Results 1 to 29 of 29
    Established Member Two Rings stylesx's Avatar
    Aug 09 2007
    Sick Bicycle
    Oakville
    Gas Consumption for A4 3.2
    Im a bit concerned with the numbers im getting here. First off im located in Canada so i will be speaking Liters and CDN dollars, which may i add is higher then the American $$ :)
    So here is my problem, I own a 2007 A4 3.2 with about 3500km on it already and a fill up costs me around $57 BUT ONLY lasts me 350km !!!!! i think that is crazy !!!
    So im hoping that there is some sort of computer self adjusting feature that might let the car run rich now for the break in period and then level off some time.
    Let me add that im not an aggressive driver at all, so can someone please provide some input on this please.
    Thank you
    Jul 29 2007
    b7 3.2
    Re: Gas Consumption for A4 3.2
    Im filling up at about $50usd, usually around $45 but the prices just went up.
    Getting anywhere from 300-320 miles per tank, and I'm at just over 3000 miles on the car.
    What that means in liters and km, I don't know and won't ever.
    Aug 09 2007
    Sick Bicycle
    Oakville
    Quote Originally Posted by typerlover View Post
    320 miles = 514.99008 kilometers
    Thanks respectable, is yours a 3.2 also ?
    Jun 05 2007
    Syracuse, NY
    it gets better after about 10k miles
    Aug 09 2007
    Sick Bicycle
    Oakville
    WOW thats quite a bit afterwards :)
    Oct 18 2007
    Morris County, NJ
    I have an 05.5, 3.2 Quattro with approximately 22,500 miles. My mileage numbers have been pretty good. I usually get anywhere from 280-340 miles on a tank of gas, with about 40% highway 60% city. And that mileage is using about 13.6 gallons. The tank is 16.6 gallons I believe. I've gotten over 370 miles when my driving is more highway biased.
    I got the car CPO so I don't know how the mileage was when it was new. However, usually the gas mileage will start to get better after the engine breaks in. Probably after 3k-5k I would think. Also, thats expensive gas. For those 13.6 gallons I referenced above, it cost me about $38 for premium.
    Have you checked your tire pressure? That will have a big impact on your MPG
    Sep 29 2006
    Westwood/West Los Angeles
    My car has a very large system in the back, I get about 260 miles to the full tank on my 3.2, I'm a very calm driver, but Los Angeles is stop and go traffic.
    Veteran Member Three Rings barkerd427's Avatar
    Oct 04 2006
    2007 Audi A4 & a honda
    Princeton, NC
    OP, you have to take into account what type of driving you do and the length of your trips and the time it takes for your car to warm up. As an American living in Europe I am well versed in Metric and English conversions and you are hardly getting any MPG, but you are paying a lot less than I am per tank. If you are doing a lot of stop and go driving with very limited distances traveling at about 55 MPH then you will have very low KPL or MPG. Also, it is probably cold there like it is here and mine is lowered by about 5 MPG per the computer. If any of this helps or you need more info just post it up. I have put 30,000 miles on my car in the first year, so I have quite a bit of experience with it and it's tendencies. I usually play a game while I am driving where I am always trying to get the best MPG I can get. Mine is a 2.0 and not a 3.2, but same concept.
    2007 A4 2.0T S-Line Quattro / Deep Sea Blue / Black Leather Interior / Nav / Heated front seats / Xenon head lamps / APR Snub Mount / RS4 Pedal Set / RS4 brushed aluminum grille / RS4 rear sway bar / RS4 parking brake handle / Xenon match interior lighting / SOON Custom fog light grilles with S6 LEDs and RS4 mesh and brushed aluminum trim, just need to find the trim
    Registered Member Two Rings OceanBlueB7's Avatar
    Oct 15 2007
    Ocean Blue Pearl '06 A4 2.0TQT
    Boise, Idaho
    I have noticed a CONSIDERABLE difference in my mileage depending on driving style(i.e. aggressive vs. mild) and gauge my gasoline bill expectations accordingly.
    Aug 09 2007
    Sick Bicycle
    Oakville
    Just an updated on this, I am at 8,000km now and am still getting MAX 460km on a full tank
    Active Member Two Rings JCleary's Avatar
    Feb 26 2007
    '07 A4 Avant
    Menlo Park, CA
    Why does everyone talk about miles per tank? Does nobody know how to calculate miles per gallon or km per liter??? Weird.
    On the diesel sites it's all about hand-calculating miles per gallon. My gas-hog 2.0 averages 21mpg. I've had tanks as low as 17mpg, and one tank rang in at 28mpg.
    And another thing- The trip computer should be called a Lie-o-Meter! It's 2-3mpg optimistic at any given time.
    I've read you can adjust with a Vag-Com, but I have not bothered.
    If I knew the mileage on the 2.0T was going to be this bad, I would have gotten a 3.2!
    Established Member Two Rings MojaveA4's Avatar
    Nov 15 2007
    2008 Corvette
    Temecula, CA
    My 2.0 mileage is REALLY dependent on my driving style. If I take it real easy then I get 450 miles a tank and if I have fun, 320 miles a tank. Obviously, the fun factor drops a lot for the good gas mileage which is why I rarely can pull off 450 unless I make it a game.
    Veteran Member Four Rings Slo.Mo.Shun.'s Avatar
    Oct 14 2006
    MK6 Jetta
    South,FL
    Quote Originally Posted by JCleary View Post
    It all depends on your driving style, sometimes I hardly get 320 miles per tank, sometimes 450-500, and my personal best 632.
    -Unitronics Stage 2+ ECU/TCU tune.
    -EI AL CAI.
    -Driver Mod.
    Veteran Member Four Rings a4dc89's Avatar
    Nov 07 2007
    Land Rover Disco I
    Washington DC
    Quote Originally Posted by HID View Post
    WOW 632 is out of this world!! The best ive gotten is around 420 or so. Perhaps FWD makes a bigger difference than i thought
    2006 A4 B7 2.0TQ Dolphin Gray Metallic 6MT
    REVO Stage II, 034 HFC, AEM turbo inlet/intake, OEM Piston DV, BSH PCV Fix, HID Fogs/Fog Mod, AWE Boost Gauge, Debadge
    All go no show
    Oct 14 2006
    MK6 Jetta
    South,FL
    FWD cars have a bigger gas tank too and run lower rpms at cruising speeds
    -EI AL CAI.
    -Driver Mod.
    Active Member Four Rings 3.2some's Avatar
    Dec 19 2007
    ..is full of crap I dont need
    Escondido, CA
    I get around 300 miles a tank but I drive my car like I stole it AND my daily commute is 60 miles a day. I've got 30K on the odometer.
    V/R -Phil
    B7 2006 Audi A4 3.2L Tip FWD Brilliant Black
    Senior Member Two Rings Widget's Avatar
    May 22 2007
    '06 A4 S-line, 2.0TQMT - Moro
    New England....
    So your saying there is a different gear ratio for 2wd vs. Quattro?
    Veteran Member Four Rings Sanjman's Avatar
    Nov 16 2006
    nothing else special
    Skokie, IL
    Why this thread is useless:
    1) Already talked about how it is pointless to compare.
    2) People have different tanks depending on Quattro and FWD.
    3) People weigh differently.
    4) People driving differently.
    5) People use different types of gas not to mention different octane ratings and different amount of additives.
    6) People live in different altitudes, weather conditions, humidity, and temperatures.
    7) People have different modifications to their car.
    8) People have either Quattro or FWD which also means different weight, distribution, and different transmissions (quattro: 6 speed versus FWD: CVT)
    9) People have different transmissions: auto and manual.
    10)the MuthaF*** list goes on... and on.
    If you think something's wrong... take it back... but it's obvious that your car's mileage has or is improving...
    Jun 05 2007
    Phillips Ranch, CA
    ^ wow a mutha F***** pessimist
    everything u ever post is negative. how about not posting at all.
    if noobs or the gerneal public want to answer each other post. so be it, MR. NEGATIVE
    Nov 16 2006
    Skokie, IL
    Quote Originally Posted by acidrome View Post
    point being is that he's not going to get a good answer because no one really knows... and all the answers he'll receive can't even be compared to that person's car unless if if they have AT LEAST the same exact car with the same exact features... but I am pretty mean in other threads where it's a repost... I don't consider this a repost exactly... so I wasn't exactly yelling... on this thread.
    Oct 04 2006
    Princeton, NC
    stylesx - What kind of driving do you do? ex. How far do you usually drive, how fast, stop and go or highway...
    Nov 01 2007
    B7 A4 2.0TQT
    PA
    my 2.0T costs $50 to fill up on premium (93)
    Feb 26 2007
    '07 A4 Avant
    Menlo Park, CA
    Quote Originally Posted by Sanjman View Post
    It would not be useless if miles per gallon (or liters per 100km if you're metric)were used instead of miles per tank. Just shows either the overall lazyness of the posters in this forum or their inability to do simple math...
    Aug 09 2007
    Sick Bicycle
    Oakville
    hahahahaa Angry :) .....jokes
    BTW the thread is not useless as its helping me realize that there is no problem with my car and that the consumption is normal :)
    Also you are perfectly right that you can only compare apples to apples and i don't expect to get answers from an A4 2.0 owner as the title specifically states my engine and since its a 3.2 then that right off the bat states a quattro.
    Thank you
    Awaiting Confirmation Four Rings
    Feb 29 2008
    2006 A4 2.0T Quattro, Dolphin
    San Francisco Bay Area
    Just to give styles a bit of a rest, I am going to include the following factors in my comment: weather, altitude, driving style, car model & specs, etc:
    - Quattro tank
    - I weigh 185 lb.....no f'ing clue what that is in kg's.....
    - I drive pretty hard most of the time, I have a tip trans and hate regular Drive w/ a passion.
    - 91 oct. Shell V-Power: not far from $50 U.S. to fill 2/3 of the way @ $3.79 per gallon w/ 7.125% tax in CA
    - Drove from San Fran Bay Area to Squaw Valley, Lake Tahoe and back on one tank; go from + 50 ft altitude to 6,200 ft, going from relatively humid to dry, Bay Area: +/- 65 degrees F and Tahoe +/- 45 degrees F.
    - Stock 2.0T A4 Quattro Sport
    - Auto/Tip trans
    - **muthaF'ing things to make the list go on and on**
    I left from Corte Madera, CA, went to Squaw Valley, CA (while up there took one trip up to Tahoe City and back while up there), and made it back all on one tank.
    Total distance: 406.9 miles
    Average Speed: +/- 65 mph
    MPG: 406.9 / 16.4 gal (full Quattro 2.0T tank) = 24.81 MPG
    Considering a good deal of that driving was spent climbing 6,000 vertical feet thru thinner air, I think this is killer mileage compared to my old car (v6 Nissan Maxima), which was almost done with its tank by the time you get to Tahoe, let alone enough to get you back down the mountain or all the way back home.
    Hey, at least I'm tryin'!
    Aug 09 2007
    Sick Bicycle
    Oakville
    Good info but I wouldn't expect the 2.0T to perform like the 3.2L, but good info for whoever owns a 2.0T and wants to know consumption
    Feb 29 2008
    Yea, me either; the 4-banger should do a little better with the 6-speed than a V6. I'm a big fan of shifting with the TIP, cuz I think Drive tends to put the car in too low a gear and spends more gas shifting down to 5th when I'm going 35; sounds like it's intentionally trying to break the tranny so I can spend a few grand fixing it.........you can't fool me, Audi!
    But yes, its a good gauge for someone wanting to know 2.0T consumption; I, for one, was pleasantly surprised!
    Aug 09 2007
    Sick Bicycle
    Oakville
    Anyone want to trade their 2.0T with my 3.2 :) ahhah
    Veteran Member Four Rings Tgr_Clw's Avatar
    Jul 20 2005
    2003 Audi A4 1.8TQM
    Toronto, Canada
    Note that colder temperatures equal to crappy fuel economy. Wait until is gets a bit warmer and check then.
    Appearance: OEM+
    Interior: B6 S4 Recaro Seats
    Performance: MTM Stage 3 / Milltek Exhaust+Milltek HFC / JJ TIP / ASP FMIC / SB FE SS
    Suspension: Vogtland Coilovers / HSport S4 Sways
    Braking: Stoptech 332 BBK
    Wheels/Tires: BBS CH 18x8.5, ET35 / GY Eagle F1 GSD3 235/40/18
