Results 1 to 6 of 6
Thread: p0444!
    May 21 2007
    Florida
    p0444!
    damn car is already throwing codes. i did the clear corner headlights mod yesterday and the 2nd start up after installing them back in, i got a check engine light. i figured it was going to be some autoleveling code or maybe a "bank x too lean" code since you have to take the little intake thingy off too...nope. its p0444, an evap code. anyone have this before? and how is it fixed? are there any hoses up by the headlights i may have popped off or something? i really think this may have been the case, because it takes two drive cycles to set the light, and after installing the headlights i started the car up and backed it outside. theres drive cycle 1. then i started it up again, and drove to my friends house (noticing the check engine light). theres drive cycle two. makes sense that i did something to cause it right?
    also, i baught my car just over 2 weeks ago, and they gave me a 30 day warrenty...you think evap system will be covered under warrenty?
    edit-where is the charcoal canister located on these cars? is it in the front on the drivers side per chance?
    2018 Navarro Blue Q5
    Mar 21 2006
    Revo Tuned 2.0L w/35r
    Lakeland, FL.
    Re: p0444!
    Take it back for the warr. The evap canister is under the spare tire well.
    BetaAlphaTauMember#6
    I'm back bitches!
    35r and REVO...what?
    May 21 2007
    Florida
    Re: p0444!
    alright cool. i searched google and found that one guy solved the problem by re-seating the electrical connector to the purge valve so im gunna try that. ill give the place i baught it a call tomorow.
    Veteran Member Three Rings kpatz's Avatar
    Nov 08 2006
    '02 Audi A4 B6, '06 Mazda6 wgn
    NH
    Re: p0444!
    P0444 - Evaporative Emission System Purge Control Valve Circuit Open
    Check the connection to the purge valve located behind the airbox. Maybe you disconnected it and forgot to reconnect it.
    2002 A4 1.8T Quattro, 5 Speed, Goodwood Green (rare color!)
    Current mods: APR Stage 1+, TT225, 710N, APR Snub, JH solid short-throw shifter, JH solid linkage upgrade, Sachs clutch, Euro shift knob/boot, 4300K HID D2S, 18" VMR RS4 reps w/General Exclaim UHP, hardwired Valentine 1 w/remote display
    May 21 2007
    Florida
    Re: p0444!
    ahh yes! thats where the purge valve is! i was lookin on the canister and couldnt find it. i deffinatly fudged with that thing when i did it. ill check it out! thanks a lot man!!
    May 21 2007
    Florida
    Re: p0444!
    that did it! the connector somehow popped out and wasnt makin a solid connection! thanks for the info!
