Results 1 to 11 of 11
Thread: 245/35 on 19x8
    Established Member Two Rings Rulez's Avatar
    Nov 02 2006
    2011 Audi S4
    Orlando, FL
    245/35 on 19x8
    I did some searching and found some results, but I just wanted to be sure.
    I got some 19x8 Flik Justices and I wanted to run a 245 for a wider look. I hate tire stretch. Will these fit without any rubbing issues? Or, will 235's fit without that stretched look?
    If anyone has any close up or detailed pics of either, I'd love to see them :)
    Mike Rule
    2011 Audi S4
    Nov 14 2006
    600hp glorified Beetle, e-tron, 1G DSM
    Gig Harbor, WA
    Re: 245/35 on 19x8
    235's will not have a stretched look on an 8 inch wide wheel. You can also run 245's if you would like to. However, whether or not they will rub depends on the offset of the wheels. If the wheels have an offset higher than et35, chances are they won't rub. If your car is lowered, how much it is lowered plays a part too.
    -Darrick
    Registered Member Two Rings
    Dec 08 2006
    2003 Infinity G35 6mt
    Abingdon, MD
    Re: 245/35 on 19x8
    By higher, do you mean +40, +45, etc?
    Or + 30, +25?
    --2003 Infinity G35 6mt--
    --HKS Hipermax RS Coilovers | 19x9.5", 19x10.5" Work Meister S1's w/245/35 & 275/30--
    Nov 02 2006
    2011 Audi S4
    Orlando, FL
    Re: 245/35 on 19x8
    Quote Originally Posted by 2wdsux View Post
    Or + 30, +25?
    Higher? I said wider :)
    EDIT: I just realized you were speaking to Capt. Obvious, not me. Nevermind :)
    Quote Originally Posted by Capt. Obvious
    So 245's must be cutting it pretty close then I assume. My wheels are +35mm and I dont plan on slamming the car, just a moderate drop so it doesnt look like a monster truck.
    Mike Rule
    2011 Audi S4
    Nov 14 2006
    Gig Harbor, WA
    Re: 245/35 on 19x8
    I meant higher as in 40, 45, etc.
    I wouldn't say that 245's are cutting it pretty close. There's plenty of people on here who run 245's. However, most of them have 18's. If it were me, I would go with the 235's.
    -Darrick
    Senior Member Two Rings pms's Avatar
    Mar 14 2007
    2004 S4
    Roswell, GA
    Re: 245/35 on 19x8
    I realize you stated that your reasoning for wanting to run the wider tire is for appearances sake, but here is a link to a very interesting discussion that took place on a local autocross forum regarding the performance implications of running a wider tire on the same width rim: http://soloatlanta.com/forum/index.php?showtopic=2545
    I found the discussion and conclusion interesting.
    Nov 02 2006
    2011 Audi S4
    Orlando, FL
    Re: 245/35 on 19x8
    Quote Originally Posted by pms View Post
    Thats pretty amazing for only 10mm difference per tire
    Mike Rule
    2011 Audi S4
    Established Member Two Rings grey_squirrels's Avatar
    Nov 21 2005
    2003 VW GTI IY, 94 Miata (cheap track)
    Ft Lewis, WA
    Re: 245/35 on 19x8
    Falkens run wider too though. I am running the 615's also and they are just a wider tire than comparable brands.
    2000 S4--- Black
    Stage 2
    Feb 19 2007
    FAR @ SG
    Re: 245/35 on 19x8
    I bet you wouldn't have looked in my thread that was right above yours cos it was only something totally different but here they are -
    not much of a depth perception shot but it's a 245/35/19 on a 19x8 ultraleggera. offset is +35.
    Drop coming but from what I've been told by my guys, NO RUB!
    http://img482.imageshack.us/img482/2...closeupmg7.jpg
    EDIT: offset is +45. not +35.
    Veteran Member Three Rings quattrotman's Avatar
    Sep 26 2006
    Re: 245/35 on 19x8
    IMO on an 8" wheel they'll look like balloons but will probably fit.
    Nov 02 2006
    2011 Audi S4
    Orlando, FL
    Re: 245/35 on 19x8
    I ended up ordering 235/35 BFG KDW2's. I'll post up pics when they are on :)
    Thanks for the pic SQX18T!
    Mike Rule
    2011 Audi S4
