Results 1 to 15 of 15
    Established Member Two Rings MidnightCruiser's Avatar
    Jun 21 2005
    04 Audi A4 1.8T
    Arcadia
    HELP: car won't start and gas gauge shows empty...
    it happened all of a sudden today. in the morning on the way to work, it started fine. in the afternoon on the way to lunch, it started fine. after lunch on the way back to work, it won't start. since then every single time i need to jump start it. so i'm thinking it's the bad battery or the starter.
    but here's the whacky part, when i jump started the car for the second time, the gas gauge showed empty and the dashboard said 0 miles. so i quickly went to the closest gas station and poured gas until the pump stopped. assuming that the tank was full, i put it away and guess what, it only put 12 gallons. so with a help of a nice guy at the gas station i restarted the car again and the gas gauge now showed 3/4 full. wtf? as i was driving back home, the gauge slowly went up and by the time i got home (about 20 min. drive) it showed full.
    so now after a few hours of rest i restart the car just to see, the gauge shows empty and it says 0 miles again!!! there's no sign of leak anywhere whatsoever. could this be battery related?? and if the battery is causing all this, does that mean the starter is fine?
    how should i go about fixing these problems????
    tia
    PS
    oh and when i was looking for a leak, i heard some hissing/air gushing out sound from right rear (passenger side) wheel area. but it went away as soon as the car turned off. what could that be? and could that be related??
    Kerscher Front Lip // DTM Boser Hood // S4 Ecodes // Blackedout Grills // Neuspeed Catback // Magnaflow Tips // Revo Stage 1 // Forge DV // Neuspeed Shortshifter // 19" Maya STM Powdercoated Black Center with Painted Black Lip // Tein SS Coilovers // Eurocode Roof Spoiler // Lip Trunk Spoiler // 5% Charcoal Tint // 5400k HID
    Nov 28 2006
    2005 Audi A4, Yamaha gp800 Watercraft
    CT, USA
    Re: HELP: car won't start and gas gauge shows empty...
    im not sure what to say about the guage but the hissing sound is your fuel pump..... thats why your car isnt starting...its not getting the fuel from the tank because of the fuel pump or fuel filter....clean the filter and see what happens....like i said i dont know about the gauge though
    Veteran Member Four Rings alexza4's Avatar
    Apr 23 2007
    19-S5||22-GV70||14-RAM1500Hemi
    the problem does sound like the fuel pump problem, i had a very similar issue on my wife's X5.
    as for the fuel guage getting to full realy slow, i had this happen when i furst got my a4, first time i got gas. it took about 15 minutes for it to finaly get to full. that was it, no other adverse affects. it has only happened once and never since that.
    2019 S5 3.0T
    2016 A5 2.0T Cab
    2015 S5 3.0T - SOLD
    2003 A4 QM Uni EFR 6758 on meth - SOLD :((
    2003 A4 GIAC KO4 - SOLD
    Aug 26 2005
    Have the car scanned for DTCs, procede based on the results.
    Oct 16 2006
    Naperville
    Quote Originally Posted by alexza4 View Post
    The problem is when you fill up, dont leave your car in the "on" position. This happened to me beforer and someone on here filled me in.
    Veteran Member Four Rings GTMRS4's Avatar
    Sep 14 2006
    New York, NY
    My benz did that, it turned out being a sensor. Take it to a shop and let them know whats going on.
    BetaAlphaTau # 18
    2007 Q7 4.2 Premium
    2007 997 Midnight Blue
    2005 Lotus Elise Magnetic Blue
    2004 B6 APR STGIII+ (SOLD but not forgotten)
    Established Member Four Rings A4TL's Avatar
    Nov 06 2006
    335is
    atlanta
    well duh everyone since OBD-II has come out has known you never fill up with the car on, the fuel sender is relative.. not absolute.
    Veteran Member Three Rings kpatz's Avatar
    Nov 08 2006
    '02 Audi A4 B6, '06 Mazda6 wgn
    NH
    When you say it doesn't start, do you mean it doesn't turn over/crank at all, until you jump it? Or does it chugga chugga but not catch? (We need a sticky that says "when posting about no-start problems, please indicate what does happen when you turn the key!!"
    If it isn't cranking until you jump it, you have a bad battery. This causes all the computers in your car to reset, which could be causing some of your fuel gauge issues too, until everything recalibrates.
    2002 A4 1.8T Quattro, 5 Speed, Goodwood Green (rare color!)
    Current mods: APR Stage 1+, TT225, 710N, APR Snub, JH solid short-throw shifter, JH solid linkage upgrade, Sachs clutch, Euro shift knob/boot, 4300K HID D2S, 18" VMR RS4 reps w/General Exclaim UHP, hardwired Valentine 1 w/remote display
    Registered Member Two Rings ratty's Avatar
    Feb 03 2006
    B6 TQ
    Sydney
    Damn... when I saw the topic I thought this was one of those "I ran out of gas, is that covered under warranty" threads.
    Oh well, I have a smile just thinking it could have been.
    Mmmm, quattro
    Mmmm, Turbo
    Mmmm, APR
    Veteran Member Four Rings F16HTON's Avatar
    Jul 04 2004
    992 Carrera
    Makai - Kaka'ako
    When you battery lose a couple of cells, and dies, the gauge cluster does not work properly. I know this from experience. You need to invest 88 bucks into a new battery.
    In Limbo Four Rings
    Sep 27 2006
    2005 Audi B6 1.8t Ultrasport
    New Jersey
    its ur fuelp pump, ur dealer will tell u its ur fuel filter so they can loot off you, but its the fuel pressure regulator/fuel pump
    Jun 21 2005
    04 Audi A4 1.8T
    Arcadia
    thanks guys...
    so it's either the fuel pump (which i'm hoping it's not) or just the battery. i'll have a mechanic check it out.
    kpatz: the key turns and it makes 'click click' sound. indicators turn up while i'm turning the key.
    Nov 08 2006
    NH
    click click but no cranky cranky? Then you jump it and it cranks and starts up?
    It's the battery. The fuel pump wouldn't make it need a jump.
    Jun 21 2005
    04 Audi A4 1.8T
    Arcadia
    kpatz is indeed right. i replaced the battery and now everything's back to normal.
    Jul 04 2004
    992 Carrera
    Makai - Kaka'ako
    Quote Originally Posted by 400HPA4 View Post
    Told ya so!
