Results 1 to 16 of 16
    Senior Member Two Rings giacb6usp's Avatar
    Sep 17 2006
    05 A4 1,8T
    Long Island. NY
    Octane Booster Longterm Effect..
    I'm using STP Octane Booster for everytime I fill up the tank..
    Some said using octane booster can damage emission system.
    Is it for real?? The engine response a lot smoother and quicker with 93 + Octane Booster but I'm just worrying that I might damage these things...
    any opinions??
    USP CLUB MEMBER #4
    K04 - Miltek Exhaust - PSI TP - Racetec FMIC - TT 225 - SB OFE SS - AWE Boost Gauge - AWE Tuning Pedals - Forge 007P- RNS E - Oettinger - Apexi TT - Fujita Filter - S4 F.Grille - ECS D.Mirror - Hawk HPS F/R - Hardwired V1 - Hitachi E CP - Bosch FR5DTC - H11 Höen Xenonmatch - APR Snub - VAG-COM License with HEX-USB+CAN Interface -
    Established Member Two Rings UltraA4's Avatar
    B6 1.8TQ USP, B5 S4
    Re: Octane Booster Longterm Effect..
    I read somewhere that they do have negative effects on spark plugs, injectors o2 sensors etc...in high concentrations so i dont know if i would use it every time. Why not just fill and mix with real race gas higher octane?
    USP CLUB MEMBER #74
    www.RPMNorth.com check em out!
    Current rides:
    05 A4 1.8tq USP black/black
    02 S4 Silver/black
    Previous rides
    04 BMW 330i ZHP package monaco blue pearl/beige
    03 A4 1.8tqm moro blue/grey
    01 A6 2.7tq black/black
    99 A4 1.8tq silver/grey
    Established Member Four Rings A4TL's Avatar
    Nov 06 2006
    335is
    atlanta
    that stuff is overpriced junk.
    go get some toluene from sherwin williams or some xylene (google the effects) if you octane boost for less cost.
    you can do 20% toluene and/or 10% xylene (100% pure only!)
    toluene is about 114 effective octane and xylene is about 118 effective octane
    both are great paint strippers i'd use a hose-pump device to pump it out of the can since it will bubble paint on contact.
    keep in mind most octane boosters also burn hotter giving higher EGT's and your plugs usually will show a tinge of (yellow?) color on the ceramic.
    stuff works though man. xylene is pretty bad for rubber lines.
    both quickly lose their properties when exposed to the air (aromatics). If you must pour this in on a very low tank then fill up and do some crazy driving (no donuts!) to slosh it around.
    gasolines and such just dont mix like you'd think they would.
    or buy 100 octane it will probably just cost the same if you can source it unleaded and its FRESH. never buy gas out of a big ole tank its usually old stale gas. Why all C/VP-16 leaded is always sold in 5 gallon tanks (or larger).
    remember buying large quantities of toluene like a 50 gallon tub may lead to the DEA watching you. you seen the movie SPUN?
    02 1.8tqs - apr 1+ - SS forge - Hartmann B5 RS4 18" ET35 - Delsa (ebay) spoiler lip - debadged, B7 A4 320mmx30 front brakes - 335i Montego Blue/black; Sport;Prem; iDrive; Step and Heated Seats.
    Veteran Member Four Rings chrislane31's Avatar
    Mar 24 2007
    Do the math octane boosters are garbage.
    lest say you put 16 oz of 104 octane booster in with 13 gallons of 93
    1 oz = 0.0078125 gal
    16oz=.125 gal
    93x13=1209
    .125x104=13
    1209+13=1222
    1222/13.125=93.105
    So that 1 16oz bottle raised your octane .105 points
    Even 1 gal of 100 only raises your octane .5 points
    Registered Member Two Rings
    Mar 21 2007
    Silver 02 Audi A4 Avant 1.8TQM
    Germantown, MD USA
    Quote Originally Posted by chrislane31 View Post
    16oz=.125 gal
    93x13=1209
    .125x104=13
    1209+13=1222
    1222/13.125=93.105
    This is pretty much what I've herad. Those small bottles of octane booster add just a fraction of octane to a tank. It's a waste of money.
    Is there a reason you need more than 93 octane? The stock 1.8T is setup to run on 91 and that's what I use with no problems. Now with mods that could change. But why waste all that money? Just tune your car for 93 if it's not already.
    Have you heard any pinging when you're on just 93?
    Mike
    2002 Audi A4 Avant Quattro 1.8T 5spd Silver
    2000 Pontiac Formula Firehawk 5.7L Supercharged 6spd Navy Blue Metallic
    Veteran Member Four Rings initiala4's Avatar
    Feb 24 2004
    Land of the smiles
    I heard Torco is the way to go when it comes to octane booster.
    2019 B9 RS4 - O.CT Tuning Stage 1 | Wagner Intercooler / Radiator | JBOM 100 Cell downpipe | Ohlins R&T DFV | 034 Motorsports Dynamic + Sway bars | 034 Motorsports Transmission mount | Ignition Projects Coilpacks | HHC Rear rotor upgrade 370mm + Endless MX72 brake pads
    Formerly - 2003 Audi B6 A4 1.8T QM, 2013 VW Passat Variant 2.0 TSI
    Feb 17 2005
    Sarasota, FL
    I used to run octane booster (BTW the STP booster is crap and does nothing) Prestone 0-60 (orange bottle) or Champion (black bottle) are the only ones that drop CF's. I used to run 0-60 on every fill up, it would drop CF's 3-5 points depending on conditions so yes it does make a difference, I dont care what any of your guys mathematical bullshit shows. Run it and log, there IS a difference!!!!
    Why I dont run it anymore, I got lazy and dont feel like running to autoparts or Walmart to grab a bottle everytime I need gas, got to be a pain in the ass!!!
    Feb 17 2005
    Sarasota, FL
    FYI, quite a few that are sold at Autoparts stores (I go to Adavnced Auto) which say "NOT FOR STREET USE, OFF ROAD ONLY" or something of that sort, these are the ones that work best and show the most drastic drops in CF's however some of them get up to the $8-10 range for a bottle
    Apr 05 2007
    Quote Originally Posted by initiala4 View Post
    yeah Torco and Lucas are the only 2 that actually raise octane "noticeably". "3 points" is equivalent to .3 in Octane rating. So additives that say "raises by 10 points!" mean 1 octane number. or from 91 to 92. Lucas raises 30 points (or 3 octane) per 16 gal of gas and has lubricant additives.
    Mar 27 2005
    The Cold North
    Quote Originally Posted by exorcet View Post
    You are refering to this one? Lucas Octane Booster
    I have never actually seen this in the store? Where have you purchased it? thanks.
    2001 A4 1.8TQM (in pieces..)
    2020 Chevy AEV ZR2
    Feb 17 2005
    Sarasota, FL
    Quote Originally Posted by EBG 18T View Post
    Yup thats one of the ones I was talking about that says offroad use only on the bottle. Ive gotten it from Advanced Autoparts several times, not sure if you have those by you. It is also 8-9 bucks a bottle IIRC
    Veteran Member Four Rings Daddy MO's Avatar
    Jan 28 2007
    e30 * K5 Blazer * Xterra
    NOR*CAL - Benicia
    The only octane booster/cleaner that works and that I have proven to myself and others on paper is CLEAN POWER!!! Otherwise you might as well be running race gas.
    Thanks to: Lubrify.com / TOMAS Sport Tuning / BRRacing / Craftwerx Concepts / I/O Port Racing Supplies / AGUND1S Tire
    Feb 17 2005
    Sarasota, FL
    Quote Originally Posted by Daddy MO View Post
    octane booster for a 3.0 and for a 1.8T are going to be totally different. I see no reason why you would ever use octane booster on a NA car
    Mar 24 2007
    So 15ozs of this can do what 1 gal of 100 cant? 30 points is a alot in a 15 gal tank.
    I used to use this stuff in my old car and never saw any real difference, but when I would put 1/2 a tank of 100 in I could def feel it.
    Jan 28 2007
    NOR*CAL - Benicia
    Quote Originally Posted by A4ringedONE8T View Post
    I havent used it on my 3.0 and compared results. I guess I should have mentioned that this was on an MR2 turbo, 13B and 13BT rotary, and Audi inline 5T motors. The results gained were .030 dropped on et's.
    BTW, the same results were on one N/A motors as well. Not only rotaries but some 1.8 to 2.0 Honda and Nissan motors. All this was done back as freakin 1992 if some of you youngins need to know
    **edit** the 3/10 dropped was at best but I would say the avg was at least .015 dropped depending on the motor.
    Veteran Member Four Rings 3ohAvant's Avatar
    Mar 09 2004
    east bay, CA
    the STP stuff really isn't worth much.
    You want the torco mach stuff, or the amsoil stuff.
    Just beward of running anything with lots of MMT ( i think thats the acronym). Basically, if you start seeing your tips orange, and your plugs orange up, then stop using that brad, its got too much of that MMT stuff in it.
    The torco stuff, we run in the car at races/autox, not daily.
    There are a bunch of subbie guys that have run the torco stuff for like 5-10K miles daily, every tank, w/ no probs.
    - Benny
