Results 1 to 8 of 8
    Veteran Member Three Rings Euro's Avatar
    Sep 18 2006
    Bimmers
    Portland
    A recomended tire size for a 18x8.5 wheel?
    for a 18x8.5 wheel....
    I was looking to try and fit a 225/40 but im not so sure any more.
    Lowered on Koni Coilovers. I want to be clear of any rubbing.
    I know that a 235/40 is probably a safer option as far as a better fitment, but I want to see what fellow zine members are running.
    I searched and didn't really find anything help full.
    How much of a visual difference will there be from the 225/40 compared to the 235/40? That'd be awsome if someone had contrasting close up pictures.
    Thanks.
    Nov 14 2006
    600hp glorified Beetle, e-tron, 1G DSM
    Gig Harbor, WA
    Re: A recomended tire size for a 18x8.5 wheel?
    The front tires on my car are 225/40 on an 8.5, click the link in my sig for several angles of the fitment.
    Keep in mind that I have Falken tires on my car though, and they tend to fit "skinny" so my 225's look more like a 215.
    -Darrick
    Jun 14 2005
    Anaheim, CA
    rubbing issues depend on your wheel's offset...
    Brandon @ VMR Wheels
    Brandon@Velocitymotoring.com | 714.442.7916 Ext 108 | www.velocitymotoring.com| Instagram | | | Blog
    Sep 18 2006
    Bimmers
    Portland
    +35 off set.
    Registered Member Two Rings Les_RS4's Avatar
    Apr 22 2007
    B7 A4, 1.8T, 5MT, M.BLue
    Beijing
    235/40 is good, 225/40 too narrow
    I had it in mine ET35, never had any issue rubbing
    Deactivated Four Rings
    Oct 06 2006
    South Bend, IN
    We'd recommend 225/45R17 for stock ride height. 225/40R17 is about 0.6" smaller in diameter (on average), and you'd need to run the tire with a little more PSI than stock.
    Veteran Member Three Rings robsilvr85's Avatar
    Nov 23 2005
    17 Volvo XC90 T8, 05.5 A4 2.0TQ
    Chicago
    I ran 225/40 on my 18x8.5 arctics also w/ a 35 offset. A little too narrow for the wheels but kept a somewhat stock diameter.
    05.5 A4 2.0TQ
    - JHM Stg1, DV, 18 Peelers
    11 Q7 TDI Prestige
    - 22 Ace Convex
    Feb 27 2005
    North Wales, PA
    225/40/18 as well on 18 x 8.5 35mm offset wheels. Pretty slammed b5 a4 on stasis CO. I would have loved to run a 235, but i would have rubbed in the front with rolled fenders.
