Results 1 to 8 of 8
    Veteran Member Three Rings dingguhlbary's Avatar
    Jul 17 2007
    New Jerzzzzzzzzzzzzzzzzzzzzzzz
    how can i check if the rear differential is leaking?
    so im going around checking cars and doing most of what this says
    http://forums.vwvortex.com/zerothread?id=2080285
    but how do i check if the rear differential is leaking? thanks
    Veteran Member Four Rings tamadrumr88's Avatar
    Nov 03 2006
    lehigh valley pa
    Re: how can i check if the rear differential is leaking?
    the rear diff will look "wet" in spots more so than others, especially on the lower side of it thanks to gravity at work
    dont get me wrong, it leaks, but not enough to worry me. one day when im feeling ambitious ill crawl under there and top it off. its not leaking enough to worry me at this point because its not like i have puddles under my car (then again it may be completely dry who knows)
    Veteran Member Four Rings audiness's Avatar
    Jan 26 2007
    Charleston SC
    mine leaks around both rear driveshaft seals. I drained it because i was scared that all the fluid was gone, but when I drained it , it was missing hardly an fluid.
    I filled it w. fresh oil and good to go
    Veteran Member Four Rings .Mad Hatter.'s Avatar
    May 07 2007
    thing with diff. fluid is that it will only leak out when the car is in motion, so there more than likely wont be a puddle. get underneath it and look for fluid around the axles, at the diff. it leaks VERY SLOWLY, mine have been leaking since x mas and i just got them done. they leak more in the warm weather, so nows the time to do them.
    Aug 19 2009
    Vermont
    i cant find any good DIY's on fixing this leak, anyone know where i could find one?
    Veteran Member Four Rings J Ozzie's Avatar
    Jun 06 2008
    Port Moody, Canada
    yeah id say fix youe leaking diff if it is.. i was told by a mechanic when i had my talon..
    '' your diff is sweating but dont worry''
    Next thing you know me n the gf are on a road trip doing 180 to head to K town and BOOM my diff locks up oil spills onto my custom 3'' exhaust and then catches on fire!
    Yeah ill never get that smell out of my head.
    All our clothes smelled like diff oil for weeks no matter how many times we washed them..
    2014 Audi Q5 TDI - Brilliant Black | LED Fogs | VCDS Mods | LED Interior swap |
    R.I.P... (wrecked)2005 Audi A4 1.8TQM 6Speed
    R.I.P..2001 Audi a4 1.8TQM (casa white no sunroof)
    Vancouver Audi Club.ca
    where's our resident intoxicated lobster Canadian - Thomas
    Jun 01 2008
    Apopka, FL
    Quote Originally Posted by nchiarel View Post
    There's not alot to write about.. pop the axle off, then there's a single bolt that holds the flange on and then you have direct access to the seal. only hard part is putting the seal back in the correct depth and angle since there's no easy dummy stopper. If you're doing something like this for the first time It's good to have an extra seal or two. I destroyed two trying to get the seals in correctly.
    Aug 19 2009
    Vermont
    Well todau i just replaced my tbb and f hose and filled up my rear diff (it took a whole quart so i odnt think its doing too well). Im going to check it in a week or two to see how much its leaking then ill make the decision. It has 63,000 miles and the fluid has never been changed. U think i should change it or wait a couple weeks to see how bad it is? Where can i get the seals and how expensive is the repair/can i do it myself?
