Results 1 to 12 of 12
    Sep 13 2007
    04 Atlas Grey A4 1.8TQ Avant
    Quebec, Canada
    Winter tire size questions on OEM 17" wheel
    Hi. I am thinking of staying on my OEM 17" wheels this winter, and buy a nice set of 18" RS4 reps next summer. I live in Quebec so there's a lot of snow. I'm wondering if I can fit some 205/50-17 tires. I know the diameter would work, but are these too thin for my wheels? I don't know the wheel width exactly. I'm running 235/45-17 on them now, they are the sport package wheels. I could get 225/45-17 but I think that's still too wide for snow, and I don't want to buy 16" wheels if possible.
    Martin
    Feb 17 2004
    Sterling, VA
    Re: Winter tire size questions on OEM 17" wheel
    Quote Originally Posted by gtimart View Post
    Martin
    I'm pretty much doing the same thing here. I'm looking at the Dunlop Winter Sport 3Ds for this season and then putting a set of 18-19" RS6 Reps & tires on in the spring.
    Honestly, the 17" diameter isn't really an issue. The 7.5" width would be the part to worry about. As we know wider tires make a wider footprint and can lead to hydroplaning. Going skinnier would be better for traction but, you'd need a skinnier wheel first. I don't think you can use a skinnier tire on your stock wheel.
    Here's a size calculator that I use to test sizes.
    http://www.miata.net/garage/tirecalc.html
    Brett - Moderator
    Issue?: email me.
    _____________________
    Stage 3 2004 A6 2.7T 6M
    Veteran Member Four Rings chrislane31's Avatar
    Mar 24 2007
    I just picked up some Hankook Icebears in 225/45/17
    Sep 13 2007
    Quebec, Canada
    Yeah, the miata.net tire calculator is what I used, total wheel size will be good. Like you said, it's the width of the tire relative to the width of the wheel that I'm worried about. I'd love to put 215's but Gislaved don't make 215/50-17. I can get excellent deals on those very good tires so that's why I'm asking for the 205.
    Deactivated Four Rings
    Oct 06 2006
    South Bend, IN
    Diameter is good, I am working on the load issue (go you have GAWR front and rear ?). Also would need width of OE 17" wheel to be sure
    Sep 13 2007
    Quebec, Canada
    Hi Doc. Unfortunately, I don't have that information. It's a 2004 A4 Avant Quattro Manual, but I don't know the GAWR. Same for the wheels, they are the sport package wheels from that year (6 flat relatively wide branches) but I don't know the width. I did not think of the load issue, but it certainly is important.
    If this is too complex (because I don't have the information you need) or weight is an issue, I'll try to find 16" wheels. Used OEM ones are hard to find around here. It's just that I don't want steel wheels for winter, they're too hard to clean after a drift session
    Oct 06 2006
    South Bend, IN
    We were able to come up with GAWR of 2,469 lbs frt / 2,425 lbs rear. The 205/50R17 carries up to 1,433 lbs per tire (XL or reinforced sidewall) so your are fine on load and diameter. The 205/50R17 has a rim width range from 5.5" to 7.5", so that would be the last variable. Often, wheel sizes are listed on the placard inside the door jamb or stamped on the back of the wheel.
    Sep 13 2007
    Quebec, Canada
    Thanks a lot doc! I'll think about that. I guess the 205 would look funky on my rims :-)
    Junior Member Two Rings ilPadrino05's Avatar
    Sep 17 2009
    1983 MB 500SL
    Washington, DC
    So, is anyone running 205/55R17s on their B7s stock rims with any success yet? Or, should I stick with the recommended 235/45R17s?
    Veteran Member Four Rings L0U's Avatar
    Sep 03 2009
    18 R8 RWS, 20 RS3, 21 RS6, 04 Ducati SS1000DS
    Martin
    I ran 215x50-17 on my 2003 A4 3.0litre. stock was 235x45-17. They worked great. just a few mm taller, but fit perfect.
    http://www.tirerack.com/tires/tires....omCompare1=yes
    2021 Suzuka RS6
    2020 Nardo RS3
    2018 Ibis R8 RWS
    Sep 17 2009
    1983 MB 500SL
    Washington, DC
    I'm glad to hear it can be done. I guess I'll be ordering the Michelin X-Ice Xi2 205/50R17 first thing Monday then. Thanks for the info.
    Jul 30 2008
    08 Passat 2.0t
    Near Mountain Creek
    Quote Originally Posted by ilPadrino05 View Post
    I run 205/50r17 on my B6 Passat, on stock 17" wheel
    Michelin Altimax Arctic
    08 Passat wagon 2.0T 6MT (APR Stage I, DriverGear-Eibach springs, Bilstein Sport, Euro smoked tails, intake, ATE Premium One rotors, Hawk HPS, Tyrolsport Caliper Guide Bushings, other stuff)
    Previous Cars:
    02 Golf TDI 5MT (Chipped, Bosio PP764 nozzles, VNT-17, Shine Racing suspension, S3 strut brace, WRD rear strut brace)
    88.5 Camry V6 5MT
    84 Corolla 3AT (the FWD version, hand-me-down)
