Originally Posted by
Human Garbage
So cost isn't an advantage. I understand... I think.
I run copper core plugs. They are cheap enough I buy bulk and throw a new set in every oil change. Surely even iridiums/platinums wear during the long service interval and aren't as good over time as new set after new set of coppers in terms of performance. While I respect your opinion, I'll pass on that advice thanks.
As long as you are fully aware of the situation, using copper electrode plugs as you prefer is your choice.
Besides being very hard and resistant to erosion and gap width increase from the spark, the platinum and iridium precious metals used on more expensive spark plugs resist rounding of the electrode edges and corners for a very long time in use. When the sharp when new copper/steel electrode edges wear off and get rounded, the required secondary coil output voltage necessary for a spark to jump the plug gap increases a lot, and is much higher than the fine wire point platinum or iridium electrode plugs.
Platinum or iridium electrode plugs will maintain a stable plug gap width for many tens of thousands of miles, at least 30K miles and often a lot more, and provide superior ignition spark consistency over that operation interval compared to copper electrode plugs that begin to suffer deterioration of he spark within a few thousand miles from new.
Frequent plug changes often cause problems with the aluminum spark plug hole threads after a few years as well. After some number of plug changes at OCI frequency, striped plug hole threads are more likely to occur.
