Results 1 to 40 of 40
Thread: VDO Boost gauge
    Veteran Member Four Rings sixfiveoh's Avatar
    May 19 2007
    Bay Area
    VDO Boost gauge
    Does anyone have any night shots of the VDO boost gauge? I'm not sure how it lights up, full red or white backlight with a red needle. I'm looking to get it to match a facelift interior (2001), where the backlight on the gauges are all white and the needles are red, like the AWE boost gauge.
    SIXFIVEOHphoto
    2001 Brilliant Black 1.8TMS A4
    Unitronic|APR|H&R|Neuspeed|Falken|Carbonio|Apex'i| VDO|VMR
    FS: Buncha B5 parts, CLICK
    Registered Member Two Rings
    Lambo diablo, 01 1.8T
    Daygo
    Re: VDO Boost gauge
    Ill get up a pic tonight for ya.. My laptop is broken so I have to take more pics
    Jun 19 2007
    2012 JSW TDI
    Raleigh, NC
    Re: VDO Boost gauge
    i have one with a red led.. it is full red.
    May 19 2007
    Bay Area
    Re: VDO Boost gauge
    Quote Originally Posted by socal_A4 View Post
    Appreciate it
    Quote Originally Posted by pinky View Post
    I heard they do make one with a white led, but it's not true white or something?
    SIXFIVEOHphoto
    Oct 30 2006
    B8 A4 Avant 6spd
    Re: VDO Boost gauge
    I opted out for the Pro Sports Boost gauge, awesome price, looks great, white when lights are off, amber red when headlights are on.
    -18 718 GTS
    Jan 26 2007
    e46
    540, VA
    Re: VDO Boost gauge
    i've got the red LED in mine, it looks good and matches the interior perfectly, but i also have a 97 with all red VDO gages
    B5 - RIP
    May 19 2007
    Bay Area
    Re: VDO Boost gauge
    Quote Originally Posted by Militant-Grunt View Post
    Hey, how is the visibility of the gauge in the vent on the driver's side? I just sat in my car and imagined it being over there compared to the left center vent and it felt like I was stressing my eyes out alot more looking down there... how's it work for you? I was really wanting to get it done in the left vent, but here's my point of view:
    The steering wheel kind of blocks the gauge... or have you found this to be not a problem?
    SIXFIVEOHphoto
    Jan 26 2007
    e46
    540, VA
    Re: VDO Boost gauge
    i have mine on the left vent, i'll get a picture later tonight. it works okay, not exactly what i would prefer, i think center vent would be more practical, but it does look a little better, more a part of the gage cluster, on the left vent.
    B5 - RIP
    Veteran Member Four Rings Ewok_Fetus's Avatar
    Mar 04 2007
    nothing
    nowhere
    Re: VDO Boost gauge
    Looks better in person, but these are red bulb condoms... Don't do the white because the incandecent bulb is too yellow and white LEDS are too blue. If you can find a TRUE WHITE LED that would work but those are VERY expensive and VERY hard to find...
    ΜΟΛΩΝ ΛΑΒΕ
    May 19 2007
    Bay Area
    Re: VDO Boost gauge
    Quote Originally Posted by Ewok_Fetus View Post
    I see... maybe I'll go with an AWE gauge.
    You have PM from me, btw.
    SIXFIVEOHphoto
    Mar 04 2007
    nothing
    nowhere
    Re: VDO Boost gauge
    Honestly, it looks like a hot set of tits with all red since it matches everything else on the outside of the cluster... This is the best pic I could come up with but I don't like the white myself outside of the cluster area...
    ΜΟΛΩΝ ΛΑΒΕ
    May 19 2007
    Bay Area
    Re: VDO Boost gauge
    Hmm... you're right. Now that I see that, I'm thinking I might want a vent pod for the center vent... what's the other gauge you have there, oil pressure?
    SIXFIVEOHphoto
    Mar 04 2007
    nothing
    nowhere
    Re: VDO Boost gauge
    Yep! Boost and oil pressure, soon to come is EGT on the right vent and on the drivers vent I will have AFR, all in red...
    ΜΟΛΩΝ ΛΑΒΕ
    May 19 2007
    Bay Area
    Re: VDO Boost gauge
    Hmm... I'm thinkin I might like the center vents better, although it may look less flashy by the drivers side... hmm... idk if you got my PM or not, should I resend it?
    SIXFIVEOHphoto
    Registered Member Three Rings Jereme's Avatar
    Oct 27 2006
    98 a4 1.8tqm
    Chester, NH
    Re: VDO Boost gauge
    I got a cheap one off ebay, one of those 7 color jobs...but it looks and works pretty mint..
    http://www.dirtycustoms.bravehost.com
    Custom Magnaflow Exhaust (muffler 14862),Custom 2.75" Test Pipe/Downpipe,Custom CAI,Forge 004,Forge MBC,GIAC chip,Neuspeed Race springs,Ebay short shifter,Drilled and slotted rotors with EBC greenstuff pads,18"ADR M-Sports,Nankang NS-II,Black Depos with 6500k HID kit,Newsouth Performance Gasket, P&P Head, 2.8 Transmission, Southbend Stage 3.
    Running Strong with 163k...
    Mar 26 2005
    01 A4 1.8t avant; 04 B6 S4
    All over the Bay Area
    Re: VDO Boost gauge
    oOo i'm about to purchase the awe guage myself too ^^
    TEAM|AXION
    May 19 2007
    Bay Area
    Re: VDO Boost gauge
    I was thinking about the AWE for a while too, but the VDO does look clean for a fraction of the price. And Ewok_Fetus is right, white backlighting would look kind of weird anywhere outside of the cluster area...
    SIXFIVEOHphoto
    Active Member Four Rings
    Dec 11 2006
    Boston
    Re: VDO Boost gauge
    I have seen the AWE "a4" version. Looks very nice, very bright.
    Stage 3+ RS6's
    Oct 30 2006
    B8 A4 Avant 6spd
    Re: VDO Boost gauge
    Quote Originally Posted by sixfiveoh View Post
    Its fine, I see it in the corner of my eye, though if you want to be 100% sure you've got to kind of look away, but I'm sure its the same way for the center vents. The problem with the center vents is that is a PITA to connect. On the drivers side, all the fuses are there, the ecu grommet is right there too, every easy to hook everything up.
    -18 718 GTS
    May 19 2007
    Bay Area
    Re: VDO Boost gauge
    Can't you just tap the wire for the light of the adjuster right next to the vents?
    SIXFIVEOHphoto
    Mar 15 2007
    2001 A4
    seattle
    Re: VDO Boost gauge
    Yeah you can so that it turns on with the dash lights and adjusts with them.
    Oct 30 2006
    B8 A4 Avant 6spd
    Re: VDO Boost gauge
    I set mine up differently, main power is connected to the ACC whenever the ignition goes on the boost gauge lights up as well. When I turn on my headlights it goes amber. (Headlight fuse.)
    -18 718 GTS
    Jan 26 2007
    e46
    540, VA
    Re: VDO Boost gauge
    is that a blaupunkt bahamas head unit?
    B5 - RIP
    Feb 12 2004
    2018 M3 CS, i3 REx
    Orange County CA
    Re: VDO Boost gauge
    Here's mine:
    Former:
    BMW F80 M3 CS
    BMW F80 M3
    BMW I01 i3 REx
    BMW F30 340i M Sport ZTR
    Audi B7 S4 25Quattro
    Audi B5 A4
    Oct 30 2006
    B8 A4 Avant 6spd
    Re: VDO Boost gauge
    Quote Originally Posted by JMG View Post
    Here's mine:
    Ive got to get me an updated cluster, it looks awesome.
    -18 718 GTS
    May 19 2007
    Bay Area
    Re: VDO Boost gauge
    Quote Originally Posted by The1amRadio View Post
    I believe so, want it?
    Here's mine:
    Damn, looks clean. I'm so jealous of your working LCD screen. And headunit.
    SIXFIVEOHphoto
    Feb 12 2004
    2018 M3 CS, i3 REx
    Orange County CA
    Re: VDO Boost gauge
    Hahahha. I had the dealer replace the cluster because it had dead pixels a few years ago. Hopefully this will last a few more years after I give the car to my little sister.
    Former:
    BMW F80 M3 CS
    BMW F80 M3
    BMW I01 i3 REx
    Audi B5 A4
    May 19 2007
    Bay Area
    Re: VDO Boost gauge
    What vent pod holder thing is that?
    SIXFIVEOHphoto
    May 19 2007
    Bay Area
    Re: VDO Boost gauge
    It's actually a Key West
    http://www.blaupunkt.com/us/7646470510_main.asp
    SIXFIVEOHphoto
    Dec 11 2006
    Boston
    Re: VDO Boost gauge
    Here is the AWE gauge on my S
    Stage 3+ RS6's
    Feb 12 2004
    2018 M3 CS, i3 REx
    Orange County CA
    Re: VDO Boost gauge
    Overspun makes and sells them. PM him.
    Former:
    BMW F80 M3 CS
    BMW F80 M3
    BMW I01 i3 REx
    Audi B5 A4
    May 19 2007
    Bay Area
    Re: VDO Boost gauge
    Here's mine:
    Hey, btw, does the VDO come all red like that, or do you need a red LED or some other modification to make it illuminate like that?
    SIXFIVEOHphoto
    Mar 15 2007
    2001 A4
    seattle
    Re: VDO Boost gauge
    You would need to get a red LED costs like $2.
    Mar 26 2005
    Re: VDO Boost gauge
    Here's mine:
    how the heck are you averaging 35mpg going around 80mph and possibly in 4th gear? rpm seems a bit high for 5th.
    TEAM|AXION
    Mar 04 2007
    nothing
    nowhere
    Re: VDO Boost gauge
    Quote Originally Posted by speedydragon View Post
    Don't trust what that thing says... Also, could be what his "current" mpg is. Not his average...
    ΜΟΛΩΝ ΛΑΒΕ
    Veteran Member Four Rings pipe7284's Avatar
    Sep 14 2006
    `07 Audi A4 S-Line 6MT Quattro | '01 Audi S4 AVANT 6spd
    Lansing, MI
    Re: VDO Boost gauge
    alot of you have a christmas tree looking cluster!!!!!!!!!!
    just like me!!!!!!!
    '01 Audi S4 6spd Black AVANT DAZ E85 Tune Frankenturbo F21s / 034 RS4 inlets / BOSCH EV4 72# injectors / Walbro 450L fuel pump / Daz 89mm maf housing / AFE Intake Cone / SRM SMICs / 034 street density trans and motor mounts / SSAC downpipes / Vibrant catback exhaust / H&R Ultra Low Coilovers / 18x9.5 Rota Grids / 17z Brembo front BBK / 034 Rear BBK / JHM Short shifter / JHM stg 3 clutch / PODI Boost gauge / [/CENTER]
    SOLD
    Feb 12 2004
    2018 M3 CS, i3 REx
    Orange County CA
    Re: VDO Boost gauge
    No LED needed. The guage came with a green and a red condom to put over the white light.
    Former:
    BMW F80 M3 CS
    BMW F80 M3
    BMW I01 i3 REx
    Audi B5 A4
    Feb 12 2004
    2018 M3 CS, i3 REx
    Orange County CA
    Re: VDO Boost gauge
    Don't trust the guages. I moved the needles in PS for the photo just like how I removed the garage through the windshield.
    Former:
    BMW F80 M3 CS
    BMW F80 M3
    BMW I01 i3 REx
    Audi B5 A4
    Mar 26 2005
    Re: VDO Boost gauge
    LOL! haha..what a cheater :P
    TEAM|AXION
    Mar 04 2007
    nothing
    nowhere
    Re: VDO Boost gauge
    Hahha, yeah I was gonna say too... Doing 80 and those rpms and under full vacuum?!
    ΜΟΛΩΝ ΛΑΒΕ
