Results 1 to 10 of 10
    Feb 12 2004
    N, VA
    Moaning sound from steering column
    When I turn now I hear a moaning sound from steering column within side the car. Power steering fluid reads fine. I can hear it just past the steering wheel. Turning feels heavier too.
    Veteran Member Four Rings Ewok_Fetus's Avatar
    Mar 04 2007
    nothing
    nowhere
    Re: Moaning sound from steering column
    Sounds like maybe the pump is taking a crap on you...
    May 23 2007
    99.5 Avant 1.8TQM
    the yay
    wheel bearing
    UNDER CONSTRUCTION
    Established Member Two Rings fr3nz33's Avatar
    Nov 10 2006
    1999 A4 Q 5spd, pretty stockish
    boston/wmass/ri
    ugh, me too, i'm afraid of either.
    Registered Member Two Rings
    Dec 28 2004
    pennsylvania
    I get that sometimes, seems to happen most on a really hot day, and kinda goes away after the first couple turns, like turning out of a parking space or something. Is this a similar thing to what anyone else is talking about?
    99.5 a4 1.8tqm
    93 318is
    Registered Member Two Rings kahng's Avatar
    Jan 23 2007
    96 b5 A4
    SoCal Redlands
    ooo i have the same problem ... i have no idea what that is.. but it get that when i make sharp turns when the car has been sitting for a while for instance when i come after sschool and turn out of my spot i get it. ...
    Mar 09 2004
    99.5 A4 Avant, 01 allroad
    nw michigan.
    It isn't the power steering. That usually has a gritty, notchy, or grabby feel. The moaning is usually a tie rod end. It could also be a control arm or wheel bearing. Control arm problems are usually accompanied by a clunk or thunk when cornering or hitting bumps. Wheel bearings usually hum when turning one way or the other.
    Jim
    I Do Werk.
    Oct 27 2006
    Pearl 98.5 Audi A4 1.8T
    Fargo, ND
    I had the same thing a week ago - I replaced my TRE's and it fixed the problem.
    Veteran Member Four Rings EuroA4's Avatar
    Feb 12 2004
    PA-NJ
    Yeah...I have the same issue. Although I had all my control arms and TREs done about six months ago (Febi/Bilstein)...and I can't believe they need to be done again.
    I assume with the H&R Race springs I am stressing the joints more than usual. Oh well that's what happens when you are down low!
    Veteran Member Four Rings Nebone's Avatar
    Jan 21 2006
    6MT BT Avant Ti
    RI
    I know what moan/groan sounds like from power steering. 2 weeks ago i'm driving an Mk4 and it starts squeeling bad. I pull over and see a trail of power steering fluid behind me. Steering rack blew a seal under the dust boot. Got all the parts and attempting replacement this weekend/week.
