    Established Member Four Rings A4TL's Avatar
    Nov 06 2006
    335is
    atlanta
    What is torque rating on knock sensor? Would changing this affect CF?
    We must realize as knock sensors get old they go deaf, etc yadda.
    What is the proper torque rating on the knock sensor?
    Would increasing the torque (better, replacing the sensor) a little have much effect on the ecu? consider age of sensor.
    One would think we'd replace the knock sensor on a 2002 by now.
    any thoughts?
    02 1.8tqs - apr 1+ - SS forge - Hartmann B5 RS4 18" ET35 - Delsa (ebay) spoiler lip - debadged, B7 A4 320mmx30 front brakes - 335i Montego Blue/black; Sport;Prem; iDrive; Step and Heated Seats.
    Veteran Member Four Rings bananas's Avatar
    Jun 13 2005
    1999 A4 Avant 1.8TQM
    Minnesota
    Re: What is torque rating on knock sensor? Would changing this affect CF?
    20Nm (about 15 ft-lb)
    Yes, the torque on the knock sensors will change the voltages. Don't do it though. Torque them exactly to spec. If you suspect they're bad, just get new ones.
    '03 A4 1.8TQM 337WHP/355WTQ (93+meth) | My car's Mods | Fancy Pants™ Turbo Club Member #001
    Nov 06 2006
    335is
    atlanta
    so you think after 4-5 years (90K) miles it may be wise to replace them?
    Anyone notice that #4 cylinder (end of fuel rail) tends to get more CF than the rest? (swapped plugs,new cp's, moved injectors).
    I wonder if all cylinders are pulling but the knock sensor is more/less sensitive.
    Bad is like the o2 sensor. It will become less responsive and read leaner. My mpg will decrease (maybe .05mpg at a month) but that means i ordered a new one.
    What say ye on knock sensor replacement. The quicker timing is pulled, the less likely the engine will crater in the aging years.
    It's the subsonic detonation i worry about. I can hear ping like no tomorrow (i tune cars, lol). SBD kills.
    Jun 13 2005
    Minnesota
    if you suspect they are bad, I see no reason not to replace them as they're relatively cheap (maybe 70 bucks for the pair?)
    Established Member Two Rings emanar's Avatar
    Dec 05 2005
    Two
    Puerto Rico
    Yes if you over torque the knock sensor will make a huge difference in the reading they will send to the ECU.
    Referring to the why the the Num 4 cylinder have more CF that the other is because is the farther cylinder from the throttle body. That makes the 4 cylinder a little lean so the ECU most compensate for this variation. Those German think in everything
    I recommend torquing them at 15 lb/ft not more or less.
    2003 1.8t CVT
    Forge DV 007, KN Filter
