Results 1 to 9 of 9
    Feb 08 2006
    Charleston, SC
    Horn stopped working, not fuse
    What else could go wrong with a horn? I checked the fuse already. Also, how hard would it be, if the horn just went bad, to replace it myself?
    '02 A4 1.8T QM - RIP
    '04 A4 3.0 QA - RIP
    '08 GTI - RIP
    '11 GTI - RIP
    '11 BMW 335xi - RIP
    '14 BMW 335xi - RIP
    '18 Audi S4 - RIP
    '14 Audi A4QM - RIP
    Veteran Member Three Rings darkstar's Avatar
    Dec 24 2004
    1998 silverado, 1986 c10
    Folsom, CA
    Re: Horn stopped working, not fuse
    air horn time! haha
    Veteran Member Three Rings AudiLoco18's Avatar
    Feb 06 2007
    03 A4, 06 Gs300, 07 Camry
    Miami
    mine died a couple of days ago. only one works now. but its like 50 per horn low/high. kinda $$.
    Registered Member Two Rings
    Mar 21 2007
    Silver 02 Audi A4 Avant 1.8TQM
    Germantown, MD USA
    My low tone horn was dead when I bought my Audi. I pulled the high and low horns out of my Dodge and installed them. It's kinda wierd to honk and hear the Dodge, but it sounds depper than most import horns which I like. I had to solder on the Dodge connections and it works great.
    Hit up a junk yard and pull the horns off a caddy or something.
    Mike
    2002 Audi A4 Avant Quattro 1.8T 5spd Silver
    2000 Pontiac Formula Firehawk 5.7L Supercharged 6spd Navy Blue Metallic
    Sep 23 2006
    Houston TX
    Not hard to do, just take bumper cover off and it should be mounted to inside of cover. There's DIY for front bumper removal on a4mods.com.
    Veteran Member Four Rings LAZY TURBO's Avatar
    Jun 01 2005
    La Crescenta, CA
    ferrari air horn FTW!!
    ~Sevan
    USP CLUB MEMBER #1 <~CLICK IT
    Mar 21 2007
    Germantown, MD USA
    Quote Originally Posted by Ill 3.0 View Post
    Is it easier to remove the bumper cover or headlights? Cause I removed my headlights to replace the horns. Either way it's a relatively easy swap.
    BTW, At first I bought some Hella supertwins like what a lot of the WRX guys like/use. I hated the sound they made which was the first and foremost problem. But also the mounting bolt and overall frame were bigger and it would not fit in the stock location. So I got rid of those and put my Dodge horns in. They fit like charm and I like the sound.
    Mike
    Registered Member Three Rings
    Jun 06 2007
    not enough room here
    ga
    check to make sure they were not disconnected last time the bumper may have come off.
    as mentioned they die all the time.. proably had one dead for a while and the second one went out.
    chris
    06 A3, 00 jetta 1.8t 28rs, 97 ram 2500 cummins, 97 fzr 600, 91 gti vr6 in progress, 82 rabbit ls 1.8t in progress
    Nov 14 2006
    600hp glorified Beetle, e-tron, 1G DSM
    Gig Harbor, WA
    Horn broken... watch for finger.
    -Darrick
