Results 1 to 21 of 21
    Jan 30 2007
    CLS63 AMG
    Bottom of the mountain
    Lots of white smoke from exhaust (with video)
    Recently my car has started losing lots of coolant, and also oil. I've notice white smoke coming from the exhaust previously but it wasn't too much and I dismissed it. However, during the last few days it's gotten really bad.
    Take a look at this picture and the video:
    http://youtube.com/watch?v=tA1ALMiYUwE
    Bear in mind it was a windy day and the smoke was going everywhere making it look worse than it really is, but usually it puffs straight out in a line. It only does this during idle, if I'm sitting waiting for the lights to go green or something.
    A mechanic told me it's to do with my lambda oxygen sensor and that the car is running lean.
    I'm hoping it's not a sign of a bust turbo or leaking head gasket. The performance is not affected, I've not lost any boost and the car doesn't overheat. The turbo doesn't sound too much different than before. The smoke definitely smells slightly strange, but not sweet.
    What would cause the car to smoke so much? All it's had is a chip.
    Veteran Member Four Rings GTMRS4's Avatar
    Sep 14 2006
    New York, NY
    Re: Lots of white smoke from exhaust (with video)
    Is the car riding rough? That sucks man
    BetaAlphaTau # 18
    2007 Q7 4.2 Premium
    2007 997 Midnight Blue
    2005 Lotus Elise Magnetic Blue
    2004 B6 APR STGIII+ (SOLD but not forgotten)
    May 13 2007
    Northern VA
    Blown head gasket.
    - Dan
    Jan 30 2007
    CLS63 AMG
    The thing is the car is driving, idling and performing as it should. I raced my buddies 323i and he couldn't pass me or indeed keep up.
    It just seems to be using a large amount of coolant, and smoking like nobody's business at idle.
    Veteran Member Three Rings KrUsTyX's Avatar
    Feb 05 2007
    1982 VW Caddy
    Quebec, Canada
    Quote Originally Posted by 04audiA4 View Post
    Blown head gasket.
    +1
    loosing lots of coolant + white smoke + no coolant on the ground = coolant is going somewhere... like in the cylinders = burning coolant = white smoke = head gasket
    good luck
    2006 Audi A6 Avant
    Arctic White
    Premium, Tech and Cold Weather packages
    VWQuebec.ca
    Veteran Member Three Rings Gallep's Avatar
    Mar 22 2004
    2014 Q7 3.0T, 2012 A6 3.0T
    Castle Rock, CO
    Blown head gasket.
    Yep, White Smoke + loosing coolant= Blown Head Gasket
    Previous
    USP B6 A4
    Jan 16 2007
    Wetzlar
    turbo?
    Veteran Member Four Rings krew53's Avatar
    2023 RS6 - 2013 B8.5 S4 - 2003 B6 1.8BT quattro
    Simi Valley, CA
    2nd on the blown head gasket.... I had the same thing.
    Jan 30 2007
    CLS63 AMG
    Oil and water do not seem to be mixing, and the car is not overheating at all. Could it not be something else?
    May 13 2007
    Northern VA
    All of the signs point to a blown head gasket.
    - Dan
    Veteran Member Three Rings kpatz's Avatar
    Nov 08 2006
    '02 Audi A4 B6, '06 Mazda6 wgn
    NH
    It wouldn't be overheating if you keep the coolant topped up.
    Did you check both the oil and the coolant to see if there's any mixing going on? If the oil cooler goes, you can get mixing but you wouldn't get the white smoke.
    Sounds like the head gasket to me.
    2002 A4 1.8T Quattro, 5 Speed, Goodwood Green (rare color!)
    Current mods: APR Stage 1+, TT225, 710N, APR Snub, JH solid short-throw shifter, JH solid linkage upgrade, Sachs clutch, Euro shift knob/boot, 4300K HID D2S, 18" VMR RS4 reps w/General Exclaim UHP, hardwired Valentine 1 w/remote display
    Sep 14 2006
    New York, NY
    Blown gasket...I'd stop driving it and have it replaced before you warp the head.
    BetaAlphaTau # 18
    2007 Q7 4.2 Premium
    Veteran Member Four Rings RLB6's Avatar
    Sep 20 2006
    '05 MV Agusta F4-1000
    MD
    I'm going to say blown turbo seal. The turbo has a dual chamber cartridge for oil cooling and coolant cooling. Coolant side is leaking and blowing coolant right through the turbine and into the exhaust.
    Current: '23 etron-GT | Prestige
    Previous: S5 | Prestige
    May 13 2007
    Northern VA
    Drain the oil and check it out, then pull the turbos and check them out. Check the head gasket last since thatll probably be the hardest thing to check.
    - Dan
    Sep 14 2006
    New York, NY
    If you drain the oil and there is coolant mixed then its a blow head gasket
    BetaAlphaTau # 18
    2007 Q7 4.2 Premium
    Veteran Member Four Rings A4 TSCHUSS's Avatar
    Apr 24 2005
    E55 AMG, CTS-V
    Jacksonville, Florida
    well most have summed it up. Smell the smoke, if it is sweet it is coolant, if it smells like oil, you guessed it, its oil If it is oil then your turbo seal went and its time for new turbo (just happened to me 3 weeks ago) you should also not be able to boost if it was the seals in the turbo, which you say you are still able to, so im guessing you head gasket is leaking just enough to cause the smoke from coolant but not bad enough yet to cause a performance loss. Check your oil and see if it is white or milky if it is your head gasket is done and it is mixing coolant into the oil while it is also getting burnt through the exhaust when entering the cylinders.
    ~David~
    Gone but not forgotten 437whp on 93 octane and washer fluid injection A4 12.2 best ET, 12.3@119 best overall
    480whp/500wtq E55 AMG 11.6@120
    CTS-V 9.6@148
    Jan 30 2007
    CLS63 AMG
    I just took it for a quick spin around the block and it was driving absolutely perfectly. Surely if the head gasket was on its way out performance and idle would be affected?
    It only smokes a lot intermittently too, it's not all the time, but there usually is a bit of smoke coming from the exhausts. The smoke definitely does not smell sweet, so I'm guessing it's oil. Like I said, I checked the oil and it looks perfect.
    I'm preparing myself for the worst
    Registered Member Three Rings Allwheel Driver's Avatar
    Sep 18 2006
    '02 A4 3.0 6sp, '02 A6 Avant
    Wanaque, NJ
    Leaking head gasket would be my guess.
    It will probably fail soon, get it fixed before that happens!
    '02 A4 3.0Q 6speed, Sport Package, GIAC, Neuspeed SS
    S4 rear swaybar, USP Front Lip (DIY), S4 door blades
    '02 A6 3.0Q Avant Tip, H-sport swaybars, 18" S4 BBS CH wheels
    Apr 24 2005
    E55 AMG, CTS-V
    Quote Originally Posted by cesc View Post
    ok, well does it smell like burning oil then?
    ~David~
    CTS-V 9.6@148
    Veteran Member Three Rings quattrotman's Avatar
    Sep 26 2006
    White smoke is a telltale sign of water getting into the combustion chamber somehow. You really should get on that as soon as you can because it's going to get worse and the coolant can glaze over the cylinder walls and screw up your rings....not to mention overheating probs/warpage....all not good and could be pretty expensive. Sucks dude.
    Jan 30 2007
    CLS63 AMG
    Quote Originally Posted by A4 TSCHUSS View Post
    Thanks for all the help guys.
    I'm not entirely sure how burning oil smells, but the smell that is emitted when the car is smoking is pretty strong and quite pungent. It's not a disgusting smell but it's not pleasant either. It's hard to describe.
    I've been getting a lot of different answers from people, but I think you guys are right about the head gasket as there aren't a bunch of more knowledgable people about.
