Results 1 to 26 of 26
    Veteran Member Four Rings JJPA4SE's Avatar
    Boxes
    Pittsburgh, PA
    Post O-Ring Fix Write-up - E-Code Bixenon's & B6S4 Bixenon's
    Seems like there are random bits of info everywhere but not a complete how to...
    Total Time:
    5-15 Min.
    Tools Needed:
    T30 Torx to remove Headlight
    T20 Torx to remove Top Gear Assembly
    Phillips or 6mm Allen Key to turn adjustment screw
    Blue Painters Tape (If you want..)
    1. Remove Light from car. I put blue painters tape on the bumper under the light so the bumper doesn't get scratched.
    2. Identify Location
    3. Unscrew (T20 Torx) screw & Remove Top Gear Assembly
    4. Turn Light Upside Down and pull out Gear Shaft (So dirt does not go into the housing). Wipe dirt from around opening while upside down...
    5. Remove Old O-Ring and Install New O-Ring on Gear Shaft...
    6. Reinstall Gear Shaft with New O-Ring... Some other post's recommend putting Graphite Lube on O-Ring at this time. I have not done this and they seem to be working OK.
    7. Reinstall Top Gear Assembly (T20 Torx)... same as Step 3
    8. **Optional** Carefully Turn Adjustment Screw both Left and Right to make sure it's in good. Make sure to leave adjustment screw in same place as before so height of light is not changed. Final tweaks may be needed anyways once lights are reinstalled anyways.
    9. Cleanup and reinstall Headlights!!
    Good Luck and preform fix at your own risk. Be careful not to break anything, it wont be my fault...
    2001.5 S4
    2005 Acura RL - SOLD
    2006 S4 - 25quattro #159 - SOLD
    2005 A4 1.8tqm Ultrasport Avant - SOLD
    2005 A4 1.8tqm Special Edition - SOLD
    Veteran Member Four Rings Tgr_Clw's Avatar
    Jul 20 2005
    2003 Audi A4 1.8TQM
    Toronto, Canada
    Re: O-Ring Fix Write-up - E-Code Bixenon's & B6S4 Bixenon's
    Awesome write up. Thank you.
    Appearance: OEM+
    Interior: B6 S4 Recaro Seats
    Performance: MTM Stage 3 / Milltek Exhaust+Milltek HFC / JJ TIP / ASP FMIC / SB FE SS
    Suspension: Vogtland Coilovers / HSport S4 Sways
    Braking: Stoptech 332 BBK
    Wheels/Tires: BBS CH 18x8.5, ET35 / GY Eagle F1 GSD3 235/40/18
    Senior Member Three Rings 1 sick s4's Avatar
    Feb 14 2007
    connecticut
    what size is the o-ring. can i buy it at a department store.
    "I have a V8 it's NATURALLY ASPIRATED!!!!!" <-----
    Veteran Member Four Rings Raus's Avatar
    Aug 17 2005
    B6 1.8TQM, Mk2 GTI
    Nice write-up, thanks.
    Are there any other spots bi-xenons leak from? I taped up the whole side over the adjusting gear with aluminum tape and I still get condensation in one headlight when I wash the car.
    Ich bin der Musikant mit Taschenrechner in der Hand
    Boxes
    Pittsburgh, PA
    Quote Originally Posted by 1 sick s4 View Post
    see below...
    Quote Originally Posted by Raus View Post
    I have not heard of any other locations. I tried the tape fix and it didn't work for me. I believe people have had the most success is with the O-Rings.
    2001.5 S4
    Dec 07 2006
    San Francisco, CA
    Bump for this write up.
    I bought my new O-rings from JJPA4ASE and followed the write-up. Everything works perfect now. No more fog!
    Veteran Member Four Rings SuperAvant's Avatar
    May 30 2007
    MA
    Can we get the o-ring size??? Really would like to pick it up on my way home tonight
    Established Member Two Rings younga4's Avatar
    Apr 08 2007
    B6 A4 1.8t & MKIV 1.8t
    City of Angels
    We appreciate you!
    "We must find a new way to interpret our thoughts and feelings and reassess the extent to which our appraisal of our reality is realistic".
    Audentes Fortuna Juvat
    Young
    Oct 22 2005
    Reppin the Mitten.
    #6 o-ring (7/24" OD x 5/16" ID)
    Did this for like a year, and it hasnt fogged up at all
    Veteran Member Four Rings Fade2Black's Avatar
    Nov 27 2008
    Black B6 S4
    Springfield NJ
    I did this today took me about 10 min.
    Thanks
    The democracy will cease to exist when you take away from those who are willing to work and give to those who would not.
    – Thomas Jefferson
    Veteran Member Three Rings reapersa4's Avatar
    Sep 25 2006
    too many
    North Vancity
    1. take your o-ring to your local parts store, match it up and buy one size larger.
    2. use rubber grease on the o-ring before re-installing the shaft in the housing.
    500 AWHP 400 AWTQ
    04 1.8TQ6M USP Black on Black w/CF Trim ~ Eurodyne tuned ~ 2.0L GT3076R ~ AEB Head w/1mm oversize valves ~ 3658 cat cams ~ Direct port Meth ~ Custom FMIC ~ Custom 3" exhaust ~ Custom Intake Mani w/S4 72mm TB ~ STaSIS 4:1 center diff ~ HRE 441R 19x9.5/19x8.5 ~ STaSIS MS ~ B7 RS4 F+R BBK ~ Podi P2~ Custom S4 rear w/ 996TT tips ~ S4 Recaros Blk leather w/Dove Grey Alcantara ~ S4 bi-Xenons ~ Caractere Sides, USP w/Kerscher CF splitter ~ Custom EG CF hood ~
    Veteran Member Four Rings Duchenbagen's Avatar
    Feb 29 2004
    ATL/FLL
    Quote Originally Posted by vinny.dtw View Post
    Wrong. So here is the correct info.
    Danco #6 7/16" OD and 5/16" ID. Stock #96723
    You can find these at Home Depot in the plumbing aisle.
    John
    USP CLUB MEMBER #5
    How much does the illusion of integrity cost?
    Senior Member Three Rings layzie's Avatar
    May 14 2008
    B8 A4
    Buffalo, NY
    ^ correct
    USP CLUB MEMBER #113
    '04 Audi A4 1.8 6mt Ultrasport
    '08 Audi A4 3.2 6mt S-line
    '12 Audi A4 2.0 6mt S-line
    Veteran Member Four Rings DreDay's Avatar
    Apr 25 2010
    Morris County, NJ
    Figured I'd share that I did this mod last night. Thanks for the write up, and thanks duchenbagen for the correct o ring size. it was easy to find. no we wait for some rain haha well hopefully snow where I am and because I'm a snowboarder :-)
    CURRENT| C7.5 A7 TDI [MODS INCOMMING!] + 958 Cayenne Turbo
    PAST| Bagged MK1 R8| B8 SQ5| B8 S5| B6 S4| B6 A4| C5 Allroad| (2) T2 Touareg V8| Gen 2 Cayenne S
    NEXT| Another Stance Project
    Aug 26 2005
    As the original discoverer and developer of the famous "O" Ring Fix, I recommend flooding the headlight areas with a garden hose after reinstalling the headlights, to prove the fix has been installed correctly, and that the water leak into the housings has been fixed permanently.
    Vorsprung durch Technik
    Veteran Member Four Rings ilko's Avatar
    Oct 20 2007
    997TT, 993, W211 E55 AMG Wagon
    Upstate Manhattan
    Well, after searching through Home Depot and Lowe's and not being able to find the exact O-ring, I ended up doing something else... I used thread seal tape (or teflon tape as it's also known). I pulled the original O-ring about 1/2" down from where it originally sits, then wrapped the spot with 3 layers of teflon tape and then reinserted the O-ring. It seals it nice and tight. No more leaks, no more condensation. YMMV.
    B7 S4 Avant - sold
    997 turbo
    993 Carrera
    Previous: 993 Carrera 4S / 964 RS America / 964 Carrera 4 / 944 Turbo / MK4 Golf R32 / C5 allroad / B6 USP Avant
    Aug 26 2005
    Inspired work around! Congrats for your success.
    Veteran Member Three Rings Time4Audi's Avatar
    Jan 15 2007
    Massachusetts
    THANK YOU for this!
    Oct 09 2008
    Now that I fixed this I feel bad for all of the other unsuspecting B6 drivers around my area.
    The Awesome™
    Active Member One Ring KingChar90's Avatar
    Jan 04 2012
    Thanks so much for all this wonderful information. You saved me $350 + labor because I thought I was going to have to replace the headlights entirely! That NJ dealer can suck it!
    Go Audizine!
    Oct 22 2013
    NC
    Does this apply to the non-HID/standard halogen lamps as well? I have the standard halogens and have excessive condensation inside both. Do these also have the o-ring issue?
    Dec 28 2006
    '13 A5, '24 Tiguan SEL R-Line
    Western Maryland
    Quote Originally Posted by wolfsburged View Post
    Nope. That adjustment is only for the OEM HID housings.
    Aug 26 2005
    Only the S4 bi-xenon housings use the vertical beam adjuster shaft, so that is the only OEM headlight that the O ring replacement applies.
    May 04 2019
    New Zealand
    Hey! Does this apply to B7s as well? My 06 A4 Avant is really misty inside.
    May 04 2019
    New Zealand
    Nevermind, just saw the last comments. Haha. Any idea on leaky A4 B7 Avant headlights?
    Veteran Member Four Rings Biged243's Avatar
    Mar 27 2013
    Vr6 gti
    Metro Detroit Michigan
    I believe you will have to reseal the lens. There are threads in the b7 forum for it. If you do it you might as well do some other mods to your liking.
    What ever makes sense go with the opposite and you got it
