Results 1 to 40 of 45
    Active Member Two Rings BoostLeak's Avatar
    May 03 2007
    What size tire on 18x8.5 for the stretched look?
    See above.
    Feb 27 2005
    North Wales, PA
    Re: What size tire on 18x8.5 for the stretched look?
    225/40/18 is the appropriate size for the stretched look. I hope you are lowered cause that will look pretty bad on stock ride height
    Veteran Member Four Rings Calabria's Avatar
    Dec 10 2006
    '00 1.8TQM
    LA
    Quote Originally Posted by Poopie View Post
    werd
    (Ka-La-Bre-Ah)
    Senior Member Two Rings Lelix's Avatar
    Mar 22 2007
    2001 A4, 1.8tqm
    Quote Originally Posted by BoostLeak View Post
    See above.
    yep those are Fuzions ZRI's in 225/40/18
    "Wheel gap is for ///M owners"
    Registered Member Three Rings Jereme's Avatar
    Oct 27 2006
    98 a4 1.8tqm
    Chester, NH
    yeah I whip 225 45 18"s on mine
    http://www.dirtycustoms.bravehost.com
    Custom Magnaflow Exhaust (muffler 14862),Custom 2.75" Test Pipe/Downpipe,Custom CAI,Forge 004,Forge MBC,GIAC chip,Neuspeed Race springs,Ebay short shifter,Drilled and slotted rotors with EBC greenstuff pads,18"ADR M-Sports,Nankang NS-II,Black Depos with 6500k HID kit,Newsouth Performance Gasket, P&P Head, 2.8 Transmission, Southbend Stage 3.
    Running Strong with 163k...
    May 03 2007
    Thanks guys!
    May 04 2004
    00 BB S4
    York, Pa
    I run 205's on 8.5's but thats not for most people....
    Alot depends on the tire, they all strech different. I run Falken 512's and love them. Toyo's strech very well also.
    But dont strech for looks, thats dumb. Do it because you need to.
    00 S4 BB Stg3
    Stolen Tune|K&N|STACK|DAR|KW V1|VAST - MBC |JHM SS Knob - SS lines - FMIC - Shifter - Trans Rebuild - 2pcs Rotors|AWE DTS - Boost Guage - DPs |BW K04|Southbend Stg 3|ASP Cat Back|V1|034 Snub - Race Tranny mount - Street Motor Mounts - Intake Hose - DVs|HAWK HPS|APIKOL RDM|H Sport RSB|6000k HID|Mille 12"|Hifonics|Focal|WOTBOX|AVIC910
    May 03 2007
    Quote Originally Posted by 98a4 View Post
    I should be getting coilovers for it soon as well so it is because I want it slammed (not as much as you though!)
    Veteran Member Four Rings Rosati's Avatar
    Nov 17 2004
    B5 Brilliant Black A4 1.8TQM
    Northern New Jersey
    I have a sick stretch on 225's But then again, my rims are 9" wide (rear)
    FYI: mine stretch maybe 40% more than the pictured setup
    * Gone but not forgotten - BTA4 GT28RS w/ all mods 400chp
    https://www.facebook.com/media/set/?...1463643&type=3
    Current: 1994 Mazda RX7 Chaste White
    DIY B5 Head Replacement Guide: http://www.audizine.com/forum/showth...al-and-Install
    May 04 2004
    00 BB S4
    York, Pa
    Not to downplay you but 225 on a 9 isnt sick strech by any means....
    I have 215 on a 9.5/10 and its still not even what I consider "sick"
    00 S4 BB Stg3
    Veteran Member Four Rings sixfiveoh's Avatar
    May 19 2007
    Bay Area
    Are those VSXX on car in the original post? any more pics of that car?
    SIXFIVEOHphoto
    2001 Brilliant Black 1.8TMS A4
    Unitronic|APR|H&R|Neuspeed|Falken|Carbonio|Apex'i| VDO|VMR
    FS: Buncha B5 parts, CLICK
    Nov 17 2004
    Northern New Jersey
    Might not sound like it, but ill post a pic to show how sick it really is.
    The Lip is outside the tire.
    Maybe its the falken ziexs? Ill post man, youll see.
    Nov 17 2004
    Northern New Jersey
    Veteran Member Three Rings BING's Avatar
    Sep 18 2006
    01' A4 2.8QM ,99' A8Q,93' //S4
    comin up fast on your left !
    Thats a Phat Lip !!!! Thats Dangerous for N. Jersey dont u think?? Went threw to Ct. saturday in my buds 95.5 S6 Avant and collapsed a front H&R heading for the GW Bridge....
    03' VW TDI in GTI clothing
    93' //S4 GT30/40R,VEMS,6MT(sold)
    99' A8 4.2Q(sold)
    01' A4 2.8QM(sold)
    02.5' VW Passat Wagon 1.8t
    110 valves =;^)
    Nov 17 2004
    Northern New Jersey
    Ha tell me about it man, I spend most of my time driving watching the actual road, Seeing that the car is lower than in the pics.
    I also need some spacers for the front id have to go 8mm i think
    Sep 18 2006
    I have a bag of 5mm spacers,wheel studs,and lightweight Porsche nuts going in tomorrow,been sittin in the garage long enough,should have put them on when i had the wheels off adjusting my 2bennet coil-overs.......But its therapeutic !!!!
    99' A8 4.2Q(sold)
    01' A4 2.8QM(sold)
    110 valves =;^)
    Oct 06 2004
    Minnesota
    I plan to ditch my 245 for some 215s. But I also run 9"
    Instagram r_michals
    '12 Q7 TDI- Glacier White
    Feb 27 2005
    North Wales, PA
    i don't stretch my tires for the looks though. I would love to rock 235's but i would rub like crazy.
    Oct 06 2004
    Minnesota
    Streching the tires make you not rub. It allows you to push the wheels out without rubbing.
    Instagram r_michals
    Veteran Member Three Rings brlukosk's Avatar
    Mar 21 2006
    St.C MN
    Quote Originally Posted by Rosati View Post
    You need some spacers up front for sure.
    8-10mm should do just fine.
    I have 15mm up front on stock ET.
    Nov 17 2004
    Northern New Jersey
    If you read my post, youll see that I said im getting a pair of 8mm's
    Feb 27 2005
    North Wales, PA
    Quote Originally Posted by A4Rob View Post
    Yeah i know. I run a 225 so I don't rub and I have the stretched look. I love meaty tires though
    Apr 05 2007
    Bend
    I have seen 215's on a 10" wide wheel.
    Here are some examples of real stretch and poke
    My B5's For Sale PM ME!
    UberFellas
    stanceworks.com
    ^^Superior^^
    Registered Member Two Rings Nukkah03's Avatar
    May 12 2005
    97 POS TURBO
    H-Town, Oregon
    thats just nasty and I mean it in a bad way.
    Veteran Member Three Rings chimchongdlight's Avatar
    Jan 02 2007
    Bay Area to Sacramento Ca
    dang foreals
    anyone got 245's? my boss is selling some 245s thats why, i dont really like the stretch, i feel bad for the tire, lol
    any one got the look of 245 or 235?
    Jan 02 2007
    u guys think 245 or 235s will rub with 18x9 in the back and 18x8 in the front?
    Mar 21 2006
    St.C MN
    I know, I was just saying that it should get the job done.
    Sep 18 2006
    Quote Originally Posted by brlukosk View Post
    15mm's !!! DANG thats a lot of added stress on those hubs dude.......
    99' A8 4.2Q(sold)
    01' A4 2.8QM(sold)
    110 valves =;^)
    Veteran Member Four Rings aytheory's Avatar
    Oct 28 2006
    A4 1.8tqm 99.5 aeb ndbw
    Los Angeles / Santa Barbara
    OMG these rim pictures remind me of goatse - bwahahahah
    Mar 21 2006
    St.C MN
    Quote Originally Posted by BING View Post
    Yeah I know, but I think it looks like ass without them!
    Maybe I should go with 10..
    -brad
    May 04 2004
    00 BB S4
    York, Pa
    Rosati, thats not crazy strech by any means....
    215 on a 9.5 (3pcs its 9.74 inside to inside)
    00 S4 BB Stg3
    Veteran Member Four Rings alen's Avatar
    May 10 2004
    1.8tqms
    ghettlanta
    depends what kind of stretched look you are going for.. i suggest you go to vwvortex mkiv forum and check out any thread there...you'll get to see all kinds of stretches.
    as for 8.5, you might want to go with 205s to get that nice stretched look. 225 on 8.5 looks like ass imo.. 235 on 8.5 is perfect i think, look below:
    Senior Member Three Rings hey4's Avatar
    Feb 10 2006
    B5 A4
    Twin Cities
    Quote Originally Posted by a4fann View Post
    offset? Rubbing issues. I have a set of 18X10 et42 for the rear but I'm pretty sure they won't fit
    Veteran Member Four Rings bOOOOstedAudi's Avatar
    May 27 2004
    C6 A6 S-line 3.0T Quattro, BT B7 A4 2.0T S-line Quattro
    Sacramento, CA
    yeah but your perception of strech is crazy
    Nov 17 2004
    Northern New Jersey
    you are on the VW Mk1/2 level stretches on your a4 What im on is pretty good for an A4 which is a more conservative car.
    Apr 05 2007
    Bend
    triple posts FTL
    UberFellas
    stanceworks.com
    ^^Superior^^
    Sep 18 2006
    triple posts FTL
    Rosati just wanted to see this go 3 pages!!! LOL
    99' A8 4.2Q(sold)
    01' A4 2.8QM(sold)
    110 valves =;^)
    May 03 2007
    wow.. what have I started :)
    Nov 17 2004
    Northern New Jersey
    triple posts FTL
    Hah.
    The computer froze up and i kept hitting submit, It was during the storm
    Shots at Rosati FTL son!
    Veteran Member Three Rings 97audia4's Avatar
    Oct 03 2006
    Pa
    i rung 225 40 18 on my rials, and the rears are 9 inh and the fronts are 8.5 it looks streched
    12v<First Mistake of my Life
