View Poll Results: 17" Kosei K1-TS or 18" BBS RC
Voters
13. You may not vote on this poll
  • 17" Kosei
    3 23.08%
  • 18" BBS RC
    10 76.92%
Results 1 to 17 of 17
    Registered User Four Rings winston@podi.ca's Avatar
    Jun 11 2005
    Pods, gauges and more pods
    Vancouver, BC
    Kosei K1TS or BBS RC??
    I'm looking at replacing my 17" A6 fat fives with a lighter wheel.
    The primary purpose of the wheel is for long distance driving to save wear on my 20s and to be a track wheel in case of rain when r-compounds shouldn't be used.
    So the choices are:
    Set of new 17x8 ET35 Kosei K1-TS that weigh about 16lbs
    or
    Set of used 18x8.5 ET32 BBS RC that weigh about 19lbs
    The tires in either case will be Falken 615s
    So... which one?
    I'm kind of favouring the BBS since they are wider but the Kosei are lighter. Will the 3lbs of weight savings be that noticeable?
    Veteran Member Three Rings RASTA4's Avatar
    Feb 26 2005
    2002 A4 3.0
    Metro Detroit
    Re: Kosei K1TS or BBS RC??
    I vote for:
    Based on your predisposition for high-end sh!t, BBS should be your choice. The 18s might weigh closer to 20-21lbs while the 17s are 19lbs. Chances are you won't notice a difference between the two. I've hit a couple of massive pot holes and the 17s held up perfect (run-out remained true). RCs would be some ballar track wheels a la Jet Jockey.
    |2002 3.0 SEDAN Q6MT|POLAR WHITE|PLATINUM BUFFALINO|SPORT|CONVENIENCE|COLD|BOSE|BNS-NAV|PARKTRONIC|SUNSHADES|ODO=34XXX|
    MODS
    |PES G3 SC|SUPERSPRINT|AFE PRO-DRY|18x8 BBS RE-G FORCE SPORT|17x8 BBS RC-CONTIEXTREME|H-SPORT S4 SWAYS|AMS SS|APR SNUB|STOPTECH 332 FRONT-BREMBO X-DRILLED REAR|HAWK HPS|SS LINES|OPTIMA-REDTOP35|XENON ECODES|LED CITYLIGHTS|HOEN|SYMPHONY II+|DICE|35% SOLAR GARD|S4 DOOR FLARES|MOTUL 5.1|MOBIL 1 0W40|
    Established Member Two Rings ONDERGRONDS's Avatar
    Sep 21 2006
    08 S5
    Melbourne
    BBS FTW... much better looking compare with other one
    Feb 17 2005
    Sarasota, FL
    Yea BBS for sure, plus you can roll on them if you ever wanted to and still be on a better looking wheel
    Registered Member Three Rings Allwheel Driver's Avatar
    Sep 18 2006
    '02 A4 3.0 6sp, '02 A6 Avant
    Wanaque, NJ
    BBS get my vote.
    Plus the 17" Kosei will look really small. The Fat 5s are a chunkier wheel, so they don't look quite as little IMO.
    '02 A4 3.0Q 6speed, Sport Package, GIAC, Neuspeed SS
    S4 rear swaybar, USP Front Lip (DIY), S4 door blades
    '02 A6 3.0Q Avant Tip, H-sport swaybars, 18" S4 BBS CH wheels
    Veteran Member Three Rings Gondi Stylez's Avatar
    Oct 22 2006
    B6 3.0 Q
    Calgary, Canada
    BB wha?
    '02 DG A4 3.0Q 6MT | Member of Club 3.0
    .:. OEM+ : Custom I.C.E : Vogtland GT : Hartmann : SPP : Hawk : Goodridge : JHM : Apikol : 034 .:.
    Feb 18 2004
    Rosemead, Ca
    bbs, but i would look at whatever is easier to replace in case something happens at the track (bent or cracked wheel)
    Veteran Member Four Rings 1point8teeNW's Avatar
    Nov 11 2006
    North Webster, IN
    Look for used Jetta GLI wheels (aka 18x8 BBS RC) They bend fairly easily. I had a Jetta GLI come into the shop for a rotate and rebalance. That man left with a frown. 4 bent wheels. I don't know what it took to bend them, but they looked horrible.
    Jun 11 2005
    Vancouver, BC
    But the OEM Audi BBS RC wheels are not exactly the same as the BBS release version.
    From the digging I have done the 18x8.5 version is lighter than the 17x8 or 18x8 ones for some reason.
    Sep 18 2006
    Wanaque, NJ
    Quote Originally Posted by 1point8teeNW View Post
    It would be pretty hard to mount a 5x100 bolt pattern wheel to a 5x112 hub.
    Veteran Member Four Rings deephouse's Avatar
    Sep 18 2006
    Your Mom's house
    Winston,
    for long distance driving and daily driving just get the 17s.
    take that damn red valve stem off though =)
    I'm assuming the koseis are cheaper wheel, and so will the tires.
    17s aren't THAT small they are stock on our Avants and to be perfectly honest they look fine (if looks are what you're concerned about) as you are already dumped.
    I think i'm getting old. bigger wheels are becoming less appealing to me! LOL.
    If you're concerned about resale value later on down the line, get the BBSs.
    Brian
    Oct 29 2005
    10speed
    San Francisco, CA
    dude get the Koseis theyre lighter for what you want and more protected
    - Clint
    Feb 18 2004
    Rosemead, Ca
    track tires should be cheaper in a 17" size, as well as daily driving tires
    Sep 02 2005
    Montreal
    Kosei
    Registered Member Two Rings PhilABowl's Avatar
    Dec 05 2006
    Northwestern Connecticut
    18's for the win, Kosei's For the Walmart. Either way, FTW.
    [Phil A. Bowl]
    B6 A4 1.8T Tipchronic transgendermission, 08 Pathfinder, 01 Passat 1.8T Standard
    Nov 11 2006
    North Webster, IN
    I forgot the Jetta is 5x100
    Jun 11 2005
    Vancouver, BC
    Quote Originally Posted by deephouse View Post
    Winston,
    Brian
    The Koseis are actually more expensive since they would be coming new from Tirerack. Kosei are about $1300 shipped, the BBS $1000 shipped.
    If the Kosei were a 5 spoke design I'd buy them already and it is how they look that is kind of throwing me off. Also having my 'wet' track wheel being lighter than the dry track OZs is a bit strange too.
    But as I said before... I'd be going down to the track on one of these 2 wheels and then trowing on the track tires unless it is raining.
