Results 1 to 12 of 12
    Active Member Two Rings vcharan's Avatar
    Apr 20 2007
    Edmonton
    Best place to install the RNS-E GPS Antenna
    Best place to install the RNS-E GPS Antenna RNs-E ON 2006 B7
    Veteran Member Four Rings TSlice's Avatar
    May 18 2007
    Houston
    Re: Best place to install the RNS-E GPS Antenna
    I think the standard spot is behind the instrument cluster on top of the steering column, but any place under the dash should work as long as there is no metal above the antenna. You could also put it under the decklid, but I don't know why you'd want to.
    Registered Member Four Rings
    Jun 14 2007
    2007 A4 2.0T QM 2008 A8L
    New York
    I was under the impression that all that was wired to the antenna on the roof.
    Sep 15 2005
    Norwalk, CA
    Quote Originally Posted by Tiesto View Post
    I believe if you purchase your car with rns-e, the satellite antenna is wired to the shark fin. However, if you are retrofitting, you would need to run your own receiving unit/antenna, and it'd be easier if it's near the dash.
    May 18 2007
    Houston
    That is correct, if your car didn't come from the factory with navi, the sharkfin won't have a GPS antenna. You can either retrofit the GPS sharkfin, or add a GPS antenna. I think everyone adds a GPS antenna because it is much easier and a GPS antenna relatively cheap; I hate to think how much Audi charges for a new sharkfin.
    Veteran Member Four Rings i3oricua's Avatar
    Sep 17 2006
    2022 Kia Sorento; 2015 Ducati Monster 821 Dark
    Aurora, Colorado
    I'm gonna take a picture to show you but if you look in that giant gap where your rns-e will be when you have the radio out you'll see that there is some metal up on the left hand side towards the driver's side. That antenna magnet will grab on there just fine and you'll get a great signal.....at least I do. Hope this helps.
    Registered Member Two Rings
    Aug 03 2004
    2007 Ibis White A4 2.0T 6spd
    fullerton, ca
    I believe you are incorrect on this. All the new b7's with a sharkfin have a gps antenna available regardless if you had an rns-e or not.
    I havent done it.. but from reading on navplus.us thats the general consensus.
    Quote Originally Posted by TSlice View Post
    2007 Ibis White Audi A4 2.0T 6MT w/ S-Line Package
    -RNS-E Retrofit
    -RS4 Rear Sway Bar
    -19" RS4 Replicas
    Senior Member Three Rings Raistlin's Avatar
    Apr 27 2005
    New Jersey
    I heard the same thing, new B7s even without NAV from fractory are Pre-Wired and ready for the NAV headunit with GPS antenna in the fin. You don't even need the adapter harness from what I have read.
    Jun 14 2007
    New York
    Quote Originally Posted by Raistlin View Post
    That's what I thought!
    Sep 15 2005
    Norwalk, CA
    yes, the sharkfin can act as the antenna in all b7's, but the "pre-wire" probably ends somewhere relatively close to the fin, so you would need to run your own cable for a pretty long distance and will need to pull the headliner in order to hide the antenna cable. That's a major hassle
    Registered Member Two Rings David-Alexander's Avatar
    May 16 2007
    04' A4 3.0 Quattro Ultra Sport
    Miami Beach, FL
    The roof mounted antenna works with Satellite Radio, Phone and GPS. If you want to hook-up your RNS-E directly to your antenna you need to purchase a GPS Extension Cable - FAKRA to FAKRA. The hook-up is located on the rear passenger side pillar, remove it carefully. You will see two connections, near the roof; one blue for the Fakra (GPS) and one pink for factory phone. Hook-it up, run the cables and your all set. I always pick-up 7-8 satellites, under the dash I always got 4-5.
    04 A4 3.0 Quattro Ultra Sport l RNS-E l OEM iPod Kit
    USP CLUB MEMBER #72
    May 18 2007
    Houston
    Sorry for the misinformation! Good to know...
