Results 1 to 19 of 19
    Nov 26 2006
    Memphis, TN
    Carbon Fiber Weight Loss
    OK guys, My car is a pig, coming from a small BMW E46, a 2004 M3, my car needs to drop some pounds, Mainly from the front. I feel i can get over 100lbs out of this car easy, just need some help sourcing parts.
    Here is what I know i need:
    OZ Wheels, Ultraleggera's
    ECS 2 Piece brake rotors
    Remove bumper supports
    Remove Spare Tire and Tools, that is what road side service is for anyways
    Carbon Fiber Hood
    Carbon Fiber trunk
    Here is what i need help finding:
    Lightwieght battery and battery relocation kit to put battery where spare was
    Carbon Fiber front fenders
    a shop to build carbon fiber driveshafts toreduce rotating mass
    Veteran Member Three Rings Silververtu's Avatar
    Sep 26 2005
    DMV
    Re: Carbon Fiber Weight Loss
    If you just take out the spare tire and tools, you will lose about 62lbs. I am interested on relocating the battery to the trunk.
    Good Luck and keep update your progress!!!
    Current:
    2019 Porsche Cayenne Turbo
    Gone but not forgotten:
    2006 2.0T A4 Avant 2007 BMW Z4 Roadster 3.0si 2006 BMW M Roadster 2013 BMW 550i M Sport 2015 Porsche Cayman S 2015 BMW X5 50i M Sport
    Established Member Two Rings maybachgt's Avatar
    Feb 13 2007
    los angeles
    Make sure you dont get the GMG carbon fiber hood. It is one of the cheesiest products ever. I know a guy who has it one his RS4 and it looks like a giants sticker. When you open the hood it is one of the flimsiest things ever. As for the weight loss, get some light weight rims and tires should save you 10lbs per corner or more. Brakes will also make a huge difference in weight. I'd remove the tools spare ect and get a lightweight battery but the CF stuff will yield a negligable weight loss for a high price. A nice set of coilovers like Stassis/Ohlins and H-Sport sways will make your car feel a lot lighter.
    Jun 21 2005
    Milton, Ontario
    Why remove the bumper supports? Wouldn't that decrease crash ability? Also are you driving the S4 or the RS4? They are both heavy but they aren't "pigs". The e46 M3 wasn't that much lighter...
    – Steve
    2021 Tesla Model Y
    2020 Tesla Model 3
    2014 Dodge Grand Caravan
    Veteran Member Four Rings autoverruckt's Avatar
    Sep 26 2004
    STL
    An aftermarket exhaust system should save you some weight too.
    As for road side assistance, I have used them twice...they just put the spare tire on for you. Audi outsources just like AAA.
    04 A4 USP 1.8TQ 6MT Silver | GIAC | evo dv
    05 S4 6MT silver
    07 A4 2.0TQ Black | APR93 | Eibach/Koni Sport | oem B7S4 18's
    03 A4 Avant 3.0L Silver | oem B7S4 18's | 10mm rear spacers
    14 A4 2.0TQ Silver | APR93 | S-Line Pkg| Cold Weather Pkg | 12mm rear
    Present:
    20 Q5 Manhattan Gray | Titanium Sport Pkg | Black Optic pkg
    23 S4 Chronos Gray | Premium Plus | S Sport pkg | Sport exhaust
    Nov 26 2006
    Memphis, TN
    my m3 was not stock and was actually down to a little under 3200. The s4 needs to lose weight
    Veteran Member Four Rings bunnn's Avatar
    Jan 24 2006
    e92
    you gotta be on a huge diet to get the S4 to even close to that, just think about it, compared to an e46m3 you have 2 more doors, different drive system(rwd vs quattro).. and a heavier V8 compared to I6
    and regarding the CF drive shaft, if your still under warranty is probably not a smart idea to do it...
    oh our seats are dam heavy too...=)
    Cheers!
    ~Ben
    Registered Member Two Rings ParkerF1 B7S4's Avatar
    May 14 2007
    B7S4, XC70, '08RS4 spec'd
    Little Silver, NJ
    Quote Originally Posted by OneFastBMW View Post
    Carbon Fiber Hood
    Carbon Fiber trunk
    You can have my black Ultraleggeras. $2k with almost brand new advans... or $1500 rims alone... sans TPMS.
    Rob
    2007 S4 Black/Black/Carbon
    RS4 Optic Grill, EVOMS V-Flow, Milltek Full Non-Res, GIAC, P-SS9s, H&R Sways, APR Snub, JHM ss, Oettinger/DTH Spoilers,DVDIM, VagCom-
    OQO 02 style, Hardwired V1, 20" Black OZ Ultraleggeras
    Marin, Ca
    Quote Originally Posted by maybachgt View Post
    Sorry, I have to disagree with you on the GMG CF hood. I've seen and dealt with 3 different setups, and for a carbon hood they are great. I'm not sure how many carbon hoods you've dealt with in your life, but they are all fairly felxible due to the material, or rather lack thereof to reduce weight. It comes in at a scant 14lbs, and if painted, looks totally stock.... Just another mans opinion.
    If you want to check it our for yourself go here
    Senior Member Three Rings heliskyr's Avatar
    I haven't heard of anyone doing this, but if you wanted a lighter hood it may be worth looking into picking up the OEM RS4 aluminum one. It would be way lighter than the steel one on the S4 and would not require the hood pins that are usually recommended for CF hoods. I wouldn't expect it to be an inexpensive option, though...
    As for relocating the battery, you may be able to use the OEM RS4 parts that relocate the battery to the rear spare tire well. I don't know what all of those parts would entail but since Audi already adapted the B7 body to do it on the RS4 my guess is you could probably pick up the parts from your Audi dealer.
    2005.5 S4 Dolphin / Black / Carbon
    Tip / Premium / Nav / Prem Audio / XM / Cold / Shades / TPMS
    Escort SRX Radar / Laser / Laser Shifters custom install
    20% Tint / H-Sport Sways / RS4 Grill / RS4 Pedals / DTM Carbon rear spoiler / S4 caliper springs
    Nov 26 2006
    Memphis, TN
    thank you for the battery info. However, i am going to make a battery tray to bolt there using a lightweight battery.
    Also, I all ready have the OZ wheels but thanks for the offer.
    Lastly, does anyone know of a company that can mak plastic body parts like the new BMW 3 series uses. This would be better than carbon fiber as i do not need to strength or looks.
    Nov 26 2006
    Memphis, TN
    also, i do not think the aluminum V8 would be that much heavier than the Iron 6 cylinder. The new V8 in the new M3 is actually lighter than the I6 in the old m3
    Feb 13 2007
    los angeles
    Quote Originally Posted by XCARTELX View Post
    I've dealt with quite a few include one-offs for porsche turbo's gt3 ect. this just seamed to be on the cheap end of the scale and the price reflects that. After seeing the GMG hood I fully appreciate the price of the MTM hood. And it is still possible to have a stiff carbon hood that is light. As for weight loss what about stereo removal or making so sort of "quick release" bolt system for the rear seats that basically "pop" back in
    edit: I forgot to mention the GMG hood did not fit properly immediatly. A new bracket was fabricated to make it fit properly
    May 14 2007
    Little Silver, NJ
    anytime. I think i'd like to hang on to them for the new car anyway ;P
    Rob
    Dec 11 2005
    California
    I paid just over half of what the current cost of the MTM CF hood is so I'm not condoning the price. However, it's a great CF hood--very stiff, yet only 12 lbs. PERFECT fit and ready for install, no adjustment or drilling of any kind was necessary. The owner of the body shop where I had it installed said he's done at least 100 CF hoods by just about every major manufacturer and this was by far the best he'd ever seen. I was on my way home in less than an hour...
    Nov 26 2006
    Memphis, TN
    can you please post some pics of the hood closed. I want a vented hood to help with underhood temps
    Dec 11 2005
    California
    Click on My Gallery Images under my username on the left of my post. There's a pic of it closed in there.
    Nov 26 2006
    Memphis, TN
    awesome, thanks. Since I have a DTM that is what my car will look like. Do you feel it does anygood with underhood temps? Also, does anyone else make a vented hood for the B7 body?
    Dec 11 2005
    California
    I think it does some good... I see plenty of heat haze rising out the vents when driving slowly or at a stop. I'm not aware of any others. I think $8.1K (unpainted) is too high for this hood though. You can save about the same amount of weight with the EuroGEAR hood for a small fraction of the MTM price, and I would think you could get a custom vented hood fabricated for less as well.
