Results 1 to 22 of 22
    Established Member Two Rings kashutu's Avatar
    Dec 30 2005
    A4 1.8T
    MA
    ET 45 & ET 32? Whats the difference?
    Hey guys I wanna know if anyone have any pics of the cars with ET45 & ET32 wheels side by side. I know there is a lot of theory info. out there that I have looked at, but I still can't understand whats the difference, and howdoes it look like in real? Thanx
    Veteran Member Four Rings rxrep's Avatar
    Feb 28 2006
    has nothing in it but memories.
    Pittsburgh-Philly
    Re: ET 45 & ET 32? Whats the difference?
    ET45 is stock. If you look straight on at the car from the front, the stance will be narrower with 45 vs. 32 by 13mm (45-32=13). The wheels will appear to be tucked in more. Adding spacers to ET45 can get you out to ET32.
    The higher the value of the ET (offset), the more the outside edge of the wheel will be tucked in towards center. So, lower ET will make the stance wider, and the wheels will appear to stick out more.
    Hope that helps.
    FTR, RS4 ET is 28. Wide-ass mofo, for sure.
    Just think opposite. Lower number = wider stance.
    My 2004.5 APR Stage 3+ is SOLD
    Veteran Member Four Rings initiala4's Avatar
    Feb 24 2004
    Land of the smiles
    One sticks out more than the other. lower the offset the more the wheel will stick out more
    2019 B9 RS4 - O.CT Tuning Stage 1 | Wagner Intercooler / Radiator | Ohlins R&T DFV | 034 Motorsports Dynamic + Sway bars | 034 Motorsports Transmission mount | Ignition Projects Coilpacks | HHC Rear rotor upgrade 370mm + Endless MX72 brake pads
    Formerly - 2003 Audi B6 A4 1.8T QM, 2013 VW Passat Variant 2.0 TSI
    Veteran Member Four Rings Tgr_Clw's Avatar
    Jul 20 2005
    2003 Audi A4 1.8TQM
    Toronto, Canada
    The difference is 13mm.
    Appearance: OEM+
    Interior: B6 S4 Recaro Seats
    Performance: MTM Stage 3 / Milltek Exhaust+Milltek HFC / JJ TIP / ASP FMIC / SB FE SS
    Suspension: Vogtland Coilovers / HSport S4 Sways
    Braking: Stoptech 332 BBK
    Wheels/Tires: BBS CH 18x8.5, ET35 / GY Eagle F1 GSD3 235/40/18
    Registered Member Three Rings Allwheel Driver's Avatar
    Sep 18 2006
    '02 A4 3.0 6sp, '02 A6 Avant
    Wanaque, NJ
    et = mm in negative offset from wheel center line.
    '02 A4 3.0Q 6speed, Sport Package, GIAC, Neuspeed SS
    S4 rear swaybar, USP Front Lip (DIY), S4 door blades
    '02 A6 3.0Q Avant Tip, H-sport swaybars, 18" S4 BBS CH wheels
    Bklyn
    Neither one of them knows how to "phone home" :-(
    Feb 28 2006
    Pittsburgh-Philly
    Quote Originally Posted by cyclo View Post
    Buh-dump-crash...
    Thanks folks for coming to the Holiday Inn, I'll be here all week...
    That was pretty funny though.
    Nov 14 2006
    600hp glorified Beetle, e-tron, 1G DSM
    Gig Harbor, WA
    -Darrick
    Established Member Four Rings A4TL's Avatar
    Nov 06 2006
    335is
    atlanta
    make sure you are comparing equal width rims. ET35 of 8" rim is not the same as ET35 of 9" rim. someone had a nice diagram of how ET works it explained alot to me and i still don't get it.
    ET35 is hot on my rs4 reps (b5) compared to USP ET43 wheels. 8mm makes a helluvalot difference and i am not going any lower than sport 02 suspension so i think i could get a few more mm out but i'm not running spacers.
    Sep 18 2006
    Wanaque, NJ
    Quote Originally Posted by A4TL View Post
    The offset is measured from the centerline of wheel (sliced in half vertically).
    So a wider wheel with the same offset will have different measurements from the inner rim edge to the mounting plane because it will have more distance on either side of the center line.
    Make sense?
    Dec 28 2006
    '13 A5, '24 Tiguan SEL R-Line
    Western Maryland
    Sep 18 2006
    Wanaque, NJ
    From my understanding that has positive/negative reversed.
    Almost all wheels for modern cars have negative offset, such as in the schematic.
    The wheel when mounted is offset 35mm towards the inside.
    If you add a spacer, say 10mm to a 45mm negative offset wheel (et45) you get the eqivalent of 35mm negative offset.
    Dec 28 2006
    Western Maryland
    I believe the diagram is correct. If you assume the wheel in the diagram has a 45mm offset and you add a 10mm spacer you will move the blue centerline of the wheel out by 10mm thus reducing the ET (red horizontal line)to 35mm.
    Forum Moderator Four Rings actlsub9's Avatar
    Jun 13 2005
    Audi
    Quote Originally Posted by Allwheel Driver View Post
    It is correct, positive offset is toward the spokes on the outside of the wheel, negative offset is toward the inside of the wheel. And most cars have a positive offset not negative as you say.
    Greg - Moderator
    WWW.ACTLSUB9.COM
    Sep 18 2006
    Wanaque, NJ
    It's misleading because a wheel with less offset actually mounts more towards the outside.
    But by that picture and description, more offset would move it outwards.
    I learned it as the relationship between the steering axis and the mounting plane of the wheel.
    Negative offset puts it inside the steering axis, Positive outside.
    Zero offset is where the wheel is obviously centered on the steering axis.
    Jun 13 2005
    Audi
    More offset would move the hub mounting surface towards the outside of the wheel, therefore moving the wheel inward when mounted. The picture/description is correct.
    Greg - Moderator
    WWW.ACTLSUB9.COM
    Sep 18 2006
    Wanaque, NJ
    Yeah, I'm getting it all confused.
    I don't know why I think it's the other way...maybe brain damage.
    Aug 26 2005
    Zero offset, is when the wheel to wheel hub mounting surface plane is located exactly on the wheel centerline. (the wheel centerline divides the rim width distance by 2) Positive offset places the wheel centerline toward the outside of the wheel/hub mounting surface at the wheel hub, negative offset, positions the wheel centerline inside of the wheel/hub mounting surface, (inside/outside being referenced as mounted on the car, relevent to the chassis centerline.)
    Mar 16 2013
    Ilford, Essex, UK
    Hi, I see that this is an old thread, but wanted to ask if it is simple as measuring g from the inside edge of wheel arch to face if tyre to find the spacer width needed to make the wheel/tyre flush?
    On my B6, S4 with stock avus 18inch 8j wheels I reckon this is 15mm front and 18mm on back?
    Anyone concur?
    Dec 28 2006
    Western Maryland
    Quote Originally Posted by tanahmed View Post
    Anyone concur?
    You have it right. Just measure the clearance between the tire and fender to determine how far you can offset the wheel. That is the spacer size you will need. Without knowing your ride height I don't think anyone can confirm your listed measurements but they sound reasonable to me as long as you aren't slammed.
    May 21 2007
    Florida
    for reference, this was 18x10 ET32 on the rear of my B7A4:
    2018 Navarro Blue Q5
    Nov 11 2010
    Rochester, MN
    ^^ and that is what is referred to as "poke", correct? i.e. a wheel with an offset of 32 would stick out more than a wheel with offset of 45.
    19" B8 S5 Peelers
