Results 1 to 31 of 31
    Registered Member Two Rings urban_g6's Avatar
    Jan 04 2007
    Can you put staggered wheels on a Quattro?
    I got some rims that are staggered. Size is 19" X 8.5 & 19" X 9.5. Someone told me this could cause problems. Is any of this true?
    Feb 23 2004
    Audi A4 1.8T
    Los Angeles CA
    Re: Can you put staggered wheels on a Quattro?
    of course it is. just do a search of the thousands of people who've tried this. all of their quattro systems got confused and sent too much torque to the rear wheels and all the diffs burned up and the axles fell off the car.
    sucks
    Veteran Member Four Rings akademiks120's Avatar
    Nov 27 2005
    San Francisco, CA
    get ready to put your flamesuit on.....
    Original Member of the 3.0 Club
    2002 Audi A4 3.0Quattro 6spd - Brilliant Black
    No fat chicks......the car WILL rub.
    Feb 17 2005
    Sarasota, FL
    Its a damn shame to see wheels flying off the poor Quattro cars! Minding there own business and everything, just trying to get some extra lip
    Saint Cloud, Fl
    Dictionary.com Unabridged (v 1.1) - Cite This Source
    duhinterjection (used to express annoyance at banality, obviousness, or stupidity.)
    instagram ------------> low_enforcement
    Nov 14 2006
    600hp glorified Beetle, e-tron, 1G DSM
    Gig Harbor, WA
    You've already had this question answered 5 months ago in the B7 forum, and then AGAIN today in the B7 forum. Do you really think you're going to get a different answer in here?
    YES, YOU CAN STAGGER YOUR WHEELS IF YOU MATCH THE FRONT AND REAR TIRES PROPERLY.
    -Darrick
    Nov 27 2005
    San Francisco, CA
    Jan 04 2007
    Quote Originally Posted by Capt. Obvious View Post
    Dude, who the hell are you to tell me what thread I can post and where? If you don't want to read my thread, don't effing open it.
    And please tell me where I have gotten a straight answer regarding a quattro/staggered set up? Everyone on this and the 1 other thread has given me a mixed answer. One person say's it's going to f*ck up my car, and the next say's nothing will happen.
    This is obviously a question that I would like to get a large feedback on. So if I want to post this in every board I want, then I will.
    Feb 17 2005
    Sarasota, FL
    Quote Originally Posted by bbaudi382 View Post
    sucks
    Now read this reply to your thread one more time. Do you really think anything would cause the axles to fly off the car? If you took that as a serious response than you have serious issues!
    There are 100's of people all over AZ with every kind of Audi running staggered setups. As long as you keep the rolling diameters similar, you will be fine!!
    Seattle/Seoul
    yeah i saw this thread and was so anxious to see capt. obvious' response! but anyways, search for capt. obvious car with the HRE's, that stance was so sick, current setup looks sweet too, but those 18x10's were just NASTEE!
    peace
    DBC ownz joo!! <- Wow what year is that from??
    Quote Originally Posted by urban_g6 View Post
    You will not have any issues running a staggered setup whatsoever. I would try to keep the rolling diameters as close as possible.
    I can pretty much guarantee that this is the general consensus of the Audi community.
    Nov 14 2006
    Gig Harbor, WA
    Well, if you don't like me posting in your thread and don't want accurate quality information, then don't read my response sweetie.
    Not to sound pretentious, but if you want to know about making staggered/crazy offset/non-Audi wheels fit on your car, I am the one to ask. I know more about this kind of stuff than 99% of the people on this board and you will see soon that everyone agrees with me.
    -Darrick
    Nov 27 2005
    San Francisco, CA
    Seriously, the only people who are telling you not to run staggered setup and say that you will have problems..........Do not run staggered setups and do not have the experience. plain and simple.
    Listen to some of us who actually do run staggered setups on our quattro drive systems. We understand the importance of the wheel width, wheel offset, and most important, an understanding of appropriate tire sizing. If you run the correct size tires which should have equal rolling diameter in both the front and rear, you should not experience any problems with the drivetrain. The only issues you might incur are a bit more awareness of your cars understeer because of the larger surface area from tire to ground in the rear wheels.
    and about your point about where and when to post.....yeah, we are telling you not to post repetitive shiet on these boards. A simple search could get you all the answers that you need and are looking for. Just look at the post that I made earlier, i provided links to several threads that relate to this topic (one thread being one of my own). And in regards to posting this in the B7 section, the B7 and B6 share the same Chassis, so all wheel applications are the same for both models. One person told you you would have problems running staggered, but did you bother to do the research? You're getting mixed answers because everybody has different setups, if you want information about running a staggered setup.....try taking advice from the people running staggered setup.
    If you have 19x8.5 in the front and 19x9.5 in the rear, your tire sizes are gonna have a good dependency on your offsets. If your running less than a +35et. then you want to run 235/35/19 in the front and 245/30/19 in the rear. If you have +35et or above, then you want to run 235/35/19 in the front and 265/30/19 in the rear. This will give you the aggressive staggered look in the rear and not cause any issues. Although, with both setups, alignment is definately key. You want to run your camber in the rear to atleast -1.5 to prevent any rubbing issues. The rear wheels max out camber at -2.0 and many people run at this setup to have no rubbing at all. All in all, it can be done.................you just have to know what the fuck it is you're doing.
    Veteran Member Four Rings HeymyAudi's Avatar
    Sep 23 2006
    Las Vegas, NV
    WHERE THE HELL DID YOU GET THAT WRESTLER THING FROM ?? I Pulled that shit up in a meeting and they were dying!!!!! Its so funny reading this thread I went to look about some Maya Wheels yesterday and the guy who is a very very knowlegable rim dealer in south fl told me NO YOU CANNOT RUN STAGGERED.. So I said " Dont want to tell you no but check Audizine.com many guys are running it and no problems" so most people think you cannot but you can ..
    Veteran Member Four Rings LampyB's Avatar
    Apr 25 2007
    MA
    you can't run different sized tires. your car will pull you all over the road....the previous owner of my car had 225 in the front and 235 in the rear and any little bump in the road would almost pull me into the lane next to me. As soon as I replaced the tires to all 235's the problem went away.
    LampyB.
    Custom Trunk Badges For Sale!
    | 2004 A4 USP 1.8TQ | 6SPD | GIAC 1+ | APIKOL | HYPERBOOST | FORGE TIP | NGK | 20% TINT | VMR | OFE SS | PODI | N249 Delete |
    Registered Member Two Rings PhilABowl's Avatar
    Dec 05 2006
    Northwestern Connecticut
    1 inch difference is not enough - your front tires should be recessed about 6 inches in from the edge, and the back tires should stick out approximately 2/3rds of a tire width.
    When staggered properly you should get not only better traction but a hot look:
    [Phil A. Bowl]
    B6 A4 1.8T Tipchronic transgendermission, 08 Pathfinder, 01 Passat 1.8T Standard
    Nov 14 2006
    Gig Harbor, WA
    Quote Originally Posted by LampyB View Post
    That's not from staggering the tire sizes, that's from improper alignment and/or tire wear. I haven't had a car with staggered wheels (whether it be my RWD Supra, my FWD Jetta, or my AWD Audi) do anything of the sort.
    -Darrick
    Sep 02 2005
    Montreal
    I wanna see someone with the balls to put the wider wheels in the front, where it actually helps...
    Veteran Member Four Rings 3.0L AUDI A4's Avatar
    2004 A4
    Central Jersey
    Staggared wont hurt your car, and truthfully our cars dont really* need an alignment check.
    Nov 27 2005
    San Francisco, CA
    Quote Originally Posted by HeymyA4 View Post
    haha you kinda quoted the wrong person. I have it on my harddrive, it used to be my avatar on another forum.
    Dec 05 2006
    Quote Originally Posted by 3.0L AUDI A4 View Post
    Just for clarification, are you really saying that our cars, meaning Audi's, don't need alignment checks?
    If so, please PM me, I have a well known piece of real estate (in Brooklyn they just call it "The Bridge") I will sell to you at a fraction of its value!!!
    [Phil A. Bowl]
    Established Member Two Rings Tuftylb's Avatar
    Aug 14 2007
    B5 A4 2.8Qmt
    Miami, FL, USA
    Quote Originally Posted by PhilABowl View Post
    Lmao...
    Surgeon General Said Nothing about "Smoking the Competition"...
    Veteran Member Four Rings A4TUNE's Avatar
    Sep 14 2006
    Mass
    Quote Originally Posted by akademiks120 View Post
    hahahaha @ that gif. I don't know where thats from but I laughed my ass off.
    -Max
    2004 A4 1.8T M6 Quattro Ultrasport
    REVO Stage 1 | AWE Boost Gauge | Carbonio CAI | Valeo Single Xenon Black Ecodes | RS4 Rear Sway Bar | 18x8 OZ Superleggera | DTH USP Splitter
    Nov 27 2005
    San Francisco, CA
    **** scratches head ****
    Oct 18 2019
    Philadelphia
    I have a 2016 S5 and want to stagger 20 inch wheels. 20 8.5 front 20 9.5 rear. What size tires should I use to get the perfect balance?
    Veteran Member Three Rings 19jdog's Avatar
    Jul 28 2014
    2006 Mini Cooper s - 2013 Mini Cooper S - 2007 C6 Avant - 2006 GSXR 750
    SACRAMENTO
    Quote Originally Posted by Sincere215 View Post
    LOL Why are you posting in the B6 section?? S5 has its on section!!!
    11 Q7 Prestige TDI S Line - Stance SF 03 20x10
    04 B6 A4 USP 2.7t
    USP CLUB MEMBER #198
    BEL 2.7t SWAP- Rohana RC7 19x9.5 33mm - 034 REAR SWAYBAR - TIP TO 6 SPEED SWAP
    Apr 17 2016
    kc
    Because the s5 guys got more money than sense? Lolol
    Senior Member Three Rings IndoReef's Avatar
    May 20 2015
    2018 VW GTI Autobahn
    Ontario/Canada
    I've been on the internet to long today
    Winter: 02 B6 1.8T quattro 01A Brilliant Black, Gutted Stock Cat, 2.5" stainless custom exhaust to 4 inch tips,DSMIC's
    USP Front lower Valance, REVO Stage 1, Solo Werks S1 Coilovers,B6 S4 Front Brakes, Forge Hybrid Diverter Valve, SAI & AC Delete
    Summer:2018 MK7.5 GTI AutoBahn
    Veteran Member Four Rings MacFady's Avatar
    Aug 10 2011
    330i ZHP
    Prince Edward Island
    How about Audi, the RS3 is optioned with 255F/235R. On a side note OP, what is the offset on the 9.5 wheels in the rear?
    Established Member Two Rings Scott Long's Avatar
    Aug 29 2007
    SLC, UT
    I have 19x8.5 front and 19x9.5 rear.
    Front tire is 235/35/19
    Rear tire is 265/30/19
    Overall tire diameter is close enough to not cause any issues.
    02 A4 1.8Tq manual - Sport suspension, 19x8.5 w/ 235/35/19 (F) & 19x9.5 w/ 265/30/19 (R), limo tint, test pipe, custom turbo back exhaust w/ 4" tips, silicone TIP, 550cc injectors, tuned by Reflect w/ 3500 RPM launch control, Raxle axles, Spec Stage 2 clutch.
    Aug 10 2011
    330i ZHP
    Without knowing the wheel offset or your suspension set up I can't say what will "fit", but 245/35 in the front and 275/30 in the rear will keep the tire circumference difference at <1%.
