Results 1 to 15 of 15
    Apr 24 2007
    chicago il
    Question s6 engine vs a6 4.2. what is the difference?
    s6 is making 340hp 40 over regular 4.2
    what is the difference??
    I guess exhaust making no more than 10 extra hp's.
    Nov 18 2005
    Pair of (. )( .)
    Re: s6 engine vs a6 4.2. what is the difference?
    tunning.....
    -Andrey
    Stanced and Tuned Brilliant Black RWD C5 A6 2.7T 6MT
    Veteran Member Three Rings Alpinevelo's Avatar
    Dec 28 2006
    06 VW Jetta I5 daily driver bone stock 4 now
    Fountain Hills, AZ
    Also some 4.2 engines have 32 valves and the S6 has a 40 valve 4.2L engine. Some of the newer 4.2 A6s have the same amount of valves but are software governed to make them fuel efficient.
    So that's where you see some people adding performance fuel injectors to some cars looking to get additional horse power. I know a buddy who owns a project S4 V8 and added Bosch fuel injectors, but I am not sure about the results...
    Something to ponder for sure...
    C5 A6 2.7T GIAC software Stage 1, EVOMS DV Valves, Cupra spoiler lip, RS4 OEM 18" Wheels.
    Alex
    Veteran Member Four Rings TheBlueMartin's Avatar
    Jan 06 2005
    2006 A6 3.2, 2009 Q7 4.2 Prestige, 2014 Regal GS M/T
    Ann Arbor, MI
    Im sorry to say this, but this place is always good for a laugh.
    The true answer is:
    Intake manifold (standard is a 2 vane, S6 is a 3)
    Camshafts (all 4; 2 intake, 2exhaust).
    ECU
    They both have the same stroke, bore, and valve configuration.
    Otherwise the engines are the same, and yes, the parts in interchangable.
    IIRC, wholesale cost on the cams are $1100 each (x4), and in intake is around $2000. Total install time is around 18 hours.
    Its not worth it for 40hp.
    "Mastering others is strength, mastering yourself makes you fearless" Lao Tzu
    2006 A6 3.2 Avant- Black.
    2009 Q7 4.2 Prestige - Lava.
    Dec 28 2006
    Fountain Hills, AZ
    Quote Originally Posted by TheBlueMartin View Post
    The true answer is:
    ECU
    Kiev, at least we had the ECU part correct LOL. Blue I am glad you didn't jump to the Lexus side, we need someone has to keep us honest here...
    Damn Wikipedia...sucks!!!
    Alex
    Nov 18 2005
    Pair of (. )( .)
    i actually came back to say it can be intake, hahaha, Blue you got the correct answer, cool you kept a6:)
    -Andrey
    Jan 06 2005
    Ann Arbor, MI
    The only reason I know about this is I looked into doing a swap 3 years ago. Its not worth the money IMO, because the extra 40hp only comes in over 4000rpm, which I rarely use that range anyways. The stock 4.2 has a little more power down low, but I cant find the graph.
    Ill still be going to the Lexus side someday, I just cant justify 4 years of payments to get rid of a car I love...
    yet
    Nov 18 2005
    Pair of (. )( .)
    at least get an gs or ls hybrid:)
    -Andrey
    Jan 06 2005
    Ann Arbor, MI
    Quote Originally Posted by kievskiy View Post
    Piss on that. Ill have my hands on a 600h next month, but none of the Lexus hybrids are worth the money.
    I want a 01-04 GS430, and then let the modding begin!
    Dec 28 2006
    Fountain Hills, AZ
    So realistically, was my buddy with the S4 wasting his money adding a "performance fuel injection system?" I think it was a CNC machined pump and the actual injectors...
    Alex
    Nov 18 2005
    Pair of (. )( .)
    so u planning to do JDM VIP style huh? toyota aristo ftw
    -Andrey
    Jan 06 2005
    Ann Arbor, MI
    Quote Originally Posted by Alpinevelo View Post
    Is it a 4.2 S4? If so, its a very different motor than a C5 4.2
    hell yeah, thats what Im talkin about. JDM badging would be just the start. TRD everything....
    Registered Member Two Rings 2Quick's Avatar
    May 08 2007
    2002 S6 Avant
    Peoria, AZ
    So, whats the major difference between the S6 4.2 and the S4 4.2? Is the difference major or minor tweaks? Just wondering...
    Jan 06 2005
    Ann Arbor, MI
    Quote Originally Posted by 2Quick View Post
    Very different motors. The B6/7 S4 has the new timing chain style motor, while you have the older timing belt style motor. There are more differences than I can list...
    Aug 27 2018
    Lebanon
    The true answer is:
    ECU
    Hi
    I have a 2001 S6 bought it 2 months ago. Everything was fine till 2 days agothere was a sound in the engine, showed it to a mechanic and he said the engine is gone!!!! So he suggested buying a new engine. It's not easy to find an S6 engine so He said maybe the lower engine of the regular A6 4.2 is the same as the S6 !! Is that true? So if i buy a half A6 4.2 will fit my S6 ??
    Thanks
