Results 1 to 13 of 13
    Veteran Member Four Rings Daddy MO's Avatar
    Jan 28 2007
    e30 * K5 Blazer * Xterra
    NOR*CAL - Benicia
    Tiptronic transmission fluid change
    I just had my tranny fluid changed for the third time. I am now at 151K. The last fluid changed was at 99K w/o filter. I mentioned having problems and pulling a cell about the torque converter being stuck. I also read another thread on how if you have over 110K on your tranny "do not change your fluid because your tranny likes all the sludge and metal flakes". Well, that statement was sooo far off but it actually had me thinking.
    The fluid that came out was as black as tar. When I looked at the filter it had metal flakes, dirt, and just looked like hell
    In any case, my cell never came back, shifts are smooth and the torque converter does not slip like it did prior to the fluid change. I highly suggest to change the fluids at least every 60K along with the filter and pan gasket.
    Parts list for tiptronic fluid service/change...
    Audi/VW ATF transmission oil (6 quarts) $18 - $22 each
    Audi/VW pan gasket $45 - $68 01V32137 (comes w/ O-ring)
    Audi transmission filter $82 01V325429
    FYI, the fill for the tiptronic trans is on the passanger side of the tranny and you will need a pump to fill. I also suggest that while you have the pan removed you cycle through the gears once. You will see more of the old fluid drain out. There is also no dipstick but the service does call for 6 quarts. If I mentioned "Audi/VW" that means you can get it cheaper at a VW dealership. Alot cheaper.
    No pics, forgot my camera.
    Thanks to: Lubrify.com / TOMAS Sport Tuning / BRRacing / Craftwerx Concepts / I/O Port Racing Supplies / AGUND1S Tire
    Veteran Member Three Rings 9744RR's Avatar
    Sep 01 2005
    2016 A6 3.0T, 2003 A4 1.8T Tip, GTRS Elim, REV0, 440 injectors, ASP front mount, etc Porsche 356
    Re: Tiptronic transmission fluid change
    What do you mean by cycle through the gears once? I'm planning on replacing my wife's A4 tranny fluid pretty soon.
    2016 A6 3.0T Stock
    2003 A4 1.8T Q TIP not stock
    Porsche 356 Stock
    Veteran Member Three Rings dpatel's Avatar
    Oct 03 2005
    Atlanta, GA
    I had some metal flakes as well when Level10 did my VB upgrade at 32K. They were surprised that these Audi's where doing this.
    - 3.0 Quattro
    - Milltek Exhaust with 4" Tips
    - Hyperflow Intake
    - Caracter Front bumper
    - Eibach Pro Kit + Bilstein Sport Shocks and S4 Rear Sway
    - Sportec 18" wheels
    - Stoptech Slotted Rotors with Ceramic Pads
    - Level 10 VB & APR Snub Mount
    - G3 SuPeRcHaRgEr
    VP of 3.0 CLuB
    Veteran Member Four Rings 1point8teeNW's Avatar
    Nov 11 2006
    North Webster, IN
    I got my fluid for 11 each.
    So HA!
    Current - 2004 Pontiac GTO 6M *FOR SALE*
    Looking for - B6/7 S4 TIP or 6M
    Established Member Four Rings A4TL's Avatar
    Nov 06 2006
    335is
    atlanta
    whats the part # for the fluid for 1.8T tiptronic?
    i did mine 16K miles ago i forget lol. i plan to do every 20K/2 years so next oil change i better get the stuff together. Better to be proactive than buy a $2700 reman + torque converter + obscene labor
    02 1.8tqs - apr 1+ - SS forge - Hartmann B5 RS4 18" ET35 - Delsa (ebay) spoiler lip - debadged, B7 A4 320mmx30 front brakes - 335i Montego Blue/black; Sport;Prem; iDrive; Step and Heated Seats.
    Jan 28 2007
    NOR*CAL - Benicia
    Quote Originally Posted by 9744RR View Post
    Get all four wheels up in the air and cycle through the gears one time while the pan is off. you can only do this while the filter is removed.
    I dont know the part number for the fluid. Im sure its the same 1.8 and 3.0. VW uses the same as well. All I know is the bottles are black and have Audi, VW, and ATF on the label.
    Established Member Two Rings gotquattro's Avatar
    Jun 18 2007
    02 A4 3.0 Q / T / S
    Tallahassee
    huh-
    this past weekend I ordered the filter and gasket from ECS-
    A/T Filter & Pan Gasket Kit For 01V Transmission ES#1772 $29.95
    That's a heckuva price difference...
    Got Quattro?
    02 Silver A4 Sport (sold)
    3.0 Q / T / S
    14851's | RS4 Rear Sway | Slotted F&R w/ Hawk HPS & Stainless lines | APR Snub
    2006 MazdaSpeed6 GT #3476
    - clicky-clicky for details
    Jan 28 2007
    NOR*CAL - Benicia
    Quote Originally Posted by gotquattro View Post
    huh-
    I couldnt wait for shipping so I had to get mine at the dealer. Had I known ahead of time I would have ordered from ECS.
    Nov 06 2006
    335is
    atlanta
    you can get the pentosin too. i do germanautoparts dot com since they charge you actual bulk-rate ups fees instead of buffing the price on fees (not saying ecs does that)
    Jun 18 2007
    02 A4 3.0 Q / T / S
    Tallahassee
    Here's a pic of the $29 kit from ECS
    (and the APR snub & the fuel filter that all came in today's mail)
    Got Quattro?
    3.0 Q / T / S
    Nov 06 2006
    335is
    atlanta
    lucky 3.0 guys and their cheap fuel filters :)
    Jun 18 2007
    02 A4 3.0 Q / T / S
    Tallahassee
    Quote Originally Posted by A4TL View Post
    $8
    Got Quattro?
    3.0 Q / T / S
    Veteran Member Three Rings Noodle's Avatar
    Oct 16 2007
    Pittsburgh, PA
    Good tip. I'm @ 60k now, so I'll have to see when the last time it was changed.
    EDIT: I also forgot to add that my engine (not when I owned it, the previous owner), had the entire engine replace by Audi due to sludge.
    Sludge is never a good thing, unless you're making a snowball.
