Results 1 to 8 of 8
    Veteran Member Three Rings SilverSurferS4's Avatar
    Jun 11 2007
    Neuspeed Rear Sway Bar Adjustment? Help..
    Hey guys whats up.. Im fairly new here on the fourms.. I just bought a neuspeed rear sway bar, i didnt install it yet, but i had one quick question about the adjustment on the bar because the instructions werent too clear for me. I searched in the DIY installs of the bar but no where really explained how to adjust it. In the instructions it says it has 3 different settings (hard, medium, soft).
    The instructions state:
    Soft setting = holes closest to end of bar
    Hard setting = holes furthest away from bar..
    Then it says place endlinks in different holes to yeild medium setting... this is the setting that i want.. however im not sure if you place one end link in hard setting and the other endlink in the soft settin to get the medium setting... it just didnt seem right?
    Can someone who had installed one of these bars help me out... I also read that the soft setting is not too much of a difference from stock, is that true?
    Any help is appreciated thanks in advance,
    Ryan.
    Veteran Member Three Rings RuS4ty's Avatar
    Mar 13 2006
    VA / MT
    Re: Neuspeed Rear Sway Bar Adjustment? Help..
    just go all hard, but yeah if you want medium go with one on the outside and one on the inside.
    Why would you go full stiffness though?
    *NEW Addition: Misano Red RS4
    01.5 S4
    For sale(pm me for details):
    FRONT AIRBAGS !CHEAP!
    Stock S4 swaybar
    "I'd have one of those... if I were the sort of person that looked at my sister and thought, mmm..." - Jeremy Clarkson about the Roush Mustang.
    Registered Member Two Rings saj1420's Avatar
    Sep 17 2006
    2000 s4, 2001 F 350, 1998 F150
    MA
    so it seems like there are actually 4 settings?
    and RuS4ty did you mean to say why wouldn't he go full stiffness?
    Jun 11 2007
    Quote Originally Posted by RuS4ty View Post
    Well the car is a street car not for the track, I heard it takes some time to get used to the sway bar set up, i thought the medium setting would be good for me to start learning how the car acts and reacts in certain situations.
    Veteran Member Four Rings SeanF's Avatar
    Sep 13 2004
    Concord (LMS area), NC
    if its the 19mm bar, you'll still want it on full stiff as long as your endlinks can handle it...
    2007 Black Mica Mazdaspeed3 GT, w/ navigation
    Built, Blown, and Squeezin' on a 3071r
    Veteran Member Three Rings jeproks's Avatar
    Jul 14 2004
    Bahay Kubo
    Check if your endlinks are plastic or metal. Go with medium if they are plastic and full with metal. You can buy the metal ones from purems.com
    Registered User Four Rings Mike@PureMS's Avatar
    Jul 19 2007
    San Diego, CA
    The two holes at the very end of the bar are the soft setting. The two holes closer to the main bar will be the hard setting. If you use 1 of each of the holes, you end up with a medium setting.
    This will however put some preload on the bar unless you have adjustable endlinks.
    I'd suggest starting off with the softer setting and see how you like it, then simply move up to the harder setting as you see fit.
    Jun 11 2007
    Quote Originally Posted by Mike@PureMS View Post
    Yea thanks for a;ll of the help guys.. its really appreciated.
    By the way I did purchase the upgraded endlinks from ECS.. I guess I will start off on soft and then work my way up.. to whereever i see fit.
    Thanks, Ryan.
