Results 1 to 14 of 14
    Established Member Two Rings jstrat812's Avatar
    Mar 09 2007
    Scottsdale
    Definition of Stage 1 vs. Stage 1+???
    I have searched first, I promise!
    I am serious about the chip, and from what I have read the 380cc injectors are a great compliment. I was under the impression that the chip + injectors = Stage 1+
    A knowledgible VW/Audi friend of mine told me that you need the test pipe, intercooler, chip and injectors to be Stage 1+.
    Is this true?
    What is the true definition of Stage 1 vs. Stage 1+?
    And how much am I looking to spend on 1+? (ballpark)
    Feb 17 2005
    Sarasota, FL
    Re: Definition of Stage 1 vs. Stage 1+???
    Stage 1 is software only, 1+ is different software and injectors
    IC, TP, etc have nothing to do with it
    The software for either should be $500 and depending on whether you go, REVO, APR, or GIAC, injectors will be anywhere from $200 - $400
    Senior Member Three Rings NJ_A4_Lion's Avatar
    Apr 03 2007
    2007 S6
    Great question and as a Noob myself, it will be my pleasure to help you out.
    Stage 1 = flash only. APR quotes 215 hp and 245 Torque on 93 octane. While many will argue these numbers are not accurate this is what APR claims (if you go with their set-up). However to get closer to this number you would probably want to do other upgrades (intake, exhaust etc.) This initial upgrade will run you $500 + tax and labor
    Stage 1+ = another flash with the addition of injectors (Audi TT injectors or 380 injectors). According to APR, this is supposed to give you 235 hp and 275 torque. As mentioned before many would argue this is not the case but you can judge for yourself. I am currently in the process of moving from the stage 1 to the 1+. However, I feel as though my car has plenty of power because I started with the supporting modifications (i.e. CAI, Full Exhaust, Diverter Valve). So by the time I received the chip the set up was just right to receive the additional power. This setup will cost you $1,000 + tax and labor unless you are upgrading from a stage 1 (should only cost about $600).
    One thing to keep in mind is how far do you want to go. It is very simple to get carried away with these mods. So it is up to you to figure out what you want but eventually you will want more. If you see this happening just move to an S4 lol…
    Hope this helps.
    P.S. Fellas, let me know if I missed anything.
    Quote Originally Posted by jstrat812 View Post
    Is this true?
    2014 Q7
    Fully Loaded
    _____________________________________________
    Sold:
    2007 S6
    Fully Loaded
    Sold:
    2005 3.2 A6 Fully Loaded
    2004.5 1.8T 6MT A4 & 2001 1.8T 5MT A4 Fully Loaded
    Veteran Member Four Rings Daddy MO's Avatar
    Jan 28 2007
    e30 * K5 Blazer * Xterra
    NOR*CAL - Benicia
    I have stage 3 bitch!!!
    3.SLOW that is
    Thanks to: Lubrify.com / TOMAS Sport Tuning / BRRacing / Craftwerx Concepts / I/O Port Racing Supplies / AGUND1S Tire
    Dec 28 2006
    '13 A5, '24 Tiguan SEL R-Line
    Western Maryland
    Quote Originally Posted by NJ_A4_Lion View Post
    Hope this helps.
    Hey, not bad for a noob! You have definitely been listening!
    Veteran Member Four Rings Spinnetti's Avatar
    Dec 10 2004
    R8_LS400
    Dallas, TX
    BTW, "Stage" is just a marketing term, and varies by vendor, though the feedback you got is generally in line by what people mean by 1 or 1+
    2008 R8 V8 Manual: Uni 93 ECU tune * Avior Exhaust * Spacers * R8 Puddle lights * Custom mats. All 12 of my other VAG cars are gone :(
    Registered Member Three Rings Allwheel Driver's Avatar
    Sep 18 2006
    '02 A4 3.0 6sp, '02 A6 Avant
    Wanaque, NJ
    Quote Originally Posted by Daddy MO View Post
    3.SLOW that is
    I thought you had Stage 3.0+ ?
    '02 A4 3.0Q 6speed, Sport Package, GIAC, Neuspeed SS
    S4 rear swaybar, USP Front Lip (DIY), S4 door blades
    '02 A6 3.0Q Avant Tip, H-sport swaybars, 18" S4 BBS CH wheels
    Registered Member Two Rings
    Oct 18 2006
    01 Jetta VR6, 06 A4 2.0T MT6
    Somerset County NJ / Universit
    guess you didnt look hard enough...
    http://www.audizine.com/forum/showthread.php?t=96446
    Stage 1 = chip
    Stage 1+ = chip+ any other mods without a turbo upgrade
    01 Jetta VR6
    Cool White
    AEM - Magnaflow - H&R - ASA - Joey Mod - GLI front - Streetone - BFI
    Near Future Plans: Painted Boser Hood/boser extentions, rear bumper, pulleys, Turbo :D ...suggestions welcome.
    Mar 09 2007
    Scottsdale
    Actually I looked at that "sticky" post first! If you can tell me where it says the difference between stage 1 and 1+ Id love to know.
    4. Chip – A chip is probably the best bang for your buck and the most favored by most 1.8T owners. It remaps the feul and boost to push more hp on your car. The main companies are GIAC, APR, and REVO. Many choose based on which dealer is closest. All of them have upgrades for K04 and BT applications but prices vary. However… now there is a new form of “chipping” called “flashing”. Basically instead of putting an actual chip, the whole ECU gets deleted and a new file is put on for your application.
    Veteran Member Four Rings roarincheetah's Avatar
    Sep 14 2006
    04 A4 1.8t USP, O2 Chevy Avala
    not sure where you were reading, but this kinda SPELLS it out for me...
    Quote Originally Posted by AudiA4_18T View Post
    Stage 1 = chip
    Stage 2 = K04
    Stage 2+ = K04 with other mods
    Stage 3 = BT at 270-350 chp
    Stage 3+ = BT at 350-400 chp
    Stage 4 = internal/head work making 400-500 chp
    Stage 5 = Stand alone or making 500+ chp
    CHP = Crank Horsepower
    WHP = Wheel HP (usually AWHP for us)
    ~Chris
    Back from Outerspace...
    Registered Member Three Rings 8E1POINT8's Avatar
    Sep 26 2006
    Pittsburgh, PA
    While its brought up, how come there's hardly any guys going stand alone on b6s? The b5 guys are making tons o power, 034 has great stuff, people like Tom Ritt have even strapped Holset Cummings turbos on and have them tuned. What giveS?
    Pete
    -04 1.8TQ-
    APR Stage 1+(93 & 100)--TT225 Injectors--K&N--710n--BKR6E--T.P.--Autometer--S4 Blades--LaminX--CC--Kamei--Ace Zeus 18x8.5--Toyo--Kenwood PNAV DDX-6019--Lip Spoiler--20% 3M--All kinds of black shit--
    Oct 02 2006
    Arlington
    B6s are fat pigs - as opposed to our older brothers.
    3700 lbs vs. 2998 lbs. (700 may not sound like much but it def makes a difference)
    2002 A4 1.8T
    Current Mods: Ko4 Turbo, APR chipped, 35% Tint; 19in RS4 Hyper Silver; Pioneer Z1 - Ipod Adapter - XM NavTraffic - Bluetooth; S4 door blades and side mirrors, debadged, Valentine 1 with concealed display, RS4 pedal set, RS4 Carbon Fiber; Thermal Race Exhaust, Eurocode testpipe and FMIC,
    No Body Kit yet (:() but soon.....
    Veteran Member Four Rings AudiA4Style's Avatar
    Feb 24 2004
    B8.5 S4 l 75 CB550 Cafe Racer
    Quote Originally Posted by XipeR View Post
    Stage 1 = chip
    Actually Stage 1+ = chip + bigger injectors
    Also $500 is the going rate for "stage1", "Stage1" $550-600.
    2013 S4 l Prestige l Moonson Gray l S-Tronic l Sports Diff l Fine Nappa l Carbon Atlas
    2006 S4 l Avant l Premium l Dolphin Gray l MT6 l Bose l Silk Nappa Leather l Gray Birch
    Oct 29 2005
    10speed
    San Francisco, CA
    Quote Originally Posted by 8E1POINT8 View Post
    Our fuel systems hold us back... Our fueling can only hold us up to around 350whp which is pushing it. In order to upgrade you can do B5 fueling but its custom there is no kit for it. Also our DBW limits us. And on top of all that, youd have to throw rods in your motor to support big hp. There are many going the big route but it is still new in terms of crazy hp on our motors. A few are pushing the limits we will see how it turns out. Id stay updated on Jordan and Shawns progress
    - Clint
