Results 1 to 14 of 14
    Senior Member Two Rings rbecker's Avatar
    Nov 30 2006
    Los Angeles, CA
    Different offset in front vs. rear...
    I know people have made comments about running a staggered set up with Quattro cars - different size wheel in the front vs. the back.
    Does the same theory hold true with running a different offset in the front vs. the rear while maintaing the same size wheel and tire combination all the way around?
    TIA
    06 Quartz Grey Avant 2.0T Quattro
    Fomula One Tint
    Vogtland Coilovers
    19' J Line 10RL2 Wheels
    245/35 Kumho Ecsta SPT Tires
    VAG Com goodies...
    Mar 18 2012
    new zealand
    This is relevant to my interests... no one in 5 years knows?
    Oct 14 2009
    Okinawa Japan
    Sigh, it wasn't even replied to because of how dumb the fucking question is.
    But to answer your question, offset wont affect anything except
    How well the wheels fit inside the fender, if you have stock suspension. Anything between ET45 and ET30 is pretty safe territory
    You will
    Only truely
    Know what size spacer you want when you lower your car and then get the wheels you want.
    Measure your gap and get the appropriate spacers.
    Think about offset, and
    Then try to think of a reason it
    Would affect any system
    On the car if the tires are
    All the same
    Dimension......
    Woo-sa
    -Shane Drake-
    2006 A4 Avant Dolphin Grey
    2007 GT3071R A4 Moro Blue-RIP
    >DRAKLOREs Build<
    Formerly DRAKES-PERFORMANCE
    Veteran Member Four Rings Solarsuplex's Avatar
    Aug 20 2011
    Seattle Wa
    Was about to say exactly that.
    Shane should be able to lock threads after answering them.
    -James
    F T W L T B D W I C T W
    Moonlight Blue - B8.5 S4
    Brilliant Black - B7 A4
    Oct 14 2009
    Okinawa Japan
    /Thread
    -Shane Drake-
    >DRAKLOREs Build<
    Veteran Member Four Rings camoto's Avatar
    Nov 30 2009
    KTM Superduke 990
    MA
    Quote Originally Posted by DRAKLORE View Post
    I like anyone who contributes to the Audi community. I just hate how most of the time people are so arrogant or full of themselves.
    10char
    Oct 14 2009
    Okinawa Japan
    Doesn't change the fact that it was a "dumb fucking question"
    Don't see how that makes Me Arrogant
    -Shane Drake-
    >DRAKLOREs Build<
    Veteran Member Three Rings ignus99's Avatar
    Nov 08 2009
    Calgary/Alberta/Canada
    Long story short
    Lower offset = more aggressive, pushed out further from your fender wall.
    If you were to get a different offset for the front and back, the only difference would be its pushed out a little more.
    Useless in my opinion. You can get the exact same result with spacers - with the option of rotating tires whenever you wanted to.
    Don't over complicate things.
    - Karl
    Engine: GT28RS by ATP / Turbosmart 38mm dual BOV/Recirc / Carbonio CAI / APR TBE / APR Testpipe / REVO St2+ / Snow Performance ST2 / APR HPFP
    Body/Suspension: KW V2 / DPE ST-10 19x8.5 et35 / Thor Skid Plate
    Pretty Stuff: AWE Vent Boost Gauge / OEM Bixenon + V4 LED / Supertones / Votex SS / CF Hood & Mirrors / RS4 Grille & Fogs
    Veteran Member Three Rings J.Owen's Avatar
    Aug 12 2010
    I run -361* of Camber.
    Bucks County, PA
    But will this affect how long it takes me to go 80 miles at 80 mph?
    Expenses in F1 have gone down since the 1960s because teams don't need an extra pit crew to help the driver carry around his balls when he is not in the car.
    Veteran Member Four Rings Stewy's Avatar
    Jan 24 2010
    2007 Audi A4 S-Line 6MT, 2012 F-150 Platinum 6.2L, 2003 Suzuki GSX-R750
    Vancouver, B.C., Canada
    As said above, different offsets do not matter, as long as the overall circumference of the tires are the same. I think there's a window of +/- 5%.
    2007 Audi A4 S-Line 2.0T FSI - APR Stage III GT2871R, APR HPFP, Carbonio intake, AWE FMIC, BSH CC / PCV delete, OEM "D" DV, APR downpipe, Neuspeed exhaust, H&R coils, ECS Stage 4 BBK, JHM 4:1 center diff, Neuspeed short shift, RS4 rear sway bar, Neuspeed snub mount, Defi MeterBF gauges with Defi-Link, Vag'd, de-badged, black rear valence, Cupra R lip, Huper Optik tint, RS4 grille, EU amber tails, 19" Hartmann RS4 replicas with H&R Trak+ spacers
    Veteran Member Four Rings fordyoz's Avatar
    Apr 20 2011
    Philadelphia
    to give him credit, he has only been a member for 10 days, and he used the search function rather than starting a thread.
    Borg Warner EFR6758 B7 A4
    Oct 14 2009
    Okinawa Japan
    Exactly why I answered his question, and only made a comment about the OP.
    The OP had almost been a
    Member for a year before asking a pretty dumb question, let's be honest, and I was merely stating why nobody in 5 years even bothered to respond
    -Shane Drake-
    >DRAKLOREs Build<
    Oct 20 2008
    Denver
    Quote Originally Posted by J.Owen View Post
    well, i can run 1 mile in about 7 minutes..
    Nov 08 2009
    Oh shit! I didn't even notice it was a 2007 post till now.
    ... aaaand I'll be leaving now.
    - Karl
