So I have done tons of searching on the subject and have been able to answer most of my questions, but there is a lot of conflicting information floating around regarding Xenon/Bi-Xenon headlights. I am hoping to get some definative answers to a few questions can someone help me out?
Please, only answer if you actually know, don't just recite information from other threads that you do not have the personal knowledge to back up. I think that this is why I can find so many different answers for the same question. I do not need full detailed explainations (throw them in if you want to) but rather I want fast indisputable answers. I made a True False Test to try and make it easy. I can add or edit questions if needed. Thanks!!
1. The s4 came with single xenon as well as bi-xenon headlights. T/F
2. Bi-Xenon headlight housings have two seperate Xenon bulbs. One for low AND one for high beams. T/F
3. If your car was originally equipped with Xenon headlights you can install Bi-Xenons without throwing any codes (CEL, dip headlight etc) T/F
4. When installing Bi-Xenon headlights from single Xenon, you are able to use all of your original components and will NOT need to buy additional parts (assume you have proper DS bulb type) T/F
5. The light output from Bi-xenon housings is greater because:
a) "Bi" means two, so it's twice as good.
b) It has a larger focus lens but uses the same main bulb as Single Xenon
c) It has a motor and switch plate that moves around and does something.
d) Magic
if "C" please elaborate.
If I get my questions answered I'll write up a list of Xenon headlight facts that maybe will be good enough to get stickied so that others can reference it in the future!!
