Results 1 to 28 of 28
    Veteran Member Four Rings DELUX's Avatar
    May 28 2004
    04 A4 USP 1.8TQ M6 Ultrasport
    Asheville, NC
    Is there any difference between the OEM and Bosch Aero Wiper Blades from ECS?
    I ordered the Bosch Aero Wiper replacement for my OEM Aero Wipers on my A4 and I noticed that there was also an OEM replacement. I kinda assumed that the OEM version was Bosch as well, but they're cheaper it appears, so what I'm thinking is that the Bosch Aero Blades are perhaps more heavy duty or thicker than the OEM version.
    Anybody know?
    This is what I ordered:
    Quote Originally Posted by ECS
    Bosch Aero Wiper Blade Set ES#4997 - $49.95
    USP CLUB MEMBER #3 - 2004 Audi A4 1.8TQ6
    Veteran Member Four Rings heateris's Avatar
    Aug 16 2004
    08 A4 2.0TQM6 ~ 08 Highlander Sport
    SE PA
    Re: Is there any difference between the OEM and Bosch Aero Wiper Blades from ECS?
    my bubby got them from ECS. they seem nice.
    Dec 18 2006
    03 A4 1.8t | 04 IB M3 SMG
    Hanover, NH
    u need the aero arms for those wipers and they make no big diff
    May 28 2004
    Asheville, NC
    I already have the Aero arms, I have a USP, they came with the Aero wipers.
    And yea... they make a HUGE difference actually. The curvature is more natural, they're more aerodynamic and don't get lifted off your windshield under high speeds, and they last pretty damn long. I'm changing mine for the first time @ 44k miles.
    On our X5, I changed the traditional Bosch Wipers to some Valeo Aero wipers and the difference is huge, especially on the back window where traditional wiper blades always had a tough time staying down because the window is do damn curved.
    May 28 2004
    Asheville, NC
    Quote Originally Posted by heateris View Post
    Did he get the Bosch or the OEM?
    Dec 18 2006
    Hanover, NH
    heh - i just screwed my arms on extra tight and they hug my window nice
    although one of my wiper arms is jacked cuz the wiper is like ripped so it squeeks like a mother
    Veteran Member Four Rings A4TUNE's Avatar
    Sep 14 2006
    Mass
    I def need some new wiper blades.. Was just going to search for info on them and saw this thread. To my understanding you can only use Bosch Aero Wipers if you have USP (Aero) wiper arms and they won't work with a sport model A4? What are the best options for a sport A4?
    -Max
    2004 A4 1.8T M6 Quattro Ultrasport
    REVO Stage 1 | AWE Boost Gauge | Carbonio CAI | Valeo Single Xenon Black Ecodes | RS4 Rear Sway Bar | 18x8 OZ Superleggera | DTH USP Splitter
    Veteran Member Four Rings Audized's Avatar
    Oct 22 2006
    Eh?
    to my understanding, aero wiper's a standard feature for MY2004 and on. I've been looking for aero wiper blades that fit our older model's conventional wiper arms. I don't know if there is any out there, though.
    the best option would be to get aero arms from ECS.
    Sep 14 2006
    Mass
    How do I know if I have the correct wiper arms for the aero blades? They come stock on 2004+ you say?
    BTW whats "MY"2004
    -Max
    Oct 22 2006
    Eh?
    sorry about the confusion. MY stands for model year. i could be wrong about when audi started putting aero wipers on A4's. either 2004 or 05.
    here's a pic of aero wiper arms.
    http://www.ecstuning.com/stage/image.../5823_x600.jpg
    Senior Member Two Rings JonnyQ's Avatar
    2003 A4 3.0 quattro 6spd
    Long Island, NY
    If you have the aero arms you will have the aero blades. Are your blades 1 long strip of metal with rubber attached (aero), or do they have multiple hinged segments (old style)?
    check out ECS link for pics of aero blades. if you don't have them , you have the old style arms, and the old style arms only fit OEM blades or some have used Anco rubber inserts in the old style OEM blade.
    The arms (old vs aero) actually look very much the same, its just the way the blade attaches to them thats different.
    Dec 18 2006
    Hanover, NH
    OMFG I Just found out one of the metal pins from the wipers was scraping on my windshield and thats what the squeeking is from - and i was like well it's getting better day by day which is because the scratching was making a groove in my windshield hahah so now i have a frigging scratch at the base of my windshied about 1/20 inch deep
    GRREEEATT
    i just cut the pin off and now its perfect
    /rant
    Dec 18 2006
    Hanover, NH
    Bosch won't work with regular Audi arms - actually its just MY2003 - 2003 had all kinds of random bullshit
    the 2003 arms are kept on by a clip that NO ONE MAKES but audi and are like $40 a pair
    so your best bet is to just get new wiper arms and put the shits on
    although adjusting the arm positions are really a bitch
    May 28 2004
    Asheville, NC
    But the Bosch Aero blades will work with my OEM Aero arms right?
    EDIT: They should, the description says that they require OEM Aero wiper arms.
    Long Island, NY
    I remember reading somewhere that Valeo developed the wiper technology and sells it as 'ultimate wiper'
    but licensed it to Bosch , which sells it as 'Icon'.
    I think they are pretty much the same unless someone else knows more..?
    May 28 2004
    Asheville, NC
    The Valeo seems just as good. I found an aero-style replacement wiper that fit our X5 from Valeo and they work very nicely
    Veteran Member Four Rings toaster's Avatar
    Sep 16 2005
    Gone:A4 USP+ / A4 S-Line+
    long island, ny
    are there any aftermarket blades that are similar to the "aero style," that will not require me to change my 2002 oem arms?
    May 28 2004
    Asheville, NC
    Yea Valeo makes some wiper blades that are frame-less and utilize a standard wiper arm. I mentioned earlier that I picked up a set for our X5 and they work great :)
    Also... there IS a difference between the Bosch and the OEM. When I took the OEM blades off I compared them to the Bosch replacements that I ordered from ECS and the Bosch blades are a bit beefier with more rubber on them. They seem like a better blade.
    Veteran Member Two Rings StEvO's Avatar
    Apr 19 2005
    Chicago
    Rain-X also makes them now they're called the "latitude" blades and they fit the "old" style wiper arms...
    http://www.rainx.com
    APR K04, APR Exhaust, RaceTec FMIC, South Bend OFE HD Clutch, Koni Coilovers, H-Sport S4 Sways, B6 S4 Brakes, 18" ASA AR1s, Neuspeed Xtreme intake, Neuspeed short shifter, APR snub mount, Stratmosphere Hyperboost HX Compact DV
    Sep 14 2006
    Mass
    Where can I pick up some Valeo blades? Walmart?
    -Max
    Sep 16 2005
    long island, ny
    freakin' awesome...my wipers are pure streaky garbage right now.
    what lengths are our wiper blades? driver and passenger are different, right?
    https://www.buyrainx.com/index.cfm?C...TOKEN=56430837
    Veteran Member Four Rings orttauq's Avatar
    Mar 11 2007
    8V S3
    tri state
    Michelin makes an aero blade replacement for many makes and models now, so no need to change over to aero wiper arms for those not equipped....
    Valeo is the OEM manufacturer for the aero blades currently. That changes what seems like weekly these days though...
    Veteran Member Three Rings Shak's Avatar
    A4 B6
    Northern VA
    I've been thinking of getting new blades / inserts for a while now too. How can you tell if you have the AERO arms v. the regular arms? Did it come with the car after a certain model year?
    2002 A4 Quattro Tiptronic w/ Sport Package
    Mods:
    Cleared Corners; Headrest Mod; Symphony II+; Aero Wiper Arms and Blades; Painted Lowers; RS4 Rear Sway Bar, 35% Window Tint
    Sep 16 2005
    long island, ny
    can someone post the lengths of the wipers that we need?
    thanks.
    Oct 02 2006
    Wadsworth,OH
    Ok, since there seems to be a few questions, I will try to help everyone out.
    Cars up to Vin # 4 135000 (split in 2004 model year) have standard wiper assemblies that can be replaced by the Bosch Icons wiper blades. Bosch Icons are made to resembled the OEM Aero blades without having to change the arms. The actual size that you need is 21.6", but Bosch Icons are only 21" or 22", we will be testing correcting sizing on the Bosch Icons this week & posted them on the site. I am going to assume it will be the 22" versions
    For customers that want to convert to from the standard style to the OEM aero set-up they will have to buy are complete kit. (arms & blades) The OEM aero's are here:
    Replacement blades for the OEM aero's are here:
    Sep 14 2006
    Mass
    Quote Originally Posted by Shak View Post
    Dude read the thread before you post, the questions you asked have been answered already.
    -Max
    Sep 16 2005
    long island, ny
    awesome.
    post a link to the blades i need for my non-aero arms and i'll be all over it..
    Veteran Member Three Rings kpatz's Avatar
    Nov 08 2006
    '02 Audi A4 B6, '06 Mazda6 wgn
    NH
    Has anyone tried the Rain-X Latitude blades? My stock blades are driving me nuts, I replaced the inserts last fall and now they're streaking like crazy again. Such a nice car, but crappy wipers. I'll try cleaning them at lunch and pick up a set of Latitudes at Pep Boys and see how they do.
    EDIT: Cleaned the blades, they work great now. Also cleaned the windows.
    2002 A4 1.8T Quattro, 5 Speed, Goodwood Green (rare color!)
    Current mods: APR Stage 1+, TT225, 710N, APR Snub, JH solid short-throw shifter, JH solid linkage upgrade, Sachs clutch, Euro shift knob/boot, 4300K HID D2S, 18" VMR RS4 reps w/General Exclaim UHP, hardwired Valentine 1 w/remote display
