Results 1 to 36 of 36
    Senior Member Three Rings jmicko's Avatar
    Nov 15 2005
    2006 A4 2.0t Quattro 6spd
    North Haven, CT
    Rough idle, RPM's bounce up and down, and dropping real low....
    Will a torn DV cause this problem?? Or does a torn DV just affect holding boost?? I'm guessing rough idle and rpms jumping up and down would be the cause if a bad PCV??
    I'm still spiking 19psi and holding around 16 or 17, so i'm thinking my DV is fine??
    Thanks
    2006 A4 2.0T Quattro 6spd
    Imola Yellow
    Premium
    Lighting
    Technology
    Cold Weather
    Navigation
    Sport Suspension
    APR - Stock, 93, Race
    APR Test Pipe, AWE Exhaust, APR Snub Mount, RS4 Rear Swaybar, Bilstein PSS9 Coils
    Nov 14 2006
    Re: Rough idle, RPM's bounce up and down, and dropping real low....
    Quote Originally Posted by jmicko View Post
    Thanks
    Mine is doing the same thing - it's at the dealership for 2 days already.
    I will know tomorrow what exactly they replaced =(
    My car is stock, 1.5 years old w/20k miles on it... a bit too early for problems ?
    Nov 15 2005
    North Haven, CT
    Quote Originally Posted by igorek82 View Post
    Like i can be sitting at a light and the RPM's will jump up to about 1,500 and then drop back down to normal idle. Or if i'm coming to a stop and i puch the clutch in, the RPM's will drop down to like 400, and kinda sputter, and then go back up to normal idle....The car NEVER stalls though..
    Imola Yellow
    Premium
    Lighting
    Technology
    Cold Weather
    Navigation
    Sport Suspension
    Veteran Member Four Rings INTEGRATION's Avatar
    2006 A4 2.0T Quattro 6MT
    AWD_4TW
    PVC Valve? MAF sensor, TPS sensor? Usually one of those things, or at a worse case scenario...something internally may be blown.
    2006 Audi A4 2.0T Quattro 6MT S-line
    Nov 14 2006
    Identical symptoms. Will let you know tomorrow.
    Aug 20 2007
    2006 Audi A4 2.0T Tip'
    Fitchburg, MA
    I get the same thing cept it's while driving. The rpms go up and down but the car never jerks while i maintain constant speed.
    Veteran Member Four Rings Dangler's Avatar
    PA
    i had a similar problem when i went to install my forge dv....the vaccum line that went to the tap off the intake manifold, came off...and there was a vac leak at that point...
    maybe a vac leak somewhere in the miles of stupid piping under our hoods
    F.T.W.L.T.B.D.W.I.C.T.W
    Senior Member Three Rings studlee's Avatar
    2009 Dodge Ram
    Earth
    wow...lots of us are having the same problem.
    i noticed this a few weeks ago...and now when i floor it in all gears i get a whistling noise...where as it would only whistle in 1st and 2nd.
    let us know for those of you who recently went to the dealer.
    Veteran Member Three Rings 07audi4's Avatar
    Dec 06 2006
    2007 audi a4 2.0T quattro
    rochester, new york
    Quote Originally Posted by studlee View Post
    Sounds like you have a torn diverter valve.
    2007 AWE Tuning Audi A4 2.0T Quattro
    APR Stock 91 93 Race / Evolution Motorsports Intake / AWE Tuning Front Mount Intercooler / AWE Tuning Downpipe Back Exhaust / Neuspeed Race Springs / H&R S4 Front And Rear Sway Bars / Fog Light Mod / 10% Tint With Custom Audi Emblems In Rear Windows
    Registered Member Four Rings 4-tified's Avatar
    Sep 18 2006
    A4 2.0T Quattro
    Chicago
    Whistling noise is a pretty good indicator or vacuum leak, or a hose leaking somewhere, either torn or pulled off.
    Idle the engine and have a friend give throttle on off and listen for where it may be coming from. It might be as simple as the poster who just had to put the hose back on.
    If not, then it'll need diagnostic.
    I had a different car quite a few years back that developed an intake manifold gasket leak and the idle wouldn't calm down.
    My buddy and I tracked it down with some propane gas and rubber hose.
    We gave light gas from the hose and moved it around the intake parts until the idle changed. At the intake gasket, when the propane went through the gasket the idle went up. The gasket was bad on a relatively low mileage car (under 50k). It was a turbo 2.0 Mits engine.
    Nov 14 2006
    I hate the dealerships in NYC....
    The car has been there since the beginning of the week and it's still not fixed =(
    They also did not have any loaner cars since the wait time is 5 weeks to get a loaner.....
    Hopefully will know tom.
    Nov 14 2006
    The following part numbers were replaced
    06F-129-101-E VALVE
    06F-103-483-E GASKET
    My service adviser wasn't available during the pickup so I have no idea what kind of valve this is.... May be someone can identify them from part numbers... The car is fixed and seems to perform as well as before. Hope this helps.
    Registered Member Two Rings trojans1981's Avatar
    Sep 27 2007
    05 S2000,06 A4 2.0T,06 A8 W12
    Santa Ana,California
    wow five week time frame for a loaner car....glad I don't live out there. My dealership gives me a loaner anytime they will be needing my car for more than one day. I love my dealership.
    Nov 15 2005
    North Haven, CT
    06F-129-101-E VALVE
    Just checked ETKA, those are the part #'s for the PCV valve...How's the car runnin now?? back to normal?
    Imola Yellow
    Premium
    Lighting
    Technology
    Cold Weather
    Navigation
    Sport Suspension
    Nov 14 2006
    Yes, back to normal.
    Senior Member Three Rings FlyPenFly's Avatar
    Oct 29 2007
    Australian Shepherd
    San Diego, CA
    Was it the PCV valve for everyone else?
    Senior Member Three Rings ravenmadx's Avatar
    Jan 26 2007
    07' White A4 Sline 2.0T
    Germany
    mine did the same thing and it was water in the fuel. the dealer here in Germany put a hose down my tank then tested the fuel and found water. I just refilled my tank with fuel that morning and started to get the problem.
    Veteran Member Three Rings jojogoya88's Avatar
    Jan 02 2007
    new york LI
    i have the forge DV and BOV, and i get the same thing......what should i do?
    E90 M3!!! Interlagos
    Audi A4 B7 6spd S-Line Titanium Pk. SOLD
    Sep 15 2005
    Norwalk, CA
    i have stable idle, no flapping sound, but do have whistling sound in first or second when i run it hard (around 5k rpm) I haven't felt a lost of power. Could the whistle noise be from something else?
    Peter
    Veteran Member Four Rings Six Speed Turbo's Avatar
    Feb 09 2007
    Hopes, Dreams, Tools, Car Parts
    Killeen, TX
    Most likely it is the PCV valve, I searched and did my homework with the help of Audizine members took it to the dealership, told them to check the PCV and sure enough mine was bad and it had all the same symptoms. So check it out and keep us posted.
    2016 S3 Prestige - Glacier White Metallic, APR Stage 3+, APR TCU upgrade, APR CAI, APR FMIC, APR Catchcan, APR Lowering Springs, P3 Guage
    YouTube Channel https://www.youtube.com/channel/UC88...LbgXXvRHPvW3Xw <---SUBSCRIBE
    Jan 02 2007
    new york LI
    Its not the PCV , i just had mine replaced...its definitely the DV.
    Aug 19 2008
    US (Al.)
    Where are the PC and diverter valves located? My wife's '06 does this......at idle rpm's will drop down under 1k, then bounce up to 1800 or so, then settle down to 1100-1200. Then it repeats. Car runs fine other than this. I'd like to replace these valves, so if you guys can tell me where they're located, and where to get replacements I'd appreciate it.
    Oct 20 2008
    Denver
    i'm starting to get these same symptoms. rpm will jump up and down and "pulsate" while driving. i didn't notice it at first but then I heard it in the exhaust - then I looked at the needle and it kept (pulsating) up and down but not much (within 1-200 fluctuations). I'm still holding and spiking normal..you guys think it's the PCV? i'm almost hitting 50k
    Veteran Member Three Rings spitfire11's Avatar
    May 02 2007
    Airplanes, Cars, Trucks, Motorcycles, Bicycles
    Southern NM
    Sucks to read about this problem. Experienced a similar issue in my NA B5 but that would stall from the drops in rpms. Tried a bunch of things and never figured it out. Hope it doesn't happen to my b7
    VAG Cars:
    '84 Diamond Silver Metallic Rabbit GTI VR6 swap/resto-mod in progress
    Previous:
    '01 Nogaro Blue B5 S4 Sedan, 6MT, K04 Stg III
    '08 Ibis White A4 2.0T, Quattro, 6MT, S-Line Titanium APR Stg II
    '90 Black GTI Turbo 12v VR6
    '96 Emerald Mica A4 2.8 12v Quattro 5MT
    Veteran Member Four Rings airbornerifleman's Avatar
    May 20 2008
    2013 Passat TDI
    Toronto Ontario, Canada
    Quote Originally Posted by AudiTFSI3o3 View Post
    The same thing happened to me today. When I started the car, the rpm was low, not at its normal warm-up RPM and the car was shaking left and right. After a couple of restarts it seemed have gone away.
    After driving on the HWY for a half hour, I stopped at a store and left the car on, when I came back to the car, it sounded a little different so I check my tacho and the RPM is all the way up to 1300, 3-4 seconds later it goes down close to stall and starts all over. My first thought at this point was PCV.
    I'm gonna check under the hood tomorrow and do the PCV failure tests.
    I am just 1000KM above warranty
    2006 Audi 2.0T quattro Tiptronic
    APR Stage 2+
    OEM+
    _______________
    2013 Passat TDI
    May 20 2008
    2013 Passat TDI
    I popped my hood this morning with the engine running, and the first thing I noticed is a constant hiss. I tried to take off my oil cap and could not. According to my thread reading/searching skills, the symptoms I mentioned are common on engines with a failed PCV.
    Anyone know if PCV failure is just a TSB or an all out recall like the coils paks?
    APR Stage 2+
    OEM+
    _______________
    2013 Passat TDI
    Dec 01 2007
    Markham, Ontario
    PCV is just a TSB, i see you are in toronto as well.. i brought my car to uptown and had it replaced the same afternoon
    2015 BMW M3 Alpine White
    2013 Phantom Black RS5
    2012 Audi TTRS Black / Black - Sold
    Plus One
    Gabriel
    3255 Highway 7 East Unit 159
    Markham Ontario
    Cellular sales / repairs / unlocking / flashing - PM if you need help with anything
    Nov 19 2007
    07 RS4
    Taipei, Taiwan
    I had similar issue yesterday..and I got a CEL light.
    Plus, there was a high pitch hissing sound as well.
    I took the car to VW and let them check out the codes.
    They told me the CEL was caused by bad spark plug/coilpacks.
    And the hissing sound was probably related to fuel pump.
    Does this sound right?? Thanks in advance.
    Oct 20 2008
    Denver
    about a year ago I had the same hissing problem. like mentioned above I tried removing the oil cap while still running but couldn't. I figured it was the PCV at the time as well but turns out it was the Crank Case breather valve. brought it into the dealer and they replaced it.
    ^^ GL though. I'm still trying to figure out my situation.. maybe I'll have them check it out when I bring the car in for the ignition coil recall?
    Dec 07 2008
    Harrisburg, PA
    Guys, I torn DV will "not" cause idle problems.
    Senior Member Three Rings blackbox619's Avatar
    Oct 24 2008
    nyc
    2 days ago my cel came on and had a rough idle right between 500-800rpm jumping up and down so i brought it in and had the guys check it out. it just so happened that it was my pcv so i had it replaced today at open road audi. prior going for service, i had the vagcom read the codes and it said engine misfires on all 4 cyclinders but i knew that it wasnt the coils because i had 2 replaced last week. my guy showed me the pcv and it was clogged with oil biuld up. it is not the dv as some people had stated (maybe because i replaced the dv back in august?). the coils werent replaced, only my pcv. hopefully this info helps out.
    ~~ engineered in germany... modified in brooklyn ~~
    May 22 2008
    Australia
    I have this problem too on my 08 S3.
    Sometime if i am on 2nd gear go up to 5k rpm and put in neutral and let the car run itself. the RMP goes up and down.
    And it will keep doing it until the car comes to full stop, or after i step the clutch in.
    And found one of my injector is leaking.
    Veteran Member Three Rings A4Grocerygetter's Avatar
    May 08 2009
    2011 Toyota Highlander
    Makakilo
    CEL 000772 fault with Cyl 4 misfire MIL
    I have the same issue, although on cold start. Rough idle, RPM hanging around 1200-1300, then after warm up, RPM drops to 600-800 and get a shaking feeling and horrible misfiring on revs. Very bad gas mileage at around 195-240 mpg on a full tank, where my usual MPG was at 295 miles. Audi tech says bad injector.
    Dropped the car off at Tai VW (Hawaii), changing out the injectors and cam follower. Hoping this will solve the problem. I will post results later.
    2006 B7 A4 2.0T Avant S LINE Q - DTM, Hartmann, Carbonio, 034 Motorsports, JHM Motorsports, Milltek, Revo Stg II, Supertech, ECS, Stasis, HR, V4 LED's, Ziza, RNS-E, Votex, RS4 goodies
    May 22 2008
    Australia
    Man your car is doing better than my car.
    My doesn't even have fault code yet.
    I think it isn't doing enough to show it yet.
    But will get it check out soon.
    May 08 2009
    Makakilo
    Final result, bad injector on #4. Changed out and replaced all 4 injectors, and changed the cam follower out as well. Also, installed my 034 HFC and now the car is back to normal. Quicker turbo spool on the lower end. Glad its fixed.
    May 22 2008
    Australia
    Quote Originally Posted by A4Grocerygetter View Post
    Haven't get a chance to fix my car yet.
    But i am guessing its the same problem.
    Bad Injectors or the Injectors sits.
    We check it today change the plugs and coil pack around still #2 is doing it.
    So will have to wait till the work shop is free then we will pull this apart.
    Now hopping that's the problem.
