 06 2015
    Quick question. I have Menzerna 3in1 which says it includes a wax. I'd like to top it with Power Lock plus, however I'm not sure if I should be wiping down the 3in1 with IPA or eraser before the Power lock.
    And if I should be, does that negate the reason for using the 3in1 and maybe I should use something else.
    Thanks
  25. #2745
    Veteran Member Three Rings goalieman24's Avatar
    Mar 29 2011
    Quote Originally Posted by MugelloB7RS4 View Post
    Thanks
    The protection part of the 3in1 is a carnauba wax, which you'd generally want over a sealant... not under.
  26. #2746
    Feb 06 2015
    Quote Originally Posted by goalieman24 View Post
    I know, that was my thinking too......back to the drawing board
  27. #2747
    Apr 22 2010
    A few years ago I had the same question for Phil. I had 1Z polish wax (2 in 1) that I wanted to try but wanted to apply Power Lock over top. Phil gave the same response that you should really put a wax over a sealant, but said to give it a go and see what happens. I did. I think there was only a minimal amount of wax left from the polish and when I put the Power lock over it, it had an amazing mirror gloss that I wasn't expecting. Additionally, this amazing finish lasted for a very long time.....easily 6-8 months, I didn't have to touch it other than a rinse. It worked out really well. Your results may vary.
  28. #2748
    Feb 06 2015
    Quote Originally Posted by Crucible35 View Post
    Very interesting and good info. We have two vehicles. One an Audi and one a Jeep. I might try the traditional (polish, seal, wax) on the Audi and try the 3in1 topped with power lock plus on the Jeep. Not a super fair apples to apples comparison, but would be interesting to try.
    Thanks for the info.
  29. #2749
    Feb 23 2004
    Sure you can go over the 3 in 1 with Power Lock. The wax part of the 3 in 1 won't last too long. If you wipe down with IPA plan on the wax to have less protection as you will be taking some if not all of it off.
  30. #2750
    Feb 06 2015
    Would you suggest doing an IPA wipe? or layering? My thoughts were that because one is a Menzerna product and the other is a very close relative of a Menzera product that they might play nice together.
  31. #2751
    Feb 23 2004
    the protective component of the 3 in 1 is less durable than the Power Lock, if you do an ipa it will probably remove some of the protection. The power lock will last longer than the wax, so if the wax is the base layer and it will be less durable you may not achieve what you are looking for which if I'm reading this correct is what you are looking for.
    you may want to polish than seal than wax
  32. #2752
    Feb 23 2004
    Quote Originally Posted by subaruski View Post
    I have a 2019 Quantum grey SQ5 that got fairly scratched when I was removing the rear badging. Using the Torx10fx I tried Chemical Guys VSS + white hex pad and it swirled the entire area so bad. I followed up and tried V36 orange hex + V38 white hex and that failed to really provide any correction.
    This is my first time doing paint correct and polishing. Was I not applying enough pressure perhaps? Any suggestions would be helpful at this point.
    can you post the photos of the current situation
  33. #2753
    Feb 06 2015
    I agree, I think I will have better luck with a polish and then seal.
    Thank you for the response and the advice. Greatly appreciated.
  34. #2754
    Feb 23 2004
    no problem at all.
  35. #2755
  36. #2756
    Junior Member Two Rings
    Nov 16 2019
    Boston
    hey phil,
    was hoping you might be able to recommend a product for the interior plastics/dash. i've been using finish kare's 180 top kote anti-static pro for about a decade. i like the controlled/matte shine and anti-static properties. anything new worth trying?
  37. #2757
    Feb 23 2004
    Quote Originally Posted by olazy View Post
    hey phil,
    here are two good ones, in fact great ones!
    Nanolex Interior Cleaner
    Nextzett Cockpit Premium
  38. #2758
    Feb 23 2004
    This is our 1st Mystery Box of 2020 - #22!
    Exclusives from Sonax, Aenso, Fictech, Nanolex, Rupes, MTM, Jescar and More!
    Please Note:
    - Boxes will start shipping on 6.23.20
    - Delivery times please expect 48-72 hours before you receive your tracking number.
    Detailer's Domain's Mystery Box
    Get $50.00 + worth of products for $34.99!
    FREE SHIPPING on orders over $99.00
    Not eligible for discounts
    When you receive the mystery box hashtag #DDMysteryBox and post it up on Facebook, DetailingBliss, and Instagram!
    Limited Quantities
    READ MORE
    All boxes will contain never before shipped items.....
    • Here are the possible "BIG" ones
      Exclusive 6 Sonax Kits - Valued over $400!
      1 Metro Air Force Blaster - Valued at $259.99!
      Exclusive 4 Complete lines of Aenso Car Care - Valued over $200!
      Exclusive 2 Complete lines of Jescar - Valued over $200!
      1 ScanGrip MMR Kit - Valued at $329
      2 ScanGrip SunMatch3 Valued at $149!
      3 MTM Hydro PF22.2 Foam Cannon Valued at $89.99
    BUY NOW
  39. #2759
    Veteran Member Three Rings Nogaro Nitwit's Avatar
    Sep 13 2010
    2000 S4, 2005 allroad 2.7t, 2004 allroad 4.2
    Sterling, VA
    Any tips or tricks to getting dog claw marks off the dash off my 2005 allroad?
    2000 S4 - ASP Stage 3, ER ICs, ASP DPs, ASP True Dual Exhaust, 710Ns, Neuspeed 19mm swaybar, ASP phenolic spacers and many more goodies
    2005 allroad 2.7t - 6mt conversion, Daz Stage 2 tune, S6 seats/headliner, Podi boost gauge w/ custom pod, Arnott Gen IIs, H-sport swaybars, Magnaflow exhaust, 19"x9.5" Miro 111's, Euro roof rails, OEM spoiler, LED Tails
    2004 allroad 4.2 - APR tune, OEM spoiler, H-sport swaybars, OEM hitch, BFG K02 all-terrain tires, Yakima roof basket
  40. #2760
    Feb 23 2004
    if it's scratched it will need to be fixed/restored with an upholstery repair shop. products will only hide it but it will come back.
