Results 1 to 13 of 13
    Active Member Three Rings PROXUS's Avatar
    Jul 19 2005
    Chicago
    Is it possible to fix 2 piece wheel barrel without removing center piece?
    One of my wheels came defective from the factory (barrel geometry was not perfect » VIDEO), and I shipped it back. Manufacturer offered to fix it but in the same time they want to keep the center piece and put it back once barrel is fixed and straight.
    Well....I'm not a wheel expert but those 2 piece wheels are welded, and I assume that in order to fix the barrel, you would need to disassemble those pieces (unweld the center)
    If I'm correct, how safe and possible is that. Unwelding and welding the same piece could degrade the strenght of the wheel I guess
    Up to date manufacturer and dealer are very responsive and helpful but I want to be 100% sure that I get quality product.
    Nov 14 2006
    600hp glorified Beetle, e-tron, 1G DSM
    Gig Harbor, WA
    Re: Is it possible to fix 2 piece wheel barrel without removing center piece?
    If it isn't safe to do, the company that manufactured the wheels isn't going to do it. There is WAY too liability on them to do something unsafe.
    Hell, BBS and HRE won't even sell you new bolts for your wheels unless you are an authorized repair shop.
    -Darrick
    Veteran Member Three Rings quattrotman's Avatar
    Sep 26 2006
    If it really is a 2 piece wheel it is not welded. If it's welded, it's 1 piece. If it's 2 piece the rivets/bolts can be removed and the center comes out. that's why its called 2 piece. They only thing you need to worry about when you put them back together is that:
    A. You torque those bolts back on in a star pattern to the correct torque specs
    B. Mark the wheels so that they go on EXACTLY the same way and line up with the same holes as when they came apart.
    I had a prob when I refinished my 2 piece Oetty's. The refinisher did not mark them and they ended up having problems balancing so they all had to be straightened and re-done.
    They should come apart though.
    Veteran Member Four Rings Re5pectThe_Cuz's Avatar
    are those iForged? Good luck getting them back in a timely fashion. and technically that wheel is now a 1 piece. it was a 2 piece but was welded
    Black A3
    Got Oetty?
    Veteran Member Three Rings DUDEFROMRI's Avatar
    Nov 07 2006
    B7 S4
    Pooler, Georgia
    Not to mention, If it is welded it can be heat treated to obtain its required strength after the re-weld.
    RIP SWAY
    2016 S3-Current
    2013 A4-Gone
    2006 Cayman S-Gone
    2008 S4-Gone
    2003 A4- Gone
    Veteran Member Three Rings boostinmr2's Avatar
    Jun 02 2005
    selling all fast toys - IM me
    Aiea
    Quote Originally Posted by quattrotman View Post
    Wrong- it's two piece still.
    Check with Work, many of their wheels even LACK the rivets and the such and are still 2 pc. Generally speaking it means that the two pieces are constructed separately and then welded together to give more options for offsets/different discs and the such. One piece wheels are cast as one piece from the get go.
    Even three piece wheels like HRE - they are welded. The disc is 1 pc. The inner barrel is 1 pc. The out barrel (meaning lip) is 1 pc. How does the inner and outer connect? They are welded...
    Forum Moderator Four Rings actlsub9's Avatar
    Jun 13 2005
    Audi
    yea, to fix the barrel they may only need to remove the spokes and leave the weld...
    Greg - Moderator
    WWW.ACTLSUB9.COM
    Veteran Member Three Rings 2k1s's Avatar
    Sep 14 2006
    the cpt, ca
    Quote Originally Posted by Re5pectThe_Cuz View Post
    wrong. they are still 2 piece. which has already been said. I know some of the guys over there through my truck. My buddy is the marketing manager for intro wheels, the company that actually produces iforged's stuff. Even if they aren't iforged, all custom wheel companies do the same thing.
    The way they do the wheels is they heat up the barrel, slip out the center, and reweld the centers in. It won't affect the strength of the wheel. I had them done multiple times on my truck, since I kept bending 20 inch hoops. The center is the only expensive part of the wheel. The hoops aren't made by iforged. In fact HRE and iforged uses the same company to produce their forgings and their hoops. All HRE offers is a higher price, same quality of machining.
    Jun 02 2005
    Aiea
    HRE, Iforge and DPE use the same barrel manufacture.
    I just don't support Iforge because it's more like iForgery.
    Jun 02 2005
    Aiea
    Quote Originally Posted by actlsub9 View Post
    This is a 3 pc wheel, not a 2pc.
    The center (disc) clearly separates making it the third piece.
    Stage 2 Banner Advertiser Four Rings Eric@SupremePower's Avatar
    Sep 27 2004
    So Ca
    It is completely safe to do this and is an industry standard with all that manufacture two piece welded wheels.
    Eric Nareshni
    [email protected]
    714-632-1951 x225
    | 034 | ADV.1 | AG | Advan | Akrapovič | AWE | BBS | BC Forged | Brembo | Capristo | Forgeline | H&R | Klassen | KW | Milltek | Modulare | Ohlins | OZ | Stoptech | TSW | Volk | Vorsteiner | Work | and many more
    Quote Originally Posted by 2k1s View Post
    please re-read..i said technically. Not that its officially a one piece wheel, but rather you cannot just remove the rivets and unbolt the wheel. That is all I meant.
    Black A3
    Got Oetty?
    Sep 26 2006
    Quote Originally Posted by boostinmr2 View Post
    I don't know if all these wheels are made the same or someone is wrong here. My Oettinger RZ's are 2 piece and they seperate just ike the pic above. The center comes off when you remove the rivets and the hoop is not welded or anything.
