Results 1 to 10 of 10
    Sep 29 2006
    Westwood/West Los Angeles
    What does it mean when the "BRAKE" light flashes?
    What does it mean when the Red Light that says "BRAKE" flashes? My parking brake is all the way down too. It just keeps flashing as I am driving and it beeps three times when I turn the car on.
    Senior Member Three Rings ron8818's Avatar
    Dec 03 2006
    2005.5 A4 B7 2.0T
    Chicago
    Re: What does it mean when the "BRAKE" light flashes?
    X2.....
    I Just recently starting to see that as well, Only when I drive very aggressive it would "FLASH" and BEEP The "BRAKE" lights.
    I have driven my car very aggressive before I got the Dealer I3 Reflash campaign ?? Could that be the reason?
    Hi
    Sep 29 2006
    Quote Originally Posted by ron8818 View Post
    X2.....
    hehe, I didn't drive it hard at all, but lookin at your ICON I can see you drive hard
    Senior Member Three Rings PannikAttk's Avatar
    Dec 08 2006
    07 A4 2.0T - 07 X3 3.0si
    Miami
    Quote Originally Posted by alex310 View Post
    Might be low on brake fluid so check the dipstick. Had it happen on my 02 GTI 1.8t a few times due to a leaky reservoir. You must be real low because mine would only kick in during hard acceleration (fluid would swish around in the reservoir and kick off the sensor).
    Good luck, let us know
    His: 2007 A4 2.0T FWD 6 MT
    19" iForged Sprint - APR - H&R
    Premium/Convenience pkgs
    Hers: 2007 X3 3.0si
    Premium - Xenons - 18" split-spokes
    Veteran Member Three Rings sevenstarz's Avatar
    Dec 28 2005
    Orange Va
    This was happening to me. Check to make sure your brake pads are not too worn. Once I put on new pads, the light stopped flashing. Sounds like it is either low pads or low fluid (which should not be a problem unless you have a leak). Peace
    2015 SQ5 Brilliant Black | Black Optic | B&O | Carbon Inlays | 21's | KW Street Comfort | 15f/20r Spacers | RSNav S4 10.25 | 034 Stage 1 ECU/TCU
    Registered Member Four Rings 4-tified's Avatar
    Sep 18 2006
    A4 2.0T Quattro
    Chicago
    Quote Originally Posted by sevenstarz View Post
    Low/worn pads could cause a low fluid condition.
    As the pads wear the caliper needs to push farther to apply the pad to the rotor. The extra travel results in more fluid entering the brake lines.
    If you brake fluid resevoir was marginal to begin with, worn brakes can cause a warning.
    Another thing is ABS. There might be something wrong with the system.
    Check you manual and read what it says about the kind of light and flashing you have.
    Veteran Member Four Rings redhott06's Avatar
    Mar 15 2007
    2006 A4 2.0t
    Bedford, NY
    mine used to go off every once and a while, but hasnt in prob. 4-5 months. when i went to the dealership they added some fluid but they said it wasnt really that low to begin with....but it actually hasnt happened since the reflash!
    06 Brilliant Red A4 2.0T stage2+
    sparco, bbs, revo, stasis
    [email protected]
    Sep 29 2006
    You guys rock man! It was the brake fluid.
    Senior Member Three Rings pyrobecks's Avatar
    Oct 05 2006
    '06 A4 2.0TQ Prem/S-Line
    SoCal - OC
    I would be sure to check your pads, because as 4-tified said, low pads can cause low fluid.
    This happened to me a few months back and the dealer said it was low fluid, at my next service visit they advised me that my pads were low...
    ~ pyrobecks
    06 A4 2.0T Quattro Tip | Premium | DTM
    Stasis SS's > RS4 Rear Sway > VM Onyx Black 19” RS4 Reps > Black Optic DTM Grill >
    Smoked Corner and Side Markers > Audi Sport Floor Mats > Euro OEM Clear Corner Xenon's > VAGged
    Veteran Member Four Rings toaster's Avatar
    Sep 16 2005
    Gone:A4 USP+ / A4 S-Line+
    long island, ny
    there are two different icons for the fluid and the pads.
    i forget which corresponds to what.
