Results 1 to 11 of 11
    Veteran Member Three Rings iwearpro's Avatar
    Jul 28 2007
    Forsyth Illinois
    Winter grille cover? Anyone make one?
    Curious if anyone makes it for the b5 at all or know where I can get one....I have used them in the past and like how fast the car warms up to temp..Please dont comment or flame me for wanting one,only if you know where to get one..
    Thanks in advance..
    Veteran Member Three Rings 2001A4QUATTRO's Avatar
    Jun 05 2007
    2001.5 A4 1.8TQMS
    Re: Winter grille cover? Anyone make one?
    Use cardboard to cover it from the inside. Attach with black zipties...
    Engine : Carbonio V2 Intake - RAI 3" TP - APR cat-back w/glass pack - APR TIP - Forge 007P - 00Black1.8T Heat shield - GIAC-X - APR Snub mount - RS4 motor mounts - SB Stage 4 w/DMFW - 034 Street trans mounts - Evolution Motorsports Phenolic spacer
    Braking : Centric Cryo Black Zinc / Hawk HPS (F+R)
    Exterior : Ultrasport 18" ET43 235/40/18 - RS4 grill - Debadged - S4 sideskirts and rear lip - E-codes/Philips+ HID
    Interior : AWE boost guage / vent
    Veteran Member Four Rings seank's Avatar
    Nov 14 2006
    here
    ^exactly. why would you buy something you could easily produce yourself?
    Mar 09 2004
    99.5 A4 Avant, 01 allroad
    nw michigan.
    Doesn't the thermostat bypass the radiator until up to temp?
    Jim
    I Do Werk.
    Veteran Member Three Rings generik777's Avatar
    May 12 2007
    1998.5 A4 2.8 Quattro Tip
    MN
    Quote Originally Posted by onemoremile View Post
    Even so, It should still warm up quicker without all that cold air blowing in on it. And I give a thumbs up to making one out of cardboard. I think it would look better.
    Jul 28 2007
    Forsyth Illinois
    My problem is when moving it cools down to the point where I notice it,not cold but not steam me out hot either..I like the idea of it being to hot and then having the option to cool it down...Here in the midwest when it freezes rain and is so thick,its nice to have the extra heat...Know what I mean vern.;)
    Mar 09 2004
    nw michigan.
    I live in West Michigan and our weather is much worse than Illinois. My wife is from Chicago and couldn't believe her first winter here. The nasty weather coming off the lake is crazy. I've never had any issues with heat. My mother in law lives just over a mile away and I get some heat in the 5 minutes it takes to get there. It takes about 2 minutes for the seat heater to get nice and toasty and a couple minutes later I've got real heat. I'd say it might be the V6 but I also had an S4 that was warm within a few minutes. Good thing too since that car was a cranky bitch on a cold morning.
    On long frozen freeway trips my heat is still hot. If I set it to HI and put the fan in the middle I can't hold the back of my hand to the vent for long. Same with the S4. I've always been impressed with the heaters in these cars. That is, except for the heater core that needs replacing in the A4.
    Jim
    I Do Werk.
    Veteran Member Four Rings 4ringAR's Avatar
    Sep 18 2006
    Colorado
    pardon my ignorance, but from what i can gather you guys are talking about these:
    http://www.ultimateautoaccessories.c.../PROD/EA/26085
    which blocks off our CAI, doesnt our car need some air to run? i realize the engine isnt totally sealed, but it does need some fresh air, no?
    2001 Audi ur-allroad, Frankenturbo'd, 6-Speed Convert: BUILD THREAD
    "Forget Tibet, free the left lane."
    Registered Member Three Rings
    Sep 30 2007
    has too much crap to fit a car
    Upstate, NY
    Just slide a piece of cardboard between the radiator and AC condenser. Not covering the whole radiator though. Works great and you'll never see it.
    Jul 28 2007
    Forsyth Illinois
    Quote Originally Posted by 4Ring_Jelly View Post
    The car will pull air from around the bottom of the car and through cracks and crevis,that this time of the car will run just fine.
    Veteran Member Four Rings SoFresh's Avatar
    Mar 15 2006
    Seduction Motorsports 1955 Porsche 550 Spyder, Porsche 356 Coupe
    Scottsdale - Palm Springs
    I used to drive my car in -20 degree weather... never had any issues with it warming up, I was more worried about when the inside of the windoes would freeze up as well as the outside because of the condensation inside the car, lol.
    Production Manager - Gunther Werks
    Founder - Seduction Motorsports
