Results 1 to 26 of 26
    Veteran Member Four Rings S4 in_lowplaces's Avatar
    Feb 09 2006
    2021 SQ8, 2000 AWE stg 3 s4, 2012 CTSV 730Whp, Sold: 2000 Stg2 S4 revo,Totaled: 2000 Stg1 S4 APR
    Huntington Beach
    Lost about 4 quarts of oil in 1,000 miles??
    Just did valve cover gaskets (my Self). Complete oil change, and new plugs.I put 7 quarts in, now i'm at 1,000 miles since the service i did, and i have lost about 4 quarts of oil.
    I know it isnt leaking because my belly pan isnt on and there are no stains on my driveway, i also checked the valve covers, all edges....nothing, no oil leak there either, and lastly i cant smell any oil burning off if it where leaking. I know cars burn more oil once they get into higher miles, and that are S4 eats up oil before turbos go. No dentist drill or anything out of the normal, Everything is just fine, except that i have lost about 4 quarts, anyone have any ideas?
    Stock
    110,xxx miles on the car and its a tip.
    Updated: Go to second page for update on my problem
    2021 Ocra blk SQ8 - Daily
    2011 CTSV coupe 730 WHP - Garaged
    2000 Silver B5 S4 AWE stg 3 - Garaged
    2002 Silver b5 s4 stage 2 revo - Totaled
    2001.5 silver apt stg 2 b5 s4. - Sold
    Veteran Member Four Rings infinkc's Avatar
    Feb 13 2004
    S Ã C, CÃ*
    Re: Lost about 4 quarts of oil in 1,000 miles??
    what do your exhaust tips look like? has to be leaking somewhere, 4 quarts is a lot!
    Veteran Member Three Rings DarkcydS4's Avatar
    Jun 13 2005
    e92 335xi FBO+Meth, 2014 BMW X3 M-Sport
    Madison, WI
    check your ic piping....i was losing oil and for the life of me could not find the leak. like you i had no oil stains on the ground in my garage. popped off the ic piping and what do you know....that where 3/4-1 qt went. same thing happen to someone else i know...lost 5 qts of oil and found in their ic and ic piping. best of luck!
    Jun 13 2005
    Madison, WI
    might be ko4 time
    Veteran Member Four Rings nizmosx's Avatar
    Feb 13 2004
    2007 b7 a4 6MT Ti avant / 1990 300zx TT / 2014 Honda Grom / 2012 Tiguan SE
    Lakewood, CA
    yea i told him to check the piping. i have a feeling its lingering inside there
    Feb 09 2006
    Huntington Beach
    I really hope its just in my intercooler hoses, thats a cheap fix right? It has something to do with the pvc system and i need to replace the round black valve behind the y-pipe correct? I really hope it's in there, if not it's going ot be more expensive. No money for k04 upgrade but i have a pair of k03's sitting at my place. We'll see. if any one else has any input pleaase post thank you
    Feb 13 2004
    Lakewood, CA
    steps i would take.
    DOUBLE CHECK to make sure the car is cold when you check the oil and really see if its down 4 quarts. Its hard to believe its four quarts especially since you dont see any leaking with your belly pan off, and that you dont see it burning out your tailpipe. but at the same time i think you are running open downpipe so you may not be able to see if the smoke is comming out the tailpipe.
    Check the pcv valve to make sure its good to go.
    Look into your intercooler hoses to make sure its not there.
    Get a leak down test to make sure the motor is not passing it
    get your turbos looked at.
    Feb 09 2006
    Huntington Beach
    I'm running piggies with main cats still in, nothing behind it. And you knwo what nevermind about me asking you if i have to pull bumper off, i remember taking off the intercooler hose when i changed my oil filter last time. But i think i am going to rule out the motor burning it up since there is no smoke. Thanks guys
    Registered Member Two Rings Ilan's Avatar
    Jun 21 2007
    2001.5 S4 Avant (tip)
    Naperville, IL
    Quote Originally Posted by infinkc View Post
    What would be noticeable on the exhaust tips? I noticed mine have black residue on the bottom of the tips and my mechanic saw oil in my tb boot. So I'm a bit paranoid about my turbos.
    ASP Stage 1 | 710n's | Samco TBB | AWE Boost Gauge | ASP TSB | AWE Twin2 | Stasis Track Sport
    DMCTalk.com - DeLorean forum for owners and enthusiasts | gocpt.com <--- my mechanic
    Jun 13 2005
    Madison, WI
    Good luck!
    Feb 09 2006
    Huntington Beach
    Quote Originally Posted by Ilan View Post
    Thats just the exhaust gasses, your fine, and there is supposed to be a little oil in your Thottle body boot, but if you stick your finger under it and you can see oil on your fingers then you have a leaky TBB, if not your fine
    Registered Member Three Rings
    2000 Audi S4 6sp
    Calgary
    Quote Originally Posted by S4 in_lowplaces View Post
    you dont want to see oil in your TBB
    2000 Audi S4 6sp
    GIAC X / Clutchmaster Stage 3 / Piggie Pipes w/ modified stock exhaust / Hyperboost DV's
    Senior Member Two Rings DELETE02's Avatar
    Apr 05 2007
    I live at home.
    yo ask s4needsluv he has the same problem we came home from work last night and his oil light came on he was almost bone dry..?? dono where it all went ... weired...... i just checked mine and its the same as when i changed the oil...... dam monday/holiday/friday cars man...
    00 //S4 STAGE-2
    08 RS4
    Feb 13 2004
    Lakewood, CA
    yea you dont want oil in your tbb but a little oil in the pcv system and intercooler hoses is fine. NOT 4 QUARTS THOUGH.
    Veteran Member Four Rings turbow8's Avatar
    Jan 19 2005
    Land Rover LR3
    Denver, Colorado
    I lost in the neighborhood of 5 and 1/2 quarts, it was all hanging out in my intercooler pipping. The front side of the turbo's had an issue with the back side of the turbos so they took a trip threw my motor
    Do
    Epic
    Shit.
    Land Rover LR3
    Nov 09 2004
    San Jose, CA
    What do you mean by "front side having an issue with back side" ??
    And also what took a trip through your motor ?
    Confused...
    Quote Originally Posted by turbow8 View Post
    2002 S4 Avant
    Jan 19 2005
    Land Rover LR3
    Denver, Colorado
    Quote Originally Posted by GVR4-201 View Post
    Confused...
    Lets break down a turbo real quick
    The first time I blew my turbos the back side of the turbo went, pictured above is the turbine housing (generally when this part is blown the oil goes in the exhaust), the second time I blew my turbos the front side of the turbos went also pictured above as the compressor housing (when this part goes it generally dumps the oil into the intercooler pipping). The little stuff in between regarding fighting and taking a trip threw my motor was a joke, but was meant in good fun. Pictured below are the little pieces of the compressor wheel\/ \/ \/
    Shot with DSC-W5
    Pictured above is my awe intake hose, that might clarify something a little bit.
    Do
    Epic
    Shit.
    Land Rover LR3
    Feb 09 2006
    Huntington Beach
    Quote Originally Posted by SMG04 View Post
    When i tore my TBB and i changed it there was a little oil in there, not a whole bunch but a little, i asked around when i found it and everyone said it was normal to have a LITTE oil in there.
    Feb 09 2006
    Huntington Beach
    Quote Originally Posted by DELETE02 View Post
    Thats wierd, I'll give him a call tonight, i think i lost his number , hey mike can you pm me with it please? Thanks.
    Weird thing is after i got off work i went across the street to autozone and bought some oil. Before putting it in i check the oil level three times, it was REALLY low, so i put 1 quart in it, Then i check the Dipsdtick again and i found that it was filled up to normal levels, so maybe my dipstick is reading incorrectly. because liek you stated above and many others have before in the past, when your oil gets that low it shoudl send a signal to the oil light disply saying its low or whatever. I have this entire weekend to my self and will look into the problem further and get back to all of you. Thanks for the help everyone.
    Feb 09 2006
    Huntington Beach
    Here is the link to where it states that there is supposed to be a little oil passing through your TBB.
    http://audizine.com/forum/showthread.php?t=121384
    Veteran Member Four Rings revhards4's Avatar
    Feb 14 2004
    Michigan
    if you didn't change the oil yourself I would say maybe the oil lube place you took it to did not fill it enough. They prolly through 5 quarts and shipped it. A 1/2 quart in the oil filter and 2 quarts down would put you at 2 1/2 quarts....4 quarts is absolutely insane for 1000 miles!
    Feb 09 2006
    Huntington Beach
    So ...... from the first post you can see my problem, i have now made sure there is no smoke coming out of my exhaust and there isnt. I have looked in my exhaust for oil... None. I have taken both intercooler hoses off and check there, no oil. On friday i was almost on empty when i checked it in the morning. I then put two quarts in and it read overfilled. I drove it around for a while and the oil temp started to get close to 250 under normal driving conditions. I have overfilled my oil in the past and i noticed the oil temp was hotter than normal when you do this. So that is what i am getting now. i am assuming i am getting really bad reading from the dip stick....
    has there been any problems other b5's have experienced with bad oil reading through the dip stick. Whats the deal here
    Feb 24 2004
    MS3
    Austin
    Your dipstick only registers down to 1-quart low at the "low" line. If the dipstick is completely dry then you know you are more than 1-quart low.
    Don't overfill your oil. If you know it is overfilled you need to remove some oil as soon as possible.
    If you are getting inconsistent oil level readings from your dipstick then I would assume operator error.
    Are you pushing the dipstick all the way down? Do you wipe it and take multiple readings? Is your car parked on a level surface? Are you letting the oil settle down after a drive? The oil will read high if you park it from a drive and check it immediately. Let the oil settle for a bit before checking.
    The plastic parts of the dipstick tend to break from time to time as they get brittle from the extreme heat of the 2.7t. But that would be obvious.
    Feb 09 2006
    Huntington Beach
    Yep im checking everything pretty consistenlly, cold readings. i am going to chnnge the oil today and measure how much comes out. Then put in 6.5 new quartz and check every day inthe mornings. We'll see what happens,i called the dealership and asked if they have ever has customers call iin for bad oil reading, they said no. Thanks anyways
    Feb 13 2004
    Lakewood, CA
    Quote Originally Posted by fastdreams View Post
    lol this is everything i was telling you andrew.
    Feb 09 2006
    Huntington Beach
    Shut up paul or i'll take my headlights back
