Results 1 to 40 of 54
    Jun 27 2007
    Pasadena
    Cargo Cover keeps popping loose
    I have a 2003 B6 Avant. The cargo cover seems to keep popping out of the slots at the end of the cargo area (when fully extended)?
    Does anyone have this same problem and if so do you have any fixes for it?
    Thanks
    Veteran Member Three Rings RenoAudiNV's Avatar
    Feb 10 2007
    Reno, Nevada
    Re: Cargo Cover keeps popping loose
    same car, no problems like that here. That thing is actually quite hard to pop out on mine.
    Silver 2004 S4 Avant
    --Current Setup--
    Fast Intentions Downpipes || Fast Intentions Perf Core Resonated XPipe 2.5" Catback || RNS-E || Sirius || 19" BBS CH || 235/35ZR19 Bridgestone Potenza SA050 Pole Position || Bilstein Coil Over PSS9 || Carbonio CAI || V1 Hardwired || VAGCOM || Votex Rear Spoiler || Oettinger Front Grille
    http://www.youtube.com/RenoAudiNV http://www.flickr.com/photos/davidcarrico/
    Jun 25 2007
    McHenry Co, IL
    Ive had that happen a couple times when it wasnt in the slot all the way, my fix was to stop using the cover
    '98 A4 Avant 2.8
    Apr 01 2007
    2004 S4 Avant, 1970 Datsun 510
    Quote Originally Posted by a88fl1 View Post
    Happened to me once. My solution was exactly the same. I dont have a need to cover anything up back there anyways.
    Senior Member Two Rings stomata's Avatar
    May 31 2007
    B6 A4 Avant 1.8TQM
    I had the same problem
    but if you put that in slot and dun have anything pushing the cover, it should be fine
    Veteran Member Three Rings MarkChai's Avatar
    Feb 01 2007
    1998 Titus Quasi-Moto
    SF, CA
    Mine never seems too secure, but it does stay put. Make sure that the toolkit and the jack are in their proper places. When I was cleaning the other night I had problems closing that cover because I had moved things around.
    [edit] I just realized that I am talking about something different here. sorry.
    Formerly:
    B7 A4 Saloon CVT :P
    C4 A6 Avant Quattro
    B6 A4 Avant USP 6QM
    B5 A4 Saloon Q-Tip
    Established Member Two Rings AudiBenz's Avatar
    Mar 04 2007
    05 S4 Avant
    Foster City, CA (Bay Area
    I have the same problem all the time. If I hit a little bump, or take a sharp turn the damn thing pops out. Pisses me off
    May 18 2007
    Vancouver
    i have that problem too and tried to get it fixed under warranty. However audi denied the claim because they said my car was lowered.
    Established Member Two Rings VisionPaintball's Avatar
    Jun 26 2007
    Keyport,NJ
    mine does the same. I am going to try and wrap the ends in some kind of rubber for some extra grip.
    Jun 27 2007
    Pasadena
    I tried that twiceand it still pops out. The problem is that the groove that the cargo liner ends go into aren't deep enough.
    Established Member Two Rings nwavant's Avatar
    Jan 25 2006
    19 Atlas R
    Olympia, WA
    I thought there was a fix for this from Audi? Mine does the same thing and pisses me off!
    G.
    17 Allroad
    19 Atlas R
    00 Sportsmobile
    18 Tiguan (sold), 16 GSW (sold), 02 A4 Avant USP (sold), 04 VW Touareg (sold), 99 A4 Avant (sold)
    Jan 24 2008
    West Coast
    Big time necro-bump!
    I'll admit that mine does the same thing. If I have it extended, it'll retract if I hit a decent dip at any sort of speed. No problems ever when flying on the freeway.
    What is this fix you refer to?
    Moderator
    Veteran Member Four Rings EuroA4's Avatar
    Feb 12 2004
    PA-NJ
    Sounds like its time for a little dremmel action :)
    Aug 18 2009
    A Unicorn
    Portland, OR
    Same thing happens to me sometimes. Usually when going over a bump or something. Scares the shit outta you if you're not expecting it (and why would you be). I like having the cover closed, but it gets annoying. I've thought about using some plasti dip or something on the ends to give it some grip, but it sounds like that's been tried already.
    Veteran Member Four Rings AvanTTix's Avatar
    B9.5 Q5 55 TFSIe, B6 A4 1.8T Avant, MKI TT 1.8T 225hp Roadster
    San Francisco, CA
    Make sure the cargo cover trim/holder itself is engaged all the way in its rails at the back of the seats. Not saying it will totally take care of the issue, but it does help.
    MY2024 B9 Q5 55 TFSIe: GlacierWhite||7-Speed S-tronic||Prestige||Black Optic||Sport Plus
    MY2003 B6 A4 1.8T Avant: DenimBlue||Ebony||5-Speed MT||Quattro||Premium||Sport
    MY2002 MKI TT 1.8T Roadster: BrilliantWhite||RedAmber w/ Baseball Optic||6-Speed MT||Quattro||Premium
    Dec 01 2007
    Orange County, NY 10918
    same thing happens to mine. scares the shit out of ya sometimes! but i like having it closed, got too many work tools and crap for work back there.
    is there a fix to this?
    C6A6 3.0t Avant
    @avantneil
    @avantoberfest
    @skiguardusa www.skigaurd.com
    Veteran Member Four Rings D's Avant's Avatar
    Oct 03 2007
    02 BMW 330i
    Illinois
    I use some velcro to keep mine in place.
    Current '08 A6 Avant S-Line
    Former '99 A4 Avant 1.8t
    Veteran Member Three Rings justinperkins's Avatar
    May 14 2009
    Q7 TDI | B6 S4 Avant MT | 84 Adventurewagen | 53 Ford Jubilee
    MI
    yup, mine does it to, I just took it out since I never use it anyway
    figure I can better preserve it in the garage and free up a few inches of cargo space
    -justin
    Jan 24 2008
    West Coast
    ^ You make a good point Perkins. I take it out when I need extra space. I have a crate for my dog, and it won't fit at certain angles with the cargo cover in.
    Moderator
    Feb 02 2009
    NorCal
    Happens to me as well....
    I wonder if making the groove deeper with a dremmel will work ?
    What I have noticed, is when I have the cargo area FULL...so that it is packed underneath the cover, it will not slip out.
    I looked into it...for me what is happening is, that last part of the cover (Which is pre-folded)...will fold down slightly on a bump, and then BAMM... it causes the whole thing to come loose.
    (try this on your car : open the trunk... put the cover properly into the groove, then press down on the rear part of the cover an see what happens)
    May 14 2009
    Savannah, GA
    Mine used to do it, but my bigger problem was the awful creaking noise it made. I cut some small strips of felt, with a sticky backing, and wrapped it around the end pegs. Now it fits more snug and doesn't make any noise. No popping out since either.
    Jan 24 2008
    West Coast
    ^ Sounds to me that that may be the best way to go. Use something - felt, rubber, etc., to cover the ends so that it doesn't move as much in the slots.
    Moderator
    Veteran Member Four Rings pdxa4's Avatar
    Mar 26 2004
    19 MX-5, 99 MX-5, 12 Golf-R, 03 S8, 08 GTi, 06 MX-5
    Quote Originally Posted by D's Avant View Post
    Yep I did the same thing on my previous 03 Avant...
    On the end pieces that go into the slot, I stuck on the soft part of a velcro strip on each end.
    This gave it a better grip in there, and I never had any problem after that...
    You might be able to see this on my pic...only one I could find right now...
    Current: 23.5 Land Rover Defender 90
    Current: 23 Lexus GX460
    Current: 19 Mazda ND2 MX-5Current: 99 Mazda NB1 MX-5
    Former: 12 VW Golf-R, Rising Blue Former: 03 S8, Ming Blue
    Former: 06 Mazda NC MX-5
    Former: 08 GTi, 4dr DSG, 03 B6 A4 Avant 1.8TQ
    Former: 00 B5 A4 1.8TQM J31-K04
    Former: 04.5 Euro Passat PD TDI
    Original PDX
    V1.0 Member since 02/24/2002
    Oct 03 2007
    02 BMW 330i
    Illinois
    Quote Originally Posted by pdxa4 View Post
    That's just like what I've done with mine, works real good and stops the cover from making noise too.
    Veteran Member Four Rings bblume's Avatar
    Dec 20 2007
    06 avant. 92 Gti. 07 X3. 14 Sq5
    Colorado
    ^^^looks like a good solution...every time my pops I jump out of the seat thinking some kind of collision occurred. scares the bejesus outta me!
    14 Sq5
    02 Eurovan
    04 DBP R32:.
    92 Gti-TDi 1Z (sold)
    06 AVANT S-line QMT6 (Just sold it!!)
    07 BMW X3 (given to the in-laws
    Established Member Two Rings zanadu's Avatar
    Jun 08 2009
    San Jose, CA
    Exact same thing happens in my 2002, it's really annoying. The cover is pretty noisy too.
    edit: I'm gonna try the 'wrap it in the soft half of the Velcro straps' trick.
    Veteran Member Three Rings charlatan's Avatar
    Apr 13 2007
    MOLINE, IL
    My 2005 hasn't ever had this happen.
    theROGUEdesigner
    Sep 11 2009
    boards n wax
    Huntington Beach
    Quote Originally Posted by justinperkins View Post
    i might have to pull out the manual and take this thing off, it gets in the way when i put my surfboards in.
    Dec 20 2007
    Colorado
    ^^^^one other possible issue is just how much that thing weighs. The B7 cover feels like it weighs at least as much as an overweight horse jockey!
    14 Sq5
    02 Eurovan
    04 DBP R32:.
    Jan 24 2008
    West Coast
    ^ HAHAHAHA! Hilarious!
    They all do...unfortunately.
    Moderator
    Jan 24 2008
    West Coast
    Quote Originally Posted by rjpeaks View Post
    Fortunately, it's super easy. Put both seats down, then pull the entire piece towards the passenger side. Voila! It's on a little track on the back of the seats.
    Moderator
    Dec 20 2007
    Colorado
    Mine requires at least two helicopters to remove/reinstall
    14 Sq5
    02 Eurovan
    04 DBP R32:.
    Dec 01 2007
    wrapped the ends of mine with the soft side of velcro! works great, hasnt popped loose since then.
    C6A6 3.0t Avant
    @avantneil
    @avantoberfest
    Veteran Member Four Rings MikeWire's Avatar
    Mar 08 2007
    Air and water
    SATX
    Did you guys do one full wrap with velcro ends touching or did you overlap the velcro?
    -Mike
    @countdowngarage
    2015 Porsche Macan S | 2021 Atlas SEL-P | 1972 VW Bus | 1965 VW Beetle
    SOLD - 2017 VW GTI APR Stage 2
    SOLD - 2001 Allroad - 6 speed swap thread
    SOLD - 2003 A4 1.8TQM Avant Atlas - 5 speed swap thread
    Dec 20 2007
    Colorado
    Quote Originally Posted by MikeWire View Post
    X2
    14 Sq5
    02 Eurovan
    04 DBP R32:.
    Oct 03 2007
    02 BMW 330i
    Illinois
    Quote Originally Posted by bblume View Post
    X2
    Just do one full wrap end to end of some pile/soft velcro. Don't double it up... I did end up putting some of the hook part of the velcro in the slot the cover post locks into. This may not be needed and I just used a 1/4" section of it or so.
    Dec 01 2007
    yeah on full wrap, works awsome! put 300+ miles on the car yesterday and didnt pop loose once. and drove thru the rough roads of the poconos too!
    C6A6 3.0t Avant
    @avantneil
    @avantoberfest
    Mar 26 2004
    Good to hear it is working for your guys, see a nice simple change :)
    Original PDX
    Aug 26 2005
    Quote Originally Posted by dkismith View Post
    Thanks
    Audi Parts has a kit consisting of a pair of rubber blocks that fit into the slots for the cargo cover, and stops the cover from popping out. I don't know the PN right off hand, but it's a quick, easy engineered fix. My cover has not popped out eversince I installed the little blocks.
    Aug 26 2005
    Quote Originally Posted by ShyGuy View Post
    Sarcastic humor here, right?
