Results 1 to 15 of 15
    Jul 08 2007
    2018 Camaro ZL1-1LE, 2015 Toyota Tundra
    Asheville, NC
    Door speakers: Will 6 1/2" fit?
    I know that factory door speakers are 6 3/4"....but I'd like install a set of 6 1/2" components. Will those work without modification or am I gonna have to fab some stuff?
    Also...anyone put tweets in the factory tweet location? Any issues?
    Saint Cloud, Fl
    Re: Door speakers: Will 6 1/2" fit?
    yep they will fit - just cut out the factory speaker and reuse the framing to mount the new speaker
    instagram ------------> low_enforcement
    Veteran Member Four Rings Raus's Avatar
    Aug 17 2005
    B6 1.8TQM, Mk2 GTI
    You don't have to cut the speaker. 6.5" speakers fit just fine onto the speaker mounting pods. Most aftermarket speakers have a variety of mounting holes and spacing on 6.5s for this reason.
    If you're speakers have big magnets/frame you might have to cut out the back of the pods (I had to and it worked just fine) or fabricate new mounting rings out of mdf.
    Ich bin der Musikant mit Taschenrechner in der Hand
    Saint Cloud, Fl
    im just lazy and reused the factory stuff
    Aug 17 2005
    B6 1.8TQM, Mk2 GTI
    Yeah, me too. I just took out the factory bose speakers and popped in 6.5" components, is the bose mounting different than the regular speakers?
    I had to get creative with the tweeters as I couldn't find a good way of mounting them with the provided hardware. so I padded around them with double sided 3m tape and they fit snugly in the factory location.
    Jun 15 2007
    Portland, Maine
    Do the non Bose radio's have self amped speakers or are they powered by the HU??
    I wouldnt mind replacing my interior speakers for more clarity and maybe adding a sub but if i need to install an amp for interiors..i would rather not.
    Also anyone make a custom sub box for the trunk on the side where they give you the tray??
    2012 Audi S4 Prestige | Moonlight Blue | DSG | Sports Diff | Blk SC Badges | 034 Trans Mount | 19x9.5 Avant Garde M510 | H&R OE Springs | 13+ Stronic Shift Knob
    Veteran Member Four Rings dummptyhummpty's Avatar
    Sep 17 2004
    Los Angeles, California
    Quote Originally Posted by booosteda4 View Post
    From what I recall: Front is amped from head unit and rear is amped from amp in trunk.
    As for the sub box, there was just a thread on this. Search for A4 Moda, his shop makes them.
    If you need to contact me, send a PM.
    1965 Corvette Stingray
    2003 Audi A4 1.8tq (RIP: 2/10/04)
    2004.5 Audi A4 3.0q (Sold: 8/15/09)
    2003.5 BMW M3
    2013 Ford Edge Sport AWD
    A4 Stereo Information Thread
    Apr 04 2007
    2003 A4 1.8TM, 1987 325, 1987 528
    Columbia/Nashville, TN
    I am redoing my system in my car now and I just cut out a speaker ring from 3/4 inch MDF. You can get an installer to make you some up if you don't feel like doing it yourself and the speakers will be mounted in the door a LOT better.
    I would never mount a speaker in plastic if I could help it.
    Robbie
    2003 A4 1.8TM
    Motor F21 Turbo, FMIC, Green Tops, Meth Injection, Motoza Tune, Carbonio, Forge DV, Ecode Test Pipe, Neuspeed Catback, 034 Motorsport Solid Mounts
    Suspension Statis SS, Antera Type 309 18x8
    Interior/Audio Pioneer D/D Head, JL 450/4, JL 500/1, JL ZR650's, 2 - 8 JL 8W7's
    Jul 08 2007
    Asheville, NC
    Good info guys. Fabbin' up some mdf mounts isn't a big deal, I just hoped that I wouldn't really have to.
    Can't seem to find the custom sub box thread that was referenced above....maybe I'm just blind or using the wrong search terms?
    Sep 17 2004
    Quote Originally Posted by Ebbsnflows View Post
    Here you go: http://www.audizine.com/forum/showthread.php?t=147776
    2003.5 BMW M3
    Oct 15 2006
    From a few to one...
    Arlington, VA
    what brand speakers did u guys use for 6.5" components?
    '97 A4 1.8TQ, '02 A4 1.8TQ Avant, '03 A4 1.8TQMS, '04 A4 3.0Q Cabrio - Sold
    '18 S4 Prestige - APR Stage 1 ECU/TCU, APR Intake
    Veteran Member Four Rings Tgr_Clw's Avatar
    Jul 20 2005
    2003 Audi A4 1.8TQM
    Toronto, Canada
    Depends on the type of music you listen to, your budget, amount of power you're feeding them, etc.
    I used Focal speakers in my previous car and liked them a lot.
    Quote Originally Posted by NyteEscape View Post
    Appearance: OEM+
    Interior: B6 S4 Recaro Seats
    Performance: MTM Stage 3 / Milltek Exhaust+Milltek HFC / JJ TIP / ASP FMIC / SB FE SS
    Suspension: Vogtland Coilovers / HSport S4 Sways
    Braking: Stoptech 332 BBK
    Wheels/Tires: BBS CH 18x8.5, ET35 / GY Eagle F1 GSD3 235/40/18
    Apr 04 2007
    I have to sets of the JL Audio ZR650's with a JL 450/4 pushing them. But it is best to go listen to many different brands before you go spending this kind of money I did on speakers. I worked in a car audio shop and I listened to every brand we had for 6 months before I made my decision.
    Robbie
    2003 A4 1.8TM
    Oct 15 2006
    Arlington, VA
    well, i guess my budget is really not a problem. i have enough set aside for a decent system. i was just looking at something that wouldn't require an amp, that was just plug and play. i dont really feel like cutting up wires and whatnot to put an amp in, i just want to be as near to stock as possible. i guess i listen to pretty much everything. i like bass, but not to the point where it drowns out the treble. my current bass setting is 5 on symphony, and treble is 3. that's kinda where i like it now if it helps.
    Apr 04 2007
    Well to get anything that sounds better than factory your gonna need more power. I replaced my factory symphony head with a double din screen and it did help the sound out quite a bit, and I was REALLY impressed that the factory paper speakers sounded that good. You could go into replacing speakers, but most of the time these newer factory systems are engineered to sound pretty good with minimal power. Once you go replacing bits and pieces you might not get what your looking for.
    Personally, if you are wanting just a small improvment. Replace your factory head. You would be amazed at what just sending a good clean signal can do to start off. Then do a four channel amp and door speakers second.
    Robbie
    2003 A4 1.8TM
