Results 1 to 6 of 6
    Feb 12 2004
    2018 M3 CS, i3 REx
    Orange County CA
    225 vs 235 tires
    I'm a tire noob. Running Kuhmo Estas 225/40/18s right now:
    Will getting 235/40/18s fill in the gap a little? What are the advantages of the 225 tires? Performance? Looks? I'm not sure I like the stretched over look. Any advice will help.
    Former:
    BMW F80 M3 CS
    BMW F80 M3
    BMW I01 i3 REx
    BMW F30 340i M Sport ZTR
    Audi B7 S4 25Quattro
    Audi B5 A4
    Veteran Member Four Rings Chard's Avatar
    your sidewall will be taller with 235/40/18. the 235 measurement is the width of the tire. The 40 measurement is the sidewall measurement which is a ratio of the width, so if you keep the 40 series, you'll end up with an overall larger tire meaning your rolling diameter will be larger. To compensate for this you can get 235/35/18 but I don't think too many people run this size. If filling in the gap is what you're qorried about, the 235's will work.
    Veteran Member Three Rings Brrman's Avatar
    Indianapolis
    I run Khumo Ecsta Supra 712's in 235's, JMG - see my "wheels are on" post.
    My wheels are 18x8.5 tho.
    2019 S4 Prestige
    RIP... 2013 A4 Allroad
    SOLD 2007 A4 2.0T S-Line Ti (APR stg1, Koni Coilovers, LED Tails)
    SOLD. 2000 A4 avant 1.8T (GIAC stg1, Bilstein/H&R)
    RIP... 1998 A4 1.8T (GIAC stg1, Bilstein/Neuspeed)
    Veteran Member Four Rings needforspd's Avatar
    Mar 05 2004
    Deceased 01.5 A4 1.8tm
    Sylmar Hills
    like the saying goes "wider is better" for handling, at least in my experience it is.
    but you could rub depending on how low you are if you get 235s though from what ive seen/read it should be no problem.
    and imo your gap isnt bad at all. drop it one more perch if it really bugs you n try that.
    Do you have a need for speed? Then drive it like you stole it!
    Veteran Member Four Rings DRA4's Avatar
    Feb 12 2004
    B5 S4
    Just drop it a little more.
    Giac stage 1 279whp-327wtq
    TEAM A.C.E. NY
    Me: Siri where do lesbians hang out?
    Siri : I found 2 Subaru dealers fairly close to you
    Veteran Member Four Rings A4 in SC's Avatar
    Feb 16 2004
    '84 911 Carrera GP White, Burgundy cloth
    Simpsonville, SC
    I have Yoko ES100s in 235/40/18s and I was rubbing up front pretty bad over harsh bumps. Rolling the fenders took care of that though!
    I don't care for the stretched look either. That's why I went w/ 235s. Of course, there's alot of people out there that love the stretched look. I'm just not one of them. I want the tire to fill the fenderwell. I think mine are just right. The 225s I had just didn't look right to me. Kinda' like an elephant wearing a bikini, if you know what I mean...
    Mike
